Question about Brother HL 2140 Laser Printer
Can we use tracing pager for print in brother HL-2140 printer model
    Brigadier General:
  • 5,158 Answers
Consult your manual for maximum and minimum thickness of paper ... i suspect tracing paper will jam the printer
Posted on Jan 06, 2009
Can i set the Brother HL-2140 to print double sided. I cannot find it ?
The Brother HL-2140 does not include duplex printing. The only option for double sided printing with this model is to print odd numbered pages, then manually replace the paper into the tray and print the even numbered pages in a second set.
Regards,
Dan
IT Professional
May 04, 2011 | Brother HL 2140 Laser Printer
Tip
Resetting Blinking Toner Light HL-2140
Here is the procedure for resetting the Toner flashing light on Brother HL-2140 (sources for other answers here and self testing - specific to HL-2140)
  • Open the front cover and leave open.
  • Turn the printer off.
  • Hold the "white button" while turning the printer on. (All panel lights should be on.)
  • Release the "white button".
  • Press the "white button" 2 times (Pause, wait for all lights to come on.)
  • Press the "white button" 5 times. (All lights to come on again, then go out.)
  • Cancel "maintenance driver" install, if prompted
  • Close cover.
  • Power cycle printer.
This will:
  • reset the toner light (stop blinking)
  • restore the printing darkness (when toner light flashes, printer prints lighter to save toner)
  • keeps the printed page counts and drum life info
on Mar 06, 2011 | Brother HL 2140 Laser Printer
If im going to print my document the selection for printer HL - 2140 series 2 was lost and replace by the printer generic how can I reset the printer bask to HL - 2140 inorder to activate?
Brother HL - 2140 Drivers
Visit the above link from Brother Official Support. Select the Operating System and download the drivers. After in stalling the drivers, go to the Control Pannel - Printers, and set HL-2140 as default printer.
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
Jan 24, 2011 | Office Equipment & Supplies
I recently installed the Brother HL-2140 to my computer, everything came through, but I am not able to print. Rose
Set your new HL-2140 as the default printer. Go to Control Panel, Click Printers and Scanners tab, and set your Brother HL-2140 as your default printer. You may have other printer as the default printer currently. Check your connections again. Connect it to another USB port as the current port might not be responding due to connection contact problem.
Oct 05, 2010 | Brother HL 2140 Laser Printer
How can I check the count of pages printed in my brother hl-2140 printer ?
Turn the printer off then on, wait a few secondes then press the GO button 3 times quickly.
The printer settings will print. It will show you how many pages have been printed as well as number of paper jams and errors etc.
Jun 11, 2010 | Brother HL 2140 Laser Printer
Printer not printing documents HL-2140 model
when the toner light is on this means the toner cartridge is empty and ned to be replaced. After its replaced it will start working normally again.
Jun 02, 2010 | Brother HL 2140 Laser Printer
HL 2140 does not print
This is a common problem to your brother printer model 2140. You need to turn off your printer and take out the toner. Look for the side and you will see a small hole on both sides. This is the sensor. You need to cover it with electrical tape.
Here is a detailed video on how to do it:
http://www.youtube.com/watch?v=hPCGZZIdXyM
Good luck and hope this helps you.
Sep 30, 2009 | Brother HL 2140 Laser Printer
Brother 2140 Printer Problem
It is most likly not linked to word. Word is likly sending the prints to the wrong, obsloete or wrong copy of the printer.
When printing check to see where the doc is being sent to print.
Then go to printers to see which printer is your 2140 active and ofcourse do a test print. If the test print is good this is the correct link to your printer.
Dec 19, 2008 | Brother HL 2140 Laser Printer
Blank paper
Make sure you are letting it warm up long enough.
Brother HL-2140 Support
Jun 16, 2008 | Brother HL 2140 Laser Printer
Brother HL 2140 Laser Printer Logo
325 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
