Question about HP DesignJet 90 - printer - color - ink-jet InkJet
Document failed to print
Os winxp sp2 / sp3 plotter hpdesignjet 500 plotter driver v6.07 data file version 2.1
connected by usb cable, print only one at start only 2 lines and message display " document faild to print " the same plotter if connected to other laptop prints successfully have tried formateed the machine, and installed drivers freshely with licence quick heal pack updated went through scan and then installed drivers of plotter, printer for a day, and started to display the message, the problem is with 2 of my desktop machine
  • 112 Answers
Http://www.hp.com/#Support
Follow the link and get the correct driver and get installed
Posted on Jan 19, 2010
Skype kernel32
Skype v6.6.0.106 is the last version which supports XP SP2. If you try install newer version, you will need SP3 installed, or you will get the kernel32 problem "Failed to get proc adress for getLogicalProcessorInformation (KERNEL32.Dll)".
If you don't want to install SP3 for your XP, here is a work around for you to run Skype with XP SP2.
1. Download Skypesetupfull.exe v6.3.30.105;
2. Uninstall your current version of Skype from Control Panel;
3. Block the website download.skype.com in your router or in the
Host file;
4. Delete any auto downloaded skypesetup.msi in %Temp%
folder;
5. Install Skype v6.3.30.105.
Done.
Aug 04, 2013 | Microsoft Windows XP Professional SP2
I have a Assembled Computer with Processor Intel Dual Core (R) @ 270 GHz, 3 GB of RAM equipped with Microsoft Windows XP Professional Edition version 2005 service Pack 3 with Wi-Fi Netgear 108 Mbps Lan...
yah you must buy a Y-USB cable for your external hardisk. this is connection both ends are one is for hardisk and the other two cable is for USB slot of computer. why it two wires connection to usb because one wire is for Data and the other is for Power. If doesn't work..it might be a problem in your Operating system. i recommend to you to reinstall your Windows OS.. theres a 4 reasons why it happen appear the error... deffective USB cable..corrupted driver of USB device for seagate, virus infected of your systems..and maybe your hardive is deffective. Please rate if this is HELPFUL..thanks
Aug 22, 2010 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
Network Printing Issue. I'm running 2008 Domain Controller 2003 File and Print Server. Cisco 3560G switches No 3rd Party print management software User workstations are all Windows Xp Pro SP2 Printers are...
DNS errors then? can you map to the printer via hostname too? Are you sure you're not using SP3? When we upgraded to SP3, we had to use the new drivers. Try new drivers.Have you tried just rebuilding your print server? try sharing the printer off your computer in the data center and try t print to that. When you ping the data center from the user's computer... what is the delay?
Oct 13, 2009 | HP LaserJet 4250n Printer
If i restore my dell inspiron 9400 to its original factory settings will it delete XP updated files received over the past couple of years and will it affect my security McAffe that i subscibe to?
Yes it will. I suggest that you download Windows XP SP2, and Windows XP SP3 and save to an external USB key or burn to a CD-R. If you save the downloads to your HD, restoring to factory settings will most likely overwrtite your HD. So with that. I also suggest that you backup all your personal data, such as documents, pictures, favorite, email contact list, emal messages, and any other personal data that you will need.
Once you have finished the restore to factory process, place the USB key or CD-R in the slots/drive, and install SP2 first, check no restart button, then install SP3. Reboot and now do your Windows Updates.
The reason I suggest sp2, then sp3 before running Windows update, is to save you time getting your unit back in production. If you did a Windows update after the restore to factory process, you would most likely be prompted to download and install SP2, then all the patches and updates would follow fro sp2. This way sp2 updates sp1, then sp3 updates sp2, and finally the updates and security patches for sp3 are all you need.
McAfee - Again download the software to a USB key or CD-R. Before you start the restore, open McAfee, select help, about, and print out or write down your subscription key. You will need these when you reinstall McAfee on your restored unit.
Hope this helps.............
God Bless !!!!!!!
Sep 14, 2009 | Computers & Internet
I cannot save a docx to my hard drive, i get file error occurred i'm running winxp pro sp3, officepro 2007 sp2
check your operating system, or try to re install the os if the sam problem, file corrupted. try to open it then save as..
Sep 06, 2009 | Microsoft Office Word 2007 Full Version...
When i'm going to print an autocad 2009 document to the hp 500 printer with jis b0 format and biger the spooler of the printer crashes and doesnt print
If you are using Windows Vista OS, then you know that you do not have the complete drivers that should make all the features of the plotter work ok. It is recommended that you go for XP or 2000. That way, better results including fonts are achieved. Remember also that this model is old and may not really work very well with all the features in Autocad 2009 Version. You can try the plotter on a machine running on 2007 version. Good luck
Apr 29, 2009 | HP DesignJet 500ps (42 in.) InkJet Printer
Cell phone (LG KP199) to PC (Win XP) USB data transfer problem
When you connect your phone to the PC, it shows two options for connecting: Mass Storage and Cell phone. Select mass storage.
For connecting in Cell phone mode you need to have the PC Suite for this model which as on date is not available.
You can use any third party softwares like mobimb, Mobtime Cellphone manager etc. for connecting to PC.
Dec 30, 2008 | LG KP200 Cellular Phone
Windows xp service pack 2 - windows xp service pack 3
uninstall sp3,
take hdd to another machine,
recover the files and programes you want to save,
back them up on disk,ie,external drive or dvd data stores 4.7b gb per disk,
format start again and only load xp sp2.
Xp sp3 has bug fixes apparantly,lol
why fix some thing if its not broken I say.
Jul 13, 2008 | Toshiba Satellite A100-S8111TD Notebook
HI I HAVE JUST REPLACED THE INK IN MY CANON MP 760 PRINTER. ON THE PRINTER ITSELF HOWEVER, AFTER OPENING A DOCUMENT (WORD) TO PRINT, IT FAILS TO PRINT. THE PAPER IS STILL FED TROUGH AS THOUGH IT IS...
Check that is defined as default printer in 'installed printer' in Windows, and that you are not sending documents in printout to another non connected printer present in Windows under 'installed printers'.
Unplug completely computer from power socket and from USB for 10 minutes, to get rid of electrostatic problems on USB. Plug everything back and restart.
Check the USB cable, replace USB cable with a different one to check if it was the cable.
Uninstall printer from 'installed printers' in Windows (delete). Disconnect printer from USB, reinstall printer from printer software CD or downloaded driver. Connect printer to usb only after installing, or when explicitly required by software, this is important
Here is link to driver download, put your windows version in select OS box.
Apr 23, 2008 | Office Equipment & Supplies
HP DesignJet 90 - printer - color - ink-jet InkJet Logo
224 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
