Question about Dell Inspiron E1505 Notebook
TCP/IP network transport not installed
I am connected to the internet but websites are not being displayed.
  • 3 more comments
  • maroonx Jan 06, 2009
    I have not idea what run ping yahoo means. What do I do? I typed in in the address bar and nothing. firewall and antivirus firewall all turned off.
    absolutely nothing. websites cannot be displayed. I can tell that I have a connection by the strong signal showing in the icon in the taskbar.
    how to i get to network places first?
    I am getting a message the TCP/IP network transport is not installed.
  • niketatum Feb 05, 2009
    Have a strong signal. Computer is displaying this page cannot be displayed
    Genius:
  • 1,913 Answers
First type in run "ping yahoo.com -t"
if u get reply then your internet is ok.
check windows firewall or antivirus firewall.turn off.the frewall.
Posted on Jan 06, 2009
  • 1 more comment
  • kishor khatri
    kishor khatri Jan 06, 2009
    go to start menu u see run
  • kishor khatri
    hello please rate this again i give u right technical advice. ok
    go to my network places then right clik it .then u see lan card properites.
    then add protocol tcp ip.thats it.
  • kishor khatri
How to turn on a dhcp on a rca model dcm425 cable modem?
Enabling DHCP at the Client To enable the Windows NT DHCP client, you must log on as administrator at the Windows NT client.
Normally, you enable DHCP as part of the installation procedure for Microsoft TCP/IP, however, you can use this procedure if you have manually configured TCP/IP:
  1. Run Control Panel and choose Network.
    The Network Settings dialog box appears.
  2. Under Installed Network Software, select TCP/IP Protocol and then choose configure.
    The TCP/IP configuration dialog box appears.
  3. Select Enable Automatic DHCP Configuration.
    A Microsoft (MS) TCP/IP message appears, indicating that the DHCP Protocol attempts to configure the server automatically during system initialization.
  4. Choose Yes.
    A MS TCP/IP Configuration dialog box appears, displaying current TCP/IP configuration parameters. The IP Address and Subnet Mask boxes are not available (grayed out) and the manually configured values are no longer displayed.
  5. Choose OK to return to the Network Settings dialog box.
  6. Choose OK again.
  7. Shut down and restart the computer.
To enable DHCP on a Windows for Workgroups client if TCP/IP is not installed yet:
  1. Use Network Setup to install the MS TCP/IP-32 3.11 protocol.
  2. In the MS TCP/IP Configuration dialog box, select the Enable Automatic DHCP Configuration check box, and choose Continue.
  3. Restart the computer to initialize TCP/IP using DHCP.
To enable DHCP on a Windows for Workgroups client if TCP/IP is installed:
  1. To access the Network Drivers dialog box, run Network Setup.
  2. Select Microsoft TCP/IP-32 3.11, and then choose Setup.
  3. In the MS TCP/IP Configuration dialog box, select the Enable Automatic DHCP Configuration check box, and choose continue.
    A message box appears indicating that the configuration of DHCP overrides any values established locally.
  4. Choose Yes.
  5. To initialize TCP/IP using DHCP information, restart the computer.
Dec 19, 2010 | RCA Computers & Internet
My IE 8 will not open any web sites
Is your Network Connections working properly?
If your networking adapters are functioning OK, try this,
Open IE
Tools tab > Internet Options > restore Adanced Settings and Reset Internet Explorer settings.
Restart IE.
Other options are:
1) Uninstall the Network adapter
Open Device Manager > Expand Network Adapter > Right Click on your internet network adapter and Uninstall
Reboot
If it doesn't work, try it again and then reinstall the driver. You may have to get the new driver from the device website.
2) Winsock and Tcp/Ip Fix
Start > Run > Type CMD > Type the following:
Reset TCP/IP stack to installation defaults,
type: netsh int ip reset reset.log and Press Enter
Reset WINSOCK entries to installation defaults,
type: netsh winsock reset catalog and Press Enter
3) Run sfc /scannow (This will restore your system files back to original state)
Insert your XP disc
sfc /scannow
Hope it helps.
Jul 15, 2010 | Microsoft Internet Explorer 8
Just install XP PRO sp3 on P4C800 board and current version of 3Com 3C940 onboard LAN. Installation went fine but LAN can not acquired network address and get no or limited connection.Therefore internet...
When your using Internet connection via LAN you need to configure the Internet Protocol (TCP/IP) Properties at the Network Connection Wizard. To configure the Network Connection just follow this steps:
1. Double click the My Computer from your desktop/screen.
2. At the left side of the My Computer menu click the My Network Places then click View Network Connections in the left side of that window also.
3. Double click the Local Area Connection and click Properties.
4. When the Local Area Connection Properties was appear select Internet Protocol (TCP/IP) then click Properties.
5. The Internet Protocol (TCP/IP) Properties are also apear, then click Use the following IP address and fill-up the following: IP Address, Subnet Mask, Default Gateway, Preferred DNS Server and Alternate DNS Server.
6. After all you fill-up click OK Button.
Note: Make sure that the IP Address you fill-up in your network connection are not the same with the other computer to avoid conflict. Just copy the configuration on the computer like: Subnet Mask, Default Gateway, Preferred DNS Server and Alternate DNS Server. Only the IP Address are unique to the other computer. Example; 192.168.0.5 that is the IP Address of last computer are connected in the network. The IP Address you able to use is 192.168.0.6, only the last digit of the IP Address your going to change.
Jun 04, 2010 | ASUS P4C800 Deluxe Motherboard
I cannot pick up a internet connection
Click on Start - Control Panel - then Network Connections - then right click on your Wireless Network connection - click on Properties.
Then in "This connection uses the following items, scroll down to Internet Protocol (TCP/IP) and click on Properties. Under the General Tab make sure Obtain an IP address automatically and Obtain DNS server address automatically are selected. Click OK.
If you do not see TCP/IP in the Wireless Network Connection then click on the install button and then install the TCP/IP driver.
IF TCP/IP is OK then before you do the following, turn off or disconnect the power to your wireless router, wait for 1 minute before connecting the power again. Wait till the LED lights indicate that it is on line again and the wireless is on then :-
Click on Start - Control Panel - then Network Connections - then right click on your Wireless Network connection - click on View Available Wireless Networks
Do you see your wireless network (ie. your wireless router)?
If so click on your wireless router and then click Connect.
You can also click on Repair to try to reconnect to your wireless router.
Let me know if it works.
Feb 28, 2009 | HP Computers & Internet
No connection to internet
It appears that either the wireless driver is not installed or not configured on your laptop. If you have already installed the wireless driver then :-
Feb 27, 2009 | Evesham Computers & Internet
I'm not able to connect on my windows XP desktop through my HTC P3400i set. I have loaded ACTIVE SYNC through CD provided with set. Comp displays following msg on connection; " TCP/IP network...
You may need to check your firewall settings and check the box to allow your new program access through the firewall. Check your connections under START, SHOW ALL CONNECTIONS and make sure the TCP/IP client is installed for your device. If it is, use DHCP for IP address handling by going to the LOCAL AREA CONNECTION PROPERTIES and under the INTERNET PROTOCAL (TCP/IP) client, click PROPERTIES and check the OBTAIN IP ADDRESS AUTOMATICALLY. If you have IP and DNS addresses in the boxes, write them down to re-enter if you need to.
Feb 16, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Webpages are not being displayed
It is not a problem with your wireless, it is a problem with your Windows installation. Here are two things to try...
1. Run some sort of registry repair program. - Glary Utilities is a good free one, CCleaner is free and does reg stuff.
2. To reinstall TCP/IP, you can Remove your Network Card in the device manager, then reboot your computer. When it reboots, it will redetect the NIC and install the drivers, including the TCP/IP transport protocol. I very recently dealt with this problem, and the registry repairs fixed it.
Keep me posted...
Jan 06, 2009 | Dell Inspiron E1505 Notebook
I wanna talk about ip and sock
Hi! How are you? okay, Internet Protocol (IP) is the primary network protocol used on the Internet, developed in the 1970s. On the Internet and many other networks, IP is often used together with the Transport Control Protocol (TCP) and referred to interchangeably as TCP/IP.
Dec 23, 2008 | Computers & Internet
Can;t use intent on mobile
Here is what you should do step by step:
I.Configure your Computer
1.Install Bluetooth Adapter
2. Bluetooth Configuration->Local Services-> Add Serial Services ->Bluetooth Serial Port->Properties
Check – Startup Automatically
Check – Secure Connection
COM Port: COMx( mine is COM6)
3.Control Panel -> Phone and Modem Options->Modems->Add-> Check Don’t detect my modem->Next->(Standard Modem Types)->Communication cable between two computers->Next-> on witch port do you want to install it ? -> Selected ports -> COMx ( in my case COM6)->Next->Finished
Now in phone and modem options->Modems you should have : Communications cable between two computers : Attached to : COMx ( COM6 my case)
Select Communications cable between two computers -> Properties->Modem-> Maximum Port Speed : 115200 -> ok ->ok.
4.Control Panel ->Network Connections ->Create a new connection-> Next->Set up an advanced Connection-> Next-> Accept incoming connections->Next-> Check : Communications cable between two computers ->Next-> Check: Do not allow virtual private connections->next->next->select: Internet Protocol(TCP/IP)->Properties:
Network access : Check Allow callers to access my local area network
TCP/IP address assignment : Specify TCP/IP addresses:
To: 192.168.0.y (y=52 in my case)
->OK->Next->Finish
5.Network Connections
Bluetooth Network -> Enable
Internet Connection ( your internet connection ) -> properties->Advanced->Check:Allow other network users to connect trought this computer’s Internet Connection->OK
If all goes well : Bluetooth Network-> Properties-> Internet Protocol ( TCP/IP)->Properties Should have the following setting:
Checked Use the followind IP address:
IP address: 192.168.0.1
Subnet mask: 255.255.255.0
->OK.
6.Start->Control Panel->Administrative Tools->Services->Routing and remote access->Properties->General: Startup type : Automatic - this service MUST be started
**7.Install AnalogX Proxy http://www.analogx.com:80/files/proxyi.exe (for the latest version)
Proxy->Configure-> Proxy Binding: 192.168.0.x ( for me x=50 )->ok.
! If you use a proxy, remember to start it .
II. Configure Phone:
1.Install GnuBox - http://gnubox.dnsalias.org/gnubox/ ( for the latest version)
2.Configure Access point
Tool->Settings->Connection->Accces Points-> New Access point->Use Default Settings
Connection name: Bt
Data Bearer: Packet data
Access point name : Bt
User name: none
Promt Password: NO
Password: ****
Authentication: Secure
Homepage: none
Option->Advanced settings
Network Type: IPv4
Phone IP address: Automatic
Name Servers: Automatic
**Proxy serv. Address: 192.168.0.x ( for me x=50)
**Proxy port number: 6588
3.Configure all the applications from your phone witch require internet acces to use Bt Access Point
4.Configure GnuBox
Options->Install Set to GPRS
Options->Install Create Records
Options->Install->Copy settings from GPRS
Options->Install->set RAS login script
Exit GnuBox
Open Gnubox
Options->2box Bluetooth->Serial Port
Select – your computer
Do you want to require encryption? Yes
Options-> Install->change default AP
** Configure NetFront
Options->Settings->Connection
Enable Proxy : Yes
Proxy Host : 192.168.0.x ( in my case x=50)
Now you can browse the internet from your phone.
NOTE: First Configure the phone and your pc without the ** settings, and if you can’t browse the Internet form your phone then use the ** settings.
Hope this works fine.Thank you.
Nov 25, 2008 | Computers & Internet
Internet connectivity
Symptoms: After you run Microsoft Windows AntiSpyware (Beta) or other anti-virus/spyware/adware software, 1) you may receive one or more of the following interactive error messages:
Could not start the Windows Firewall/Internet Connection Sharing (ICS) service on Local Computer. Error 10047: An address incompatible with the requested protocol was used.
or
Windows Firewall settings cannot be displayed because the associated service is not running. Do you want to start the Windows Firewall/Internet Connection Sharing (ICS) service?
or
This application has failed to start because SPORDER.dll was not found.
2) Third-party networking products may not function correctly.
3) Computers may not be able to connect to the network because they cannot obtain an IP address.
4) You may receive the following error message when you are using Microsoft Internet Explorer:
Error 404: Page cannot be displayed.
Cause:
There are known spyware programs that install layered service providers (LSPs) on client computers to gather user data. When Windows AntiSpyware (Beta) removes spyware programs, it also removes the spyware-based LSPs. However, Windows AntiSpyware (Beta) does not restore any LSPs after it removes the spyware.
Resolutions:
How to rebuild the Winsock LSP chain on Windows XP SP2
How to rebuild the Winsock LSP chain on Windows XP, XP SP1, and Windows 2000 __________________
Bob Lin, MS-MVP, MCSE & CNE
How to Setup Windows, Network, VPN & Remote Access on http://www.HowToNetworking.com
Networking, Internet, Routing, VPN Troubleshooting on http://www.ChicagoTech.net
Oct 17, 2008 | HP PAVILION A6230N DESKTOP PC
Dell Inspiron E1505 Notebook Logo
88 people viewed this question
Alun Cox
