Question about Compaq Presario 5000 PC Desktop
Compaq pc intel core 2 duo
Compaq sr5000 pc is the modle i do not know the motherboard number
it was working ok till i changed the case it turns on there is no bleeps
when i connect the monita the monita goes in to standby
  • 289 Answers
Also to lotek idea, look at the motherboard manual and see if you plugged in the case correctly.
Posted on Sep 27, 2009
  • 233 Answers
So you put your old hardware into a new case? If it worked before it should work now unless you added some hardware. The first thing I would do is check all connections, cables. cords etc. Make sure everything is secure and connected properly. Make sure all PCI, AGP etc cards are seated tightly in their slots. Also double check that the wires from the face plate to the motherboard are connected properly. In other words go back and check everything you touched when doing the switch between cases. Hopefully you will find something loose or not connected properly that is causing this problem. Also did you change power supplies using the one that may have come with case. Check that too. Once I connected the power button to the re-set pins on the motherboard. Every time I pressed the power button it wanted to restart. So it could be something that simple.
Posted on Jan 08, 2009
I need to change the Motherboard (ERC410M) CPU of mi "ACER Power F%" PC fron "Intel Pentium 4" to "Intel Core 2 Duo" is it possible and how to do it?
It's highly unlikely that a P4 Mobo can take a core 2 Duo as far as I know, P4 are just single core.
Need to check what socket the MOBO has, and what socket the new CPU has - if they don't match it won't work! I'm surprised that it even fits...
Oct 11, 2014 | Computers & Internet
I want know intel d 945gcr supports quied core processor or core 2 duo processor?
Support for the following:
Intel Core 2 Duo processor in an LGA775 socket with a 800 MHz system bus
Intel Pentium D processor in an LGA775 socket with an 800 or 533 MHz system bus
Intel Pentium 4 processor in an LGA775 socket with an 800 or 533 MHz system bus
Intel Celeron D processor in an LGA775 socket with a 533 MHz system bus
Aug 14, 2014 | Computers & Internet
Intel E6750 compatible?
Motherboard supports the following processor upgrades:
  • Intel Core 2 Quad (Y) Q9xxxx
  • Intel Core 2 Duo (W) E8xxx
  • Intel Core 2 Quad (K) up to Q6600
  • Core 2 Duo E6x00 (C) up to E6700
  • Core 2 Duo E4x00 (C) up to E4400
May 13, 2014 | HP Pavilion a6838f Desktop PC
What processor can i use with 446476-001 system board
The HP 446476-001 laptop motherboard, or also stated as HP motherboard used for the HP Pavilion dv6000 series of Notebook PC's;
A) Has an Intel 965PM motherboard chipset,
Has a;
B) Socket P processor socket, for Intel processors
Using this information you know;
1) That the Intel PM965 motherboard chipset supports
Intel Core 2 Duo processors,
with either a 533MegaHertz Front Side Bus, or a 667MHz FSB, or an 800MHz FSB.
The motherboard chipset is the Northbridge, and Southbridge chip, for YOUR motherboard technology.
(Does not apply to motherboards that support the Intel Core i3, Core i5, Core i7, and Core i9 processors)
The Northbridge part number is Intel 82965PM.
You won't see this part number on a chipset, because the Northbridge chip is under a small finned heatsink.
The Southbridge chip is an Intel ICH8-M
Part number is 82801HM. This you should see on a chipset ]
2) That the processor socket is a Socket P.
So you need an Intel Core2 Duo processor, with either a 533MHz, or 667MHz, or 800MHz FSB, and fits in a Socket P processor socket.
For additional questions please post in a Comment.
(You may, or may not need a BIOS update )
Feb 18, 2012 | Computers & Internet
My notebook is Compaq Presario V3646TU, motherboard manufacturer: wistron Model: CD30 Version number: 80.52 Pristine CPU is T7250 My question: change CPU to T8300 or T9300,...
why do this, there is no benefit, (that you will see)
only HP can answer this, they now own Compaq,
no story told, buy a ***** motherboard
or just want to throw money on this old PC 2007 PC
10 years old now.
2 things must match the other chips, north and south bridge
and BIOS to change CPU.
the formore, HP fails to document clearly.
the BIOS changes lists on the HP site (we are not hp)
last F13.
Adds support for Intel Pentium Dual Core Mobile T2310 and T2330 Processors.
Adds support for the new generation of Intel Core 2 Processor Family CPUs.
your cpu aboe is gen 8 an 9
last one certified for this pc is G7
the fastest on certified was
intel Core 2 Duo processor T7500 - 2.20GHz (Merom, 800MHz front side bus, 2MB Level-2 cache per core, 65 nm process technology)
i will attempt to show the HP parts surfer data nexe.
click processor here.
you never posted your PC, service tag so answers will be weak.
the p/n was not posted by you, like GJ831AV
or the the other 40 models seen here.
why not ask HP and not fixya, HP is real....
the real deal here. HP
Oct 21, 2017 | HP (302203-001) Motherboard
Can i change my computer processor?
it all depends if your motherboard is compatible with core duo processors, usualy they are. but to find out for sure you need to obtain the model number of your motherboard or the manual and find out what it can take.
a tool called Everest, can scan your computer and tell you the model number and the website for more information.
you can download everest free edition on major geek website
Jul 28, 2009 | Computers & Internet
I carnt work out what size chip to put on the p5s-mx se Socket LGA775 motherboard
Ok no problem I can help you there. First you want Intel or AMD. I would take Intel. Then you want Core Duo or Core 2 Duo, I'd take Intel Core 2 Duo, then you need to find out the Frontside Bus Speed of your motherboard, it has to match the CPU. So let's say its 1,066MHz. And you want something faster than 1.8 so go with 2.4GHz. So now we looking for a Intel Core 2 Duo, 2.4GHz, 1066MHz bus speed with stock cooler. So then go to, in their search box type "Intel Core 2 Duo 2.4Ghz" and it will bring up all the CPU's and their prices..if you have any questions let me know. Pls rate this solution.
May 11, 2009 | ASUS motherboard P5S-MX SE LGA775 SiS671FX...
IBM ThinkPad R40 Intel Centrino Upgrade to Intel Core 2 Duo?
According to system specs your system is not compatible with the Core 2 Duo or Centrino Core 2 Duo. To upgrade to those chips you would need to replace the motherboard with one capable of running those chips. If you decided to do that you would almost surely need new RAM as newer boards use newer technology. By the time you did this the upgrade would not be cost effective. Hope this helps & please remember to rate my answer. Thanks.
Feb 03, 2009 | IBM ThinkPad R40 2722 Notebook
Iam useing asus M2N-MXSE PLUS Motherboard with AMD Athlon x2 Processor but now i want to change my processor with replaying it whih Intel core 2 duo. is that mother board support it or not. pc for...
Your motherboard is for a AMD processor not Intel. You need a motherboard for a Intel processor before you can proceed.They are so different. Core Duo chips don't even use pins.
Dec 20, 2008 | Intel Biostar P4TSE-D2 865 Chipset...
Compaq Presario 5000 PC Desktop Logo
88 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
