Question about Philips 55PL9773 55" Rear Projection Television
My television Model 55PL9773/17 shut off?
I'vd had this televsion for 4 years never had a problem. The television turns on and the imagine starts to show, when it immediately turns off by itself. I have tried to unplug the television and turn it back on but it does the same thing. What do you think the problem is?
  • 1,249 Answers
Probably a bad lamp. The lamp is the number one cause of failure for this set. The good news is that these lamps are user-replaceable. Just open the sliding door on the back of the set and unscrew the two thumbscrews that hold the lamp into the light engine (the big black plastic assembly). Then pull the lamp out by its handle (the silver clip). look into the side where light is supposed to shine out to see the actual lamp. If it is not shiny and clear, it's probably no good. These lamps are literally available everywhere you go to get tv repairs done. Most shops can even test your old lamp if its condition is questionable. Average price is $150US and is most likely the cheapest repair you can have done to these sets. Just put a new lamp back in, reset the on-screen user menu, and you're good to go for another 5000 hours.
If the lamp is ok, I would recommend having an authorized service center take a look at the set. Since this set originally sold for around $3000US, it's most likely worth repairing. That decision is totally up to you, but a new comparable set will run you around the same price, and flat-panel tv's are much less reliable than the one you have already. Imagine hanging a picture window on your wall, with fluorescent lights behind it. How fragile is that???
I recommend authorized service centers because they generally have more expertise in repairing newer equipment like this set and can repair to component level. This saves you time and money, since you don't have to wait for the repair shop to order a whole circuit card (example) rather than just replace a chip and a few (cheap) small parts (which they stock). End result: you pay $200 less and get your tv back in three days instead of three weeks. That is, if they don't fix it in your home the same day. Either way, an estimate is cheap compared to the price of this set and can usually be done in a day or so.
Posted on Mar 17, 2009
I've had this problem too. But I've had bad lamps before, and they don't shut the whole TV down. Besides, we just replace the lamp 6 months ago. Before that, it went 2 years without a replacement. What could it be besides a lamp?
Posted on Jul 24, 2009
Why is my television turning on and off?
Some TV's have a sleep timer on them. Check to see where it is set at with your remote. If it is set at a certain time, you can shut it all the way off.
Jun 17, 2015 | Televison & Video
My televsion turns off after 10 minutes by itself and it takes a few minutes to turn back on. Its a westinghouse 2005 model LTV-32w1
Sounds like either the Power supply unit or heat related problem. if you keen to take it apart you could check the power supply to see if there is anything obvious in terms of signs of over heating.
May 11, 2011 | Televison & Video
I have a tv/dvd flatscreen televsion. It is only a year old. The problem is I can not hear anything. My television is displaying the screen and movies/television is working fine, just no volume. Please...
Does the the little bar graph on screen volume display react when you turn the volume up and down or does it say something like TV VOLUME IS FIXED?
Try using your remote to look in your tv's MENU for the AUDIO OPTIONS.
Check to make sure the SPEAKER option is turned ON.
If that doesnt work, try running a cable from your tv's audio out jacks in the back to one of your home stereo's AUX inputs and see if you can hear the tv through your stereo.
Good Luck.
Jan 20, 2011 | Televison & Video
Have inherited RCA television with AV input on back, but remote and using buttons on TV allow only channels 4 and 7 to be be seen. How do you make televsion recognize AV input from back? RCA model F20600...
Bring up your video menu, make sure the cable/antenna mode is set correctly. Also do channel search/ auto program. If your AV is operating a DVD player etc., there should be a button to switch from TV to AV. If you are trying to input Cable/Antenna to AV jack you may have it plugged into wrong jack, it should go into 'antenna/cable in' jack. Hope this helps.
Nov 08, 2009 | Televison & Video
Protron LCD televsion has no audio
the TVs sound would not just not quit working because it is not digital. I have a TV from 1985 that still can be connected to a cable box. What I would do is get a few RCA cables and connect the satallite to the TV with the RCA cables if that does not work try hooking it up with a cable cord, if that does not work i have no idea to help you.
Apr 23, 2008 | RCA L37WD12 37 in. LCD HDTV
Powers on, screen flashes Akai screensaver and then shuts off
Take the unit into the service center - have the service center diagnosed the problem - they will order the part - but the parts are not available - DONT WAIT - The manufacturer must exchanged the unit because the the manufacturer must provide the parts for up to 5 years by law after the the tv is manufactured. Have the service center provide you with a workorder stating the television is not repairable because the parts are not available - then call 800-726-4405 - they will start hte process to exchange the televsion - LONG PROCESS to get an exchanged television
Feb 24, 2008 | Akai LCT3201TD 32 in. LCD Television
Trinitron KV-36FS13
The problem is in the standby power section. Check the fuse, R607, or burnt IC601, fuse R612 and VD relay 601 should show open. Its possible it could be the high voltage area of the power supply. You can try unplugging the set and cable and let it sit 4 to 6 hours. This is a hard reset. If it still doesn't turn on after the hard reset and the fuses and relays are fine, and you don't smell anything or see anything burnt. Then you'll need to call a TV repair man. They normal start around $150-$200 to fix the set. I hope this helps.
Jul 10, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Philips 55PL9773 55" Rear Projection Television Logo
673 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
