Question about Gateway 830GM PC Desktop
Replacing Motherboard My husband was trying to replace the motherboard on my Gateway 830GM computer. Now he can't remember where to reconnect the wires. Do you have a wiring diagram for 103390 Intel (Augsburg) 915G Motherboard No CPU R0?
    Genius:
  • 1,913 Answers
2 Suggested Answers
abhishekdubl
  • 6 Answers
SOURCE: Motherboard wiring
cba3c97.jpgthis is the diagram for 103390 Intel (Augsburg) 915G
Posted on Jan 06, 2009
Motherboard connections (to front panel)
remember the colored wire is +, the + and - should be printed very small on the board near the connectors as well as what they are example (HDLED is hard drive LED) or (PWRLED is power LED) or (PWRSW is power switch) these are examples yours may differ slightly
Jan 31, 2013 | Gateway (4000811) Motherboard
Front panel cords
1.
If your computer beeps when you start it but does not display anything on your monitor:
a. Disconnect and reconnect your monitor from your computer.
b. Verify that your monitor's power cord is connected and that your monitor is turned on.
c. If possible, connect your monitor to a different computer to make sure that your monitor works properly.
d.If your monitor works but your computer beeps and displays nothing,your video adapter has probably failed. If your computer is underwarranty, contact your computer manufacturer for support. If yourcomputer is not under warranty, and you are comfortable opening yourcomputer's case and replacing internal hardware, purchase and installa compatible replacement video adapter. Otherwise, contact a servicecenter for assistance. While replacing a part is a nuisance and may becostly, your documents, pictures, and e-mail should be safe and will beavailable when your computer is fixed.
2.
Ifyou see an error message that indicates that a keyboard is not presentor a key is stuck, turn off your computer and reconnect your keyboard.If the problem continues, replace your keyboard.
3.
Sometimesyour computer won't start because your computer is not compatible witha hardware accessory. If you have recently added a new hardwareaccessory, turn your computer off, remove the accessory, and restartyour computer.
4.
Removeall hardware accessories except your keyboard, mouse, and monitor. Ifyour computer starts successfully, shut down Windows, turn off yourcomputer, and add one hardware accessory. Then, restart your computer.If your computer fails to start, the hardware accessory you mostrecently added is causing a problem. Remove the hardware and contactthe hardware vendor for support. You can reconnect other hardwareaccessories.
5.
Youmay have a loose connector. Turn off your computer, remove allconnectors from the outside of your computer, and then carefully pushthe connectors back in. Look for stray wires, bent pins, and looselyfitting connectors.
6.
Ifyou are comfortable opening your computer's case, shut down yourcomputer, unplug the power, and open your computer’s case. Remove andreconnect all cables. Remove and reconnect all cards inside yourcomputer, including your computer’s memory chips. Reassemble yourcomputer before attempting to start it again.
7.
If your computer still doesn't start, your motherboard, processor, memory, or graphics card may have developed a problem. Contact technical supportfor further troubleshooting assistance. While failed hardware can befrustrating, your documents, pictures, and e-mail should be safe andwill be there when your computer is fixed.
arrow_px_up.gifTop of page
Sep 27, 2008 | Gateway 830GM PC Desktop
When I power up the computer, nothing is on the monitor, it is a black screen. what do you think could be wrong?
First off you should check all of your cables to ensure they are in fact connected correctly.
If they are all connected, then your video card has probably kicked itself.
If you have a video card, try taking it out and using the onboard video.
If you are just using the onboard video, then you're probably going to need to replace the entire motherboard.
Feb 24, 2011 | Gateway 830GM (RB830GM) PC Desktop
I have an 830GM and am suspicious of a hard drive crash or a motherboard failure and was wondering how to diagnose?
try replacing or swapping the hard drive with another machine and see if it happens again and on which machine if both machine's crash both MB and HD could be bad, If your machine with different HD works fine then it most likely was the HD If not then the MB might be at fault
Jan 24, 2011 | Gateway 830GM PC Desktop
I have a Gateway 830GM, I was wondering if it were possible to change the motherboard so I could put a newer CPU in it? I would like to buy a core 2 duo motherboard + CPU but I am not sure if I can do that...
Desktop computer cases have standard mounting holes and screw stand offs.
There are a huge range of motherboards available, select well known brands, my favorite are Gigabyte, Intel and MSI.
Select a motherboard with the features you require. If you are into gaming, graphics/CAD then select a motherboard that does not have a built-in graphics chip, and then you can get a high end graphics card.
Most likely you need a CPU and RAM with your new motherboard.
You may also need a newer ATX2 power supply if not then check the total power requirements of the new system, it needs to be at least 10 to 15% over the total power requirements so you don't stress the switch mode power supply.
Nov 19, 2009 | Gateway 830GM PC Desktop
Network card gateway 830gm
Well, you most likely will have to replace the network card, as you already know.
If your network connection is part of the motherboard, disable that one and plug in a new network interface card.
They are fairly plug and play....
Sep 21, 2009 | Gateway 830GM PC Desktop
Need new motherboard for Gateway 830GM
Looks like you have a p4 478 socket with ddr memory bad luck they only make 478 boards with ddr2 memory now. And when ever the power supply is as old as the motherboard it should be replaced to. Here's the specs I found on your computer http://www.shopping.com/xPF-Gateway-830GM. You could always try your luck on ebay good luck.
Jul 11, 2009 | Gateway 830GM PC Desktop
All wires are connected but still nothing comes up on the monitor
are you familiar into the parts inside.?
if not, i will not advised you t do this.
-inside you can see the memory strip/module, resit it again on the slot.
if you are using an external video card, better to resit it too.
let me know.
Feb 17, 2009 | Gateway 830GM PC Desktop
Motherboard wiring
Jan 06, 2009 | Gateway 830GM PC Desktop
Gateway 830GM PC Desktop Logo
378 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
