Question about Konica Minolta magicolor 2430 DL Laser Printer
Printer will not prine
I installed all new cartridges, now i am getting
error line 2474.
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
How do I fix Service Engine Error 181.514. INK Sense BPD Prine Error.
Have you removed the plastic covering the ink jets on a new cartridge?
Feb 21, 2015 | Lexmark OfficeEdge Pro 5500T Multifunction...
My printer has new cartridges but wont print
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Mar 17, 2010 | Epson Stylus DX6050 All-In-One InkJet...
The ink lamp flashes even though it is a new cartridge and is prining fine how can i stop it flashing
the ink lamp flashes even though it is a new cartridge and is prining fine how can i stop it flashing
Feb 27, 2010 | Canon FAX-JX200
Some of the prined lines are being cut off at the bottom
Try to realign the printhead.
  1. Make sure the printer is loaded with unused white paper.
  2. Open the printer Toolbox , and select the Printer Services tab.
  3. Click Align Printheads . The Align Printheads window opens. Click Align .
  4. The printer prints an alignment page. The lines in the patterns should appear to be straight. Click OK when the page finishes printing.
If that does not work you can try changing the ink cartridges and repeat the align process
Jan 19, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Cartridge problem
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 19, 2009 | Canon PIXMA iP1600 Printer
Error message
I am prining envelopes and got this message twice so far. I just unplugged the printer for a hard boot. Wish someone knew what generates this message though. Annoying.
Feb 16, 2008 | HP Photosmart 2610 All-In-One InkJet...
No cartridge found error
One or more ink carts aredodgy, fit gen new brother inks (x4)
On inks carts there is a flag inside them that normally floats, when it sits down due to ink level being low it blocks a photocell to stop machine from working, it needs to do this to stop any air getting in ink lines, so inks may appear to have ink in them but will not work, on some refill/aftermarket carts flag gets stuck
Oct 27, 2007 | Brother MFC-3240C All-In-One InkJet...
Konica Minolta magicolor 2430 DL Laser Printer Logo
290 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
