Question about Hotpoint Aquarius WMA42 Front Load Washer
Doorlock light keeps flashing.
Recently i have tried to use the machine, the doorlock light on the front pannel keeps flashing and wont start the wash. i replaced the lockcatch mechinisim, still no joy. i hvave also replaced the catch on the door itself and still the doorlock light keeps flashing. could you please help. thank you.
  • Anonymous Mar 13, 2014
    During a wash the time delay lights starts to flash and sometimes a time delay occurs
  • 67 Answers
Poss the interlock or the module has gone I have found that the neutral suppy on the board to the interlock can breakdown if the module has gone call an expert has these modules when new need to be configured to your machine as 1 module can serve about 10 models
Posted on Jun 25, 2007
Settings wont change
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently.
Pl rate me 'very helpful' for the free help, thanks
Jun 05, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Door lock light flashing
either doorlock faulty, Pcb faulty or door handle ****** not springy enough to engage the doorlock...
Jan 05, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
What do i do when doorlock light flashing
doorlock light flashing normally represents a door not closed. If it is closed properly, then latch needs to be replaced.
Sep 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWO3761
hi we have a whirlpool awo3761/5 when wash is selected it goes to start but then doorlock flashes a nowt happens, i have just replaced with new doorlock this morning and with fingers crossed tryed again it looked promising but doorlock started to flash again and nothing happens pls pls help
Sep 07, 2009 | Whirlpool Washing Machines
Washing machine not working
I Put A Set Of New Brushes In motor And It started
Jan 17, 2009 | Hotpoint First Edition FEW12 Front Load...
INDESIT WI101
hiya
these machines will do this if the timer dial has been moved during a cycle, they have a memory chip on the main circuit board.
they also do this if the machine has a fault with the exception that they dont stop, the doorlock light flashes and the timer just keeps clicking.
try setting the timer to a dot on the settings then switching the power on, the doorlock light will flash a few times, turn off again select program then switch back on, machine should now be reset and work ok, if not then count the flashes of the doorlock light as this indicates a fault code.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 04, 2008 | Indesit W 123 Front Load Washer
Beko 1512s problem
hiya
sounds like there is a fault on the machine, when the timer starts clicking the doorlock light will flash a number of times, you will need to count these flashes as this will give an indication of the fault.
hope this helps
please dont forget to rate this answer. thanks kj
Jul 25, 2008 | Indesit W 123 Front Load Washer
Please help , tell me why door is locked, on h 2 kenmore washer,
THANK YOU,
still nothing,
red doorlock light on, wont do anything,
I have to unplug so it will shut off,
when I plug in and hit start, red light stays on again,
Mar 28, 2008 | Kenmore 4292x Front Load Washer
Hotpoint wmm39a
IF you machine is a wma39 not a wmm39a then what has happed is that you control board is blown basically.
TO check this remove the soap draw and you will c three screws remove them... TO make removing the panel easier i would suggest removing the top as well as the front panel is wedged into it.. Then unclip the board from the panel and you will c where the big wiring plug is attached that the tracks on the board are blown.. There is no point replacing the board untill you can work out what has caused it to blow because it will blow again.. Its usually the motor or the doorlock which blows the board.. Trust me i been dealing with this type of machine for years...
Dec 08, 2007 | Hotpoint WMM39 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
541 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
