Question about Beverage-Air 44.9 cu. ft. / 1271 liter Commercial Freezer KF48
KF48 Beverage Air Freezer permently stuck on "defrost."
Three year old KF48 in good condition but will not get into "Freeze" mode.
  • l_c_moore Jan 06, 2009
    Thanks for trying. I am aware I can call the number in the service manual.
    Is there someone else who has more Commercial Freezer experience rather than consumer electronics?
  • Beverage-Air Master
  • 19,396 Answers
Unplug the fridge overnight and defrost it completely. Ensure the thermostat is properly set.
If it does not restart normal function after you plug back, then there may be a fault concerning the digital control, in that case call the number listed on the owner manual.
Posted on Jan 06, 2009
  • 1 more comment
  • Ginko
    Ginko Jan 06, 2009
    As suggested try first unplugging the frdge for a while, if it does not work, there are several possible faults, concerning the digital control board and other parts that can cause this.
    I do not have schematics for commercial units of this kind, call Beverage Air at 1-800-684-1199 from the USA or 1-864-582-8111 for areas outside of the United States
  • Ginko
    Ginko Jan 06, 2009
    Well, I have some, I only told you I do not have schematics. I guess
    there are differences in part locations between this model, and the Jenn Air, Arctic and similar that I
    have seen.
    Check my curriculum.
    By the way, since you do not appreciate my help I wont comment anymore.
    Goodbye and thanks.
  • Ginko
    Ginko Jan 06, 2009
    I will post a last comment,
    this is a three years old fridge, the compressor should still have life, but if it is failing the unit won't get on freeze mode.
    I think that also a failing thermostat can prevent the unit getting to low temperatures.
    An inefficient evap. system can also prevent the unit from entering "freeze mode".
    This seller has all the parts for Beverage Airs.
    They can also provide you with more specific advise by Email, or Phone.
    As usually, all repairs must be done by qualified personell.
    If you supply model number I can see if schematics are available.
    I hope this comment had been of some help.
    Regards.
    Genius:
  • 1,913 Answers
Press power button for 10 seconds.
also try to reset factory defaults settings.
there is reset buttonor check in menu.
u hae to reset all settings to factory defaults.
u can do it .
  • 679 Answers
Because the freeze control board might be not working.
check them by using a voltage meter.
Thanks for using FixYa.
  • rockfixya
    rockfixya Jan 07, 2009
    so, did u check the board.
Why do i have ice on the freezer coil when the heater is working on defrost mode
Sounds like a fan problem. Have you checked the fans operate when the doors close?
May 06, 2012 | Freezers
How lpw of a temp. Can this freezer reach..and and if only 0 degree could the thermostat temp control be changed out so it could reach les than 0 temperatures like negative 20 or so?
There are different models made for holding different products. Yours has a 1/3 hp compressor for above 20 degs. It may have 0 on the thermostat and may well pull down that far, but -20 would be out of it's reach. Where as it's sister model is made to freeze to below zero has a 3/4 hp compressor. Larger compressor for the lower temps.
Sep 18, 2011 | Beverage-Air 44.9 cu. ft. / 1271 liter...
Freezer is around 3 years old. When set at -17 degrees the freezer clicks very noisely, a relay operating I think. When the fast freeze button is pressed this clicking stops but the display reads -27...
In my opinion, since your going for the fast freeze mode, your freezer sets to its lowest operating temperature to fast tract the freezing process.
and about the noisy clicking sound it is probably a thermostat or relays depending on your system which starts and stop the compressor.
i think your freezer is just doing fine.
Dec 29, 2010 | Whirlpool Freezers
Freezer does not go into defrost cycle
first, check defrost timer function, then check heater functions. Is power making it to the heaters? Does the heater have continuity? How long, if at all, does it stay in defrost? Some unit have a defrost terminator, and, when it fails, it will go in and out of defrost instantly.,. Start there my friend.
Oct 03, 2010 | Carrier 44.9 cu. ft. Upright Freezer...
Why does the freezer pill down to desired temp & hold it for 4 to 5 minutes & then kick back on?this freezer is in excellent condition it is a kf48-1as. this is also a digital read out.it is an...
Hi, It really doesn't mean that there is something wrong with it, but then again even though it is only a couple of years old something may have went wrong. The control thermostat could have a problem with it as this is what senses the temperature and turn the unit off and on. I would say that if it pulls down to temp. and shuts off and back on again in that short of time, something does not sound right. Make sure that the door gaskets are in good shape and the doors seal tight. You may need to clean the condenser fan coil which is in behind unit, you will have to roll the unit out and gain excess to it. It could be located in the bottom front or even on top as this is more like the commercial units.We call this short cycling when they go on and off this often. A freon leak could also cause this. I know its only a 2006 model, but these things can happen. When they go on and off like this, they are trying to maintain the thermostat set point. Check to see if its not loosing air somewhere and the condenser coil is clean first. If it continues, get back to me and we can go from there.
Sincerely,
Shastalaker7
PS Make sure the fan is coning on in the freezer. When you open the door, it may have a door switch that shuts it off so you will have to tape it or hold it down to check the fan or fans when door is opened.
Dec 27, 2009 | Carrier Freezer Beverage Air® KF48
Beverage-Air 44.9 cu. ft. / 1271 liter Commercial Freezer KF48 Logo
522 people viewed this question
Top Beverage-Air Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
Michael Youngman
Michael Youngman
Are you a Beverage-Air Freezer Expert? Answer questions, earn points and help others
