Question about Linksys Wireless-G WRT54G Router
Can not gain entrance to seirra hoyle games throuugh router
We have tried many have opened the ports have removed the firewalls that we can we can not remove the firewall in the router can not semm to access it thanks for your asisstance GOD BLESS dennis
    Problem Solver:
  • 15 Answers
Betty, please contact me through junodr@yahoo.com, if you have messenger even better. I will have you do a couple of screen prints so I can see what your router is doing. I think I have the same router, but a "pocket" edition (small silver job). or you can call me at 906-495-1707.
Posted on Jan 13, 2009
Game won't load it is the only zynga game that will not load.
1. Check for current anti-virus before doing step below.
2.Check firewall allowances or permission to be sure game is allowed
3. Try "port forwarding
4. Check the game / verify ports need for multiplayer gaming.
5. Please forward all ports UDP/ TCP To gaming computers IP address.\
6. Log in to router and place gaming computer in to DMZ.
7. When done gaming disable the game in the DMZ.
8. You may have to uninstall game then re-install
9. Check hard drive space to see if you have ample space to load game.
10. remove any saved game to gain more storage space.
11. check the manufactures site for the game mentioned and check to see if it is compatible with your operating system and RAM ( random access memory) requirements
Feb 16, 2011 | Computers & Internet
Can t get on line on my ps3
The PS3 is plug n play and if your router is as well then it will configure the firewall automagically. However, often the older routers just don't play well together. You need to open up ports manually and configure the router and firewall separately for each game you want to play. Each game has specific TCP and UDP ports that need to be opened up to allow access. Its not a trivial exercise. You need to statically assign an I{P address to the PS3 and direct traffic from the router to the PS3 IP address for those games you want through. Each game has the details on which ports to open on the website or in the instructions. Lots of luck
Jan 13, 2011 | NetGear WGR614 Wireless Router
Playing a game called "Borderland" I can't get game to run in multiplayer mode if my Belkin N1 router is is in the circuit. If I remove the router from the circuit, multiplayer will work
you will need to do the following things
1 : Get the TCP & UDP Ports Required for the game
2 : The IP Address Of the PC
Step 1 : Open RSP by typing 192.168.2.1 on the address bar of internet explorer
Step 2 : On the Left Click on firewall
Step 3 : Leave the password blankand click Submit
Step 4 : Disable the Firewall and click Apply Changes
If it is Still not Working
On the left hand side under Firewall Click Virtual Servers
Enable the Ports that you need and assign the IP Address of the PC For the Ports and click Apply Changes
Jan 04, 2010 | Belkin (F5D5231-4) Router
Connecting xp to xbox 360 for internet. now it tells me nhat i have a strict nat setting dont know how to change.
There should be an option for AUTO settings. Make sure that is selected and it should fix your problem. If not, post here again and I'll help further.
Sep 22, 2009 | Microsoft Xbox 360 Console
Motorola router nat not open for xbox live
Configuring the Firewall for Gaming
By default, the SBG900 firewall is disabled.
If, as recommended, you enable the firewall, refer to the game’s documentation to ensure that the necessary ports are open for use by that game.
The pre-defined SBG firewall policies affect X-Box LiveTM as follows:
LOW: XBox Live data can pass through the firewall. No user action is required.
MEDIUM or HIGH: To enable X-Box Live traffic to pass, you must configure:
• Choose Custom on the Firewall > POLICY — basic Page • UDP 88:88 and UDP/TCP 3074:3074 on the Firewall > POLICY — advanced Page
Configuring Port Triggers
Because the SBG has pre-defined port triggers for games using any of the following applications, no user action is required to enable them:
• DirectX 7 and DirectX 8 • MSN Games by Zone.com • Battle.net®
For a list of games supported by Battle.net, visit http://www.battle.net.
You may need to create custom port triggers to enable other games to operate properly. If you set custom port triggers and enable the firewall, you must customize the firewall to allow traffic through those ports.
To create custom port triggers, use the Gateway > PORT TRIGGERS — custom Page.
SB900 USER GUIDE
The motorola guide has more information relating to port triggers.
If you download the pdf file, go to page 27 for Firewall settings and Page 35 for Gaming Settings..
More indepth information is there.
Hope that helps
Mike
Sep 20, 2009 | Arris SURFboard SBG900 Wireless Router...
It works fine untail I want to play Asherons Call a MS game, firewall has locked me out, how do I shut off the firewall. tyvm Ken
What you want to do is "open ports" in your firewall. This is simple if you have admin access to your router. Find the section for "port forwarding" and add ports that your game require. Typically, there is a TCP port and a UDP port. The UDP is for broadcasting type messages to/from your fellow gamers. The TCP port is usually for the game server. Check with your game instructions -- or you can probably get the answer with a google search string of "game ports Asherons Call" and I would bet it will give you exactly the settings for your router.
Here ya go (I did the google search). It appears that it only requres the UDP port. I would open all of these unless you find out more detail that you can close some ports (never leave a port open that you don't know or don't need -- it is a hackers door to your computer).
9000 UDP Asheron's Call game
9010 UDP Asheron's Call game 9011 UDP Asheron's Call game 9012 UDP Asheron's Call game 9013 UDP Asheron's Call game
Good luck.
Apr 27, 2009 | Computers & Internet
It says :"you have been disconnected from online servers"
There can be particular issues related
to playing through a router or firewall,
including sharing your internet
connection via another PC. In order to
join or host a Conflict: Global Storm
game from behind a firewall you must
open the following ports (inbound and
outbound):
UDP ports 4658, 6500, 10010,
13139, 27900
TCP ports 4658, 6667, 28910,
29900, 29901, 29920
To host a game from behind a router
with NAT (Network Address
Translation), or a firewall, you will
need to enable ‘port forwarding’ on
the following ports to route data to the
IP address of your PC;
TCP port 4658
If you continue to have problems
connecting to servers or creating
them, try bypassing your router or
firewall by connecting your PC directly
to your broadband connection.
Do not use ALT+TAB and do not enter Windows when multiplayer is running. It will kill the connection to GameSpy servers which are needed for connecting to any internet server.
Apr 26, 2009 | Eidos Interactive Conflict: Global Storm
Linksys Wireless-G WRT54G Router Logo
41 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
