Question about Whirlpool GS475LEKS Gas Kitchen Range
Whirlpool electric stove
I went to clean my oven and didn't push the door shut prior to locking it, now the door latch is in the lock position and I can't unlock it, any way of doing so?
  • 530 Answers
Did you smell plastic burning when this happened? More than likly you fried the door lock. see if you can see a bubble of melted plastic. If you do try to clean the bubble (remove it)
Posted on Jan 07, 2009
How do you use the self-cleaning ??? i lost my manual within minutes of getting....
we have a sears kenmore model and this is how we do it. remove everything from stove including the racks, close oven door, slide door lock latch to the right till it locks the door. turn knob to clean. when it is done cleaning it will turn off by itself. on some models the door latch will not slide open when done. just wait for it to cool if this is the case. it should tell on the touch pad on stove the hours that it takes to clean it. good-day !
Jan 20, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
I was cleaning my oven and one of my kids opened the doore before it was finished and then pushed the cleaning button again but did not shut the over door so the lock is up on the door and it won't shut. ...
unplug unit. remove rear cover, see if latch motor has made it to rest position. microswitch may be holding power off to latch. a slight turn may be all you need to reset latch.
hope this helps
Sep 28, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
My oven code is F5E1 , my oven was in self clean , now the door is locked
F5E1 is door latch assembly. One way that may work to unlock is to turn circuit breaker to stove off for few seconds then turn back on and door lock should activate and unlock. If not you are going to have to replace the door lock assembly.
Mar 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Door lock engaged with door open
push the clear/off button for about 3-5 seconds this should release the latch
Jan 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire oven door is open; lock is engaged so door will not close. When recommended procedure of holding oven light switch in and turning on oven clean for 20 sec is preformed, the lock moves in and...
If you can push the latch in manually, press the clear button while the button is pressed in. If that doesn't clear it:
Try disconnecting the power at the breaker to reset any electronics that might be at fault. (Make sure there are no little graphics of a lock that appear on your screen. If there are and you can't find the source, the shut down should help.
There is sometimes a separate switch aside from the light switch the is on the front of the stove front or very close to the latch itself. Considering that the oven clean will work, if there is one, it appears that is working in the in position. Look around the latch and the front of the oven for any other switches. Clean it if you find a separate control so that it can pop back out when the door is open.
Dec 25, 2009 | Frigidaire FEF336BC Electric Kitchen Range
I did a self-clean session and the oven remained locked way after it completed the cleaning. The error message on the backsplash reads E1- F5-. I am not able to open the oven. What's wrong?
I hit the cleaning button instead of the broiler and the oven lock went in mode so now it thinks it is cleaning but I can't close it and it won't shut off the cleaning mode. What can I do?
Sep 05, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
E1 F5 Error on Whirlpool Accubake Oven
The lock latch is located directly in the center upper portion of the door. It is a hook shaped latch that lock by turning downward. This lock gets stuck in this position which causes the e1 f5 error code. Locate the latch through the vent holes in the upper front of the oven door. Insert flat headed srew driver into vent hole and gently push latch up to a horizontal position & simply open door. Once unlocked, push cancel on the control panel.This will clear the error code and resolve the issue.
Apr 07, 2009 | Ovens
My self-clean Maytag electic stove (7 to 8 years old) will not clean because when you set clean on the touch pad the automatic door locking device moves to lock the door, and does pull the door in briefly,...
I fixed the problem simply by pressing the clean button when the oven was warm, not cold.
For some reason not explained in the instruction manual, the oven door safety locked properly and automatically when the oven was warm. I don't know why, but I'll take it!!
Dec 07, 2008 | Maytag Kitchen Ranges
My electric oven will not lock the door to have it self clean
The most likely problem is that the motor that drives the locking mechanism is defective.
Mar 30, 2017 | Ovens
Frigidaire---oven door locks.
On my Frigidaire electric range with flat screen front controls, when the "Clean" control was accidentally pushed and the door locked, I could not unlock the door by cutting power, by running the clean mode for 30 seconds then pushing "Clear", or by hitting any button. What opened the door was holding down the "Clear" button for 30 seconds until the range started beeping and code "F11" read on the led. This worked. Good luck with yours.
Dec 31, 2007 | Frigidaire PLEF398AC Electric Kitchen...
Whirlpool GS475LEKS Gas Kitchen Range Logo
226 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
