Question about Epson LX-300 Matrix Printer
Print in any other langauge
Sir the print is coming in other than english langauge i have tryied out to press font button and simultaniously switch on the printer it print firmware till first page and than the printer not print on next page it seems like it gets hang but it is not so. then if again i switch off and restart the printer the print given then after is again come in same foot as earlier print problem.
    Genius:
  • 2,985 Answers
Have tried the Epson - Technical support team? or try this www.fixyourownprinter.com
Posted on May 26, 2007
I just want to be able to enlarge my print size
  • Simply press and hold down the "control" key, while pressing the "plus sign" key. Be sure to keep the "control key" depressed while you press the "plus sign" key. Each repetition will enlarge the text. This can make reading small text SO much easier!
  • To return the text back to its original size (being polite to the next user), simply press, and hold down the "control" key and the "minus sign" key. Each repetition will decrease the text size
  • Log on to your computer and open the document you want to print. Click on the "Print Preview" button on the toolbar.
  • 2 Click on the "File" menu and choose "Print Preview" from the drop-down list if the "Print Preview" button is not available. The "Print Preview" function will show you exactly what the finished print will look like.
  • 3 Click the "Close" button to close the Print Preview window, then highlight the entire document and click on the "Format" menu. Choose "Font" from the drop-down list and change the font.
  • 4 Click the "Print Preview" button again to see the finished print. Continue to adjust the font size until the print looks good
  • Jun 12, 2011 | Microsoft Windows 7 Professional Upgrade...
    How to use draft mode in epson lx_300+ii printe
    Change the printer's default settings.
    Hold down the Font button and switch the printer on. The printer will print language setting
    instructions.
    Press the font button again and the printer will print instructions for changing from default settings
    Follow the instructions to change draft mode on/off.
    Jun 08, 2011 | Epson LX-300+ II Matrix Printer
    When I attempt to print the data and ready lights are on, but soon after it sounds as though it will print, the "Alarm" light appears, and printing stops.
    Go into Test Print Mode
    The printer incorporates various test print modes.
    Select the test mode you want to use following the steps below;
    (1) Turn off the power switch of the printer and check that the front cover is closed.
    (2) Turn on the power switch while holding down the control panel button. Press the button
    until the Drum LED comes on.
    The Drum LED illuminates to indicate that the printer enters into the test print mode.
    (3) If you want to execute the test print, release and then press the button again when the
    Drum LED comes on.
    or
    Push "alarm" button : The printer is restored to the factory setting and permanent fonts and macros are cleared.
    The printer returns to the ready status after
    printing.
    If it does not reset, replace the main PCB.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
    Thanks, Joe
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Feb 23, 2011 | Brother HL 1440 Laser Printer
    Red Alarm light (and all others) flashes, does not print. Closed properly. Seems to be a small amount of toner left in cartridge.
    Drum LED comes on.
    or
    printing.
    Thanks, Joe
    Feb 22, 2011 | Brother HL 1040 Laser Printer
    My dymo labelmanager 9000 will not print labels, a comment comes up saying label with arrows pointing to the left each time i press the print button. i have tried pressing the bottom feed button...
    The fix for this involves opening the unit up. The problem is the infra red LED sensor on the label exit has slightly miss-aligned giving the error. If you unscrew the two sensor boards, re-align and screw them back all will be well.
    Hope this helps.
    Jan 10, 2011 | Dymo LabelMANAGER 9000 Printer
    How to change boud rate from 19200 to 9600
    Here are the complete steps to change your LX-300 bit rate to 9600.
    1) Load a paper with the friction lever up.
    2) Hold the FONT button and switch on the printer. The printer must sense the loaded paper and must start printing some stuff. If not it rolls and tries to load the paper. In such case insert the paper again and press PAUSE button. Now the printer will print the stuff i.e) the current printer settings.
    3) After the printing finishes (the print matter will be around 25% of a 11inch page length), press LF/FF. You will find the current settings. Check the current bit rate which is indicated in the 10th line of the current settings table.
    4) Now press LF/FF which takes you to the Table B.
    5) Now you are in table B and the lights 1, 2 and pause must be Blinking, Off, Off conditions respectively.
    6) Now press the FONT button 9 times. After pressing FONT nine times, Light 1 = Blinking : Light 2 : Blinking : Pause light : ON.
    This means that you are in Bit rate menu now.
    7) Press PAUSE button.
    8) Note down this order of bit rate and the status of 1, 2 and Pause lights.
    --300 = ON-OFF-OFF
    --600 = OFF-ON-OFF
    --1200 = ON-ON-OFF
    --2400 = OFF-OFF-ON
    --4800 = ON-OFF-ON
    --9600 = OFF-ON-ON
    --19200 = ON-ON-ON
    From the current bit rate you are in now, press the FONT button a particular number of times accordingly.
    Suppose you are in 1200 bit rate currently, the lights status will be ON-ON-OFF. If you want to set to 9600 you have to press FONT button 3 times and the lights status change to OFF-ON-ON , which indicates 9600 bit rate.
    9) Now, press PAUSE button so that the settings get saved.
    10) Switch off the printer and turn it back on after 20 seconds.
    11) Switch it off again, Hold the FONT button and switch it in again.
    12) After printing finishes, press LF/FF and check the bit rate in the current settings that is printed.
    You can have the user manual for your reference.
    files.support.epson.com/pdf/lx300_/lx300_u1.pdf
    Thats' it. You're done!
    regards,
    Sabharish
    Sep 30, 2009 | Epson LX-300 Matrix Printer
    Prints in faint grey only, no real black
    dear sir.
    it's not a pritner problem. u need to chek word font's and font's colour setting but it's depand witch version u used and if every print are printed on faint grey colour yr refill cartige has a problem.. also do one thing go to pritnter setting do as grayscale. if u have any quary tell me..
    May 04, 2009 | Canon PIXMA iP1800 Printer
    Need to reset prevented maintenance code on Panasonic 7735 copier
    okay, you need to press these three keys simultaniously
    "user preset, ledger, and the number 3" you will enter the service F mode, then press 7 then the print button, then enter 22 then print then press 000 print, 000 print again and a wrench will lite up which means you just reset the maintenance counter. you then must press user preset and clear/stop key simultaniously to exit.
    Thank You,
    Mikey
    Apr 04, 2008 | Office Equipment & Supplies
    How to identify current font settings
    Try printing the menu like this -With power on press the "Shift" tand "Select" button, a red menu light will pop up on the touch panel ! than press the "Print" button on the touch panel-this will print out the current settings of your printer.
    Good luck
    Dezzi
    Sep 21, 2007 | OKI MICROLINE 520 Matrix Printer
    Epson LX-300 Matrix Printer Logo
    69 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
