Question about Microsoft Xbox 360 Console
Picture problem Dark colours seem to have alot of interference? (like an aerial not tuned in properly on a normal tv) i have tried another tv but seems to be the same any ideas?
    Scholar:
  • 30 Answers
Red ring is not the only problem with Microsoft Xbox 360. This amazing device also has some more common problems like Audio , video/Picture problem, disc read error etc. Microsoft is providing extended warranty only for red ring problem. Means you will have to spend some money to get this problem repaired also if you plan to send your xbox to Microsoft, you will have to wait for 3-4 weeks to get back your favourite Xbox. There is one more option in the form of DIY guide, this guide explains solving No Video problem with step by step instruction, so any novice can fix this problem.
Posted on Mar 07, 2009
I have a Panasonic tv model TH 42PZ80B; a Panasinic Blu-Ray dvd model DMP-BD50; a sky box (not as yet HD) and a Sony video SLV-SE 830G. I have a Satellite dish and a normal TV aerial. In the loft I have a...
You need to try and isolate the piece of equipment which is causing the problem.
You've already tried the aerial lead direct to the TV and this is OK.
Disconnect all scart leads and try the RF on its own.
Try the Aerial lead to video, then video to TV.
Try aerial direct to Sky box, then to TV.
Try just connecting the RF out from the Sky box to the TV (no aerial input), can you tune into a good channel 68 picture from the Sky box.
Then Try the VCR to the Sky box (no aerial input), see if you can tune into the VCR and Sky channel.
Hope that helps.......
Jul 10, 2008 | Televison & Video
Tv loses picture and sound intermittently for about a second
check that your aerial is in good condition and is properly installed, if you do not have a signal amplifier try fiting one, it may make a difference.
It may be that you are experiencing RF interference from a radio source, something transmitting on the frequency that your signals come in at.
I have the same problem with buses communication with thier controllers at stations, keeps cutting out my signal....A good aerial solved it
Jul 18, 2015 | LG 32LG30 32 in. LCD HDTV
Wil my tv work with out remote
There are quite a few ways to connect cable box, DVD, receiver and TV together. At a minimum---Connections between DVD and a/v receiver: For Audio, either digital coaxial, digital optical or simple RCA (CABLE ONE); If you did not use RCA you need to connect Video with either component or s-video (CABLE TWO). For connection between a/v receiver and TV: either component, s-video or RCA (CABLE THREE) You did not mention how your cable (or sattelite) box is connected. You could use same set-up as between DVD and a/v receiver for another one or two cables depending on set-up used.connecting the speaker wires of an RCA TV to an amplifier: The signal that is fed to the speakers is not designed to be fed to the line-level inputs of your amplifier. You'd need some kind of conversion and I can't tell you exactly what that would be.
Get some double-screened satellite cable and fit a female TV plug to it (or a male plug with an adapter). Connect it to RF Output 2 at the rear of your Digibox. Fit a TV plug to the other end and plug it into your TV.
Temporarily disconnect the aerial feed from the Digibox aerial socket. Switch the Digibox on to get a picture on your main TV. The Sky Digibox normally sends its signal out on UHF channel 68 so go to the second TV and tune it to 68 (or tune it till it finds the Sky picture).
Now plug the aerial cable back into the Digibox. If there is now interference on the Sky picture on the second TV (or on the terrestrial channels) your Sky signal on 68 is causing interference. Press [services] 401 [select]* and set the RF output to a different UHF channel number. You need to connect it via a Scart lead on your main TV in order to see the menu.
*In the new EPG (April 2009) it's [services] 001 [select]
Try each RF output channel number in turn (21 - 69) and retune the second TV until you get clean pictures on the terrestrial channels and the Sky channel. Also check the picture from the VCR (if connected).
This is just a brief overview. If you need a real in-depth explanation you should read the "Piping TV Around the House" Ebook by satcure.
Nov 22, 2011 | AOMNI Corporation Televison & Video
When starting TV in A.M. the picture fades and becomes dark. After about 30 minutes picture returns to normal level.
Hi
Try to play the DVD on your TV,if the picture is normal when you play it.The problem could be the signal of you aerial antenna or cable.
Thank you and good luck.
May 07, 2011 | LG 37LC7D 37 in. LCD HDTV
I have a MXT Standard definition set top box model num: MSTB202SD. When I try to auto tune it comes up database empty, can you help?
The commonest cause of this problem is tuning the set top box when the aerial lead has become disconnected or is plugged into the wrong socket (should be in the rf in or antenna socket) . As part of the normal tuning process, all previous tuning info is automatically deleted and with the aerial lead disconnected you will then end up with nothing. Make sure the lead is properly connected to the aerial and tune again.
Another possibility is to go into the main tuning menu and select return to factory condition. This will force a main reset deleting all data and you will then have to work through the whole tuning process from scratch including, setting your State, setting the tv resolution (720p, 1080i etc.) If neither of these options work, and you are certain that the box is connected to a good signal, then the box may be faulty. Good luck.
Jan 02, 2011 | Televison & Video
Getting green interference on lcd tv especially on
unplug your lvds cable going into the control pcb reconnect cable into the control pcb.if this does not work replace control pcb first,then also could be a defective panel.
Jul 15, 2009 | Televison & Video
Cannot get colour picture
check tv colour system is correct for your region, this is shown in the tuning menu, adjust if required
May 16, 2009 | Bang and Olufsen Beosound 4000 Shelf...
Sony FD Trinitron colur television KV-29LS30E
When i set the TV on it's not open but the red led lights on-off 11 times.In service manual said than the error is in 8v in jungle I.C .That means the jungle IC is off?
The 8v comes out from jungle I.C or the power supply?
THANKS
Jan 15, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Microsoft Xbox 360 Console Logo
61 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
