Question about Microsoft Xbox 360 Elite Console
HDMI problem with Xbox 360 to Dell TV
Received the xbox 360 package--60gb H/D; head set, extra controller----a few weeks ago. I have a Dell 32" HDTV, model # W3201C. When I hook up via HDMI, no signal, however, the hdmi input shows BOLD, which means it does see something connected. When I use the component cables, it works fine, when I hook up to a newer HDMI Samsung, it works fine, so it's not the XBox, or the cable. It's something with my TV. Dell is no help. the TV is over a year old and I think it's 1080i, and I believe the xbox is 1080p? Could that be the problem? I have run HD from cable to the TV, so I know the connection works, but it just won't find the xbox. I've tried to go into the TV set up to see if I can change the settings, but I I don't see where to change the resolution. Not an expert on this, but usually know enough to take care of my humble set ups. Any help is greatly appreciated.
  • makvero Jan 25, 2009
    Cam, I have the same problem with my W3201c and haven't been able to solve. I think the problem is that the HDMI version the TV supports (1-1.2 versus 1.3) is incompatible with the Xbox (versus the problem being related to resolution). I also called Dell and they don't have a clue (can't tell me what version of HDMI the TV supports). I think we're SOL on this one. The TV works with my STB, Sony Blu-Ray but not the Xbox so left that on component. Regards
  • OTIS MAN May 11, 2010
    Does HD work on the Dell with VGA cables?
    When you checked on another TV did you use the HDMI?
  • 66 Answers
Check that the wire coming from the xbox 360 elite to the tv is switched to hd, and the other end of the wire has the red and white for the sound pluged into the tv and that the red green and blue wires are pluged into the tv. also check to see if the hdmi cable to conected to the tv and xbox 360 elite.
Posted on Jan 11, 2009
Cant get it to show a picture
Could be how you have it connected and what input you have your TV on. Also, if this is a TV that is an extra DirecTv might not allow it viewable. Ok, I have a three TV setup with Dish - One controller box per TV - If this is similar, then this extra TV may not work with out some kind of work around. My living room TV is set for HDMI 1, Xbox is HDMI 2, BlueRay/DVD is HDMI 3 - So make sure your TV's feed from the source is being received.
Have a great night
Mar 26, 2016 | Emerson LC320EM9 32 in. LCD HDTV
XBOX 360
How to Connect XBOX 360
This is the back of the Xbox 360. The ports for the power cable, A/V cable, and ethernet cable are pretty easy to find. When you set up your Xbox 360, make sure it is in a well ventilated area that is free of dust. Dust and overheating are the two main causes of problems in electronics so choosing the right placement for your Xbox 360 is important.
This is the standard Xbox 360 A/V cable that comes with the premium version of the Xbox 360. The wide silver end connects to your Xbox 360 while the other end connects to your TV. The Yellow (video) cable is for standard, non-HDTV sets. You will also use the Red+White audio cables for a standard set. If you have a newer TV or an HDTV set, you can use the Red+Green+Blue video connections along with the Red+White audio connections.
This shot shows what the back of most TVs look like. If you have a standard TV, you'll only have the Yellow+Red+White connections. If you have a newer TV or HDTV, you should have the same connections that are shown in the pic. This step isn't too hard since the cables from the Xbox 360 and ports on the back of your TV are all color-coded.
If, and only if, you have an HDTV and want to use your Xbox 360 in 480p, 720p, or 1080i resolutions you have to slide a little switch over on your A/V cable. On the end of the A/V cable that connects to the Xbox 360, there is a little switch that you'll need to click over. If you do not have an HDTV, you can skip this step.
Now that you have the audio/video cables connected, the next step is to hook up the power supply. Connect the two parts as shown in the picture and then connect the "power brick" end to your Xbox 360 and the other end to a wall outlet. The big power brick needs plenty of ventilation just like the main system so try to have an open space on a shelf for it. It is not recommended that you set it on the carpet.
Once you have everything hooked up, you are ready to go. Press the large circular power button to get things started. If you have a wired controller, plug it into a USB port behind the little USB door. If you have a wireless controller, hold the silver "X" button in the middle of the controller until the upper left quadrant of the system power button as well as the ring around the "X" button on the controller light up. If it doesn't light up, press the controller connect button on the Xbox 360 as well as the connect button on the top of the controller.
If this is the first time the system has been used, you'll have to go through an onscreen setup process. This is simply setting up your player profile, choosing HDTV settings if available, and/or signing up for Xbox Live service. The system walks you through everything.
Now you are ready to play.
Sep 06, 2008 | Microsoft Xbox 360 Console
Phillips HDTV turns off when we turn the XBOX 360 on.
More than likely this is a trigger from the HDMI cable which can be disabled in the tv or xbox settings. To check, hook the xbox up to the tv with RCA cable that is supplied with the xbox and see does it turn the tv off it probably wont happen when connected like so.
Jan 08, 2015 | Philips Phillips 40 in. LCD HDTV
My xbox 360 causes my hdtv screen to crash and display colored static. It only does this on the 'optimal display' of 1680x1050. I plugged in my laptop on the hdmi and it worked perfectly. Is t
Try manually choosing lower resolutions in your xbox display settings. My Insignia HDTV does that when switching resolutions like on Hulu in between commercials and then back to the show but only for a second or so. Also does this when going from the loading screens to the game screens for a few seconds when playing the game Split/Second
Jan 10, 2013 | Microsoft Xbox 360 Console
Had the box 360 60gb for 3 weeks. Been running it via the tv scart option with yellow wire and audio red & white. Worked for 3 weeks until during playing Assassins Creed Brotherhood the screen went...
Maybe someone stepped on your cables try getting different cables.
For example if your tv is hd get a hdmi cable or buy another set of those cables.
Maybe it will help.
Jan 04, 2011 | Microsoft Xbox 360 Console
Xbox-360 wireless controller doesn't sync at all
my xbox e87a2ee.jpg joystick this spot of cable is broke and i dont know what is sequece of colours in cable?
Oct 23, 2009 | Microsoft Xbox 360 Controller
Cannont connect Ear Force X3 with my HDMI set up .
Is the problem that you're using a single HDMI cable to connect your Xbox to your TV? If so, this Turtle Beach article should help... ________________________________________
HDMI and Connecting Ear Force Xbox Headphones
The current Microsoft Xbox 360 series of gaming consoles allow the use of HDMI cables for simpler hookup to home theater systems and Hi-Definition televisions (HDTV).
The Xbox 360 Elite (the black one) comes with two additional cables, an HDMI cable and a separate AUDIO cable that provides a pair of RCA jacks (red and white) and an optical digital audio output (S/PDIF Out). With this cable package, you can easily connect any of our X-series headsets and an HDMI-connected television at the same time.
This Xbox 360 HDMI Cable package is available as an extra-cost option from Microsoft: http://www.xbox.com/en-US/hardware/x/xbox360hdmiavcable/
Here's a more in-depth explanation of the Xbox 360 HDMI Cable and how it works: http://support.microsoft.com/kb/937899?sd=xbox
[NOTE 1:] The standard Xbox models do not come equipped with this cable set. The HD cable they have obscures the HDMI connector, so that the two sockets cannot be used at the same time. If you only have this stock HD connector (component video, composite video, stereo analog audio and optical digital audio connectors), then you will not be able to use the HDMI connector at the same time.
In order to use both sockets at the same time (HDMI and A/V) you'll need to purchase the Xbox 360 HDMI Cable package described above.
[NOTE 2:] The current Xbox 360 Elite Holiday Edition (Fall 2009) does not come with the HDMI Cable set.
___________________________________________________________________
Some companies make aftermarket HDMI cables for use with the Xbox 360, but these may not provide the dual RCA jacks that carry the 2- channel analog audio necessary for hookup of the anlog-only Ear Force X-series headsets. If this is what you have, you may need to find another way to connect your Ear Force X-series headset.
The TOSLINK digitally-connected X-series headsets can be always be connected using optical digital "Toslink" connections (and that's the best way to use them!).
The oldest white-and-gray Xbox 360 models DO NOT have an HDMI port. With this particular (obsolete) model, you cannot use HDMI connections, but you can use any of our X-series headsets.
Current Xbox 360 models all have separate HDMI and A/V ports ("sockets") on their back panels.
Here are some suggestions for alternative connection schemes:
XBOX 360 AUDIO PLAYS THROUGH TELEVISION SET:
For X4 and X41: Your best bet would be to connect the Xbox optical digital audio out to the X4 transmitter's optical digital input. Then connect the X4 optical digital output to the optical digital audio input on your HDTV or home theater amplifier.
[NOTE:] Some HDTV systems have an optical digital audio output that will not transmit Dolby Digital/DTS encoded digital audio, only stereo PCM audio will be passed. In this case, you must connect as above.
For X2, X3 and X31: You can use the Headphones jack or the Audio Out jacks on your TV to connect to the Audio In jack on the Transmitter.
For X1 and X11: You can use the Headphones jack or the Audio Out jacks on your TV (if available) to connect to the headset's analog Audio Input.
NOTE: Please make sure your TV has Audio Out jacks. Some TV's only have Audio In jacks.
Audio In jacks only accept incoming audio signal; they do not send audio signal out. If no audio signal is being sent to the headset, no sound will play from the headset.
You may need to purchase a suitable adapter cable in order to connect the TV audio output(s) to the Ear Force X-series headset's transmitter or Audio Input plug.
- Connect the HDMI cable so that the Xbox 360 plays its audio through the TV.
- For X1, adjust the Dashboard > Settings > System > Voice in the Xbox 360 so that the talkback and game sounds are played together (Play Through Speakers). - For X3, X31, X4 and X41, you should set this to Play Through Headset.
XBOX 360 AUDIO PLAYS THROUGH HOME THEATER RECEIVER (except X4 and X41): This is exactly the same as the above, except that you will use the receiver's Headphones output jack to connect to the Audio In on the Ear Force Xbox-compatible headset's Transmitter (X2, X3, X31) or the green Audio Input plug (X1).
- You may need to obtain a shielded audio cable with 1/4" stereo phone plug to 1/8" stereo mini-phone plug ends. The 1/4" phone plug goes to the receiver's Headphones jack, while the 1/8" mini-phone plug goes to the Audio In on the Ear Force Transmit- ter (X2, X3, X31) or Audio Input plug (X1).
- Adjust the Dashboard > Personal Settings in the Xbox 360 so that the talkback and game sounds are played together (Play Through Both). For X3 and X31, you may also set this to Play Through Headset.
Mar 13, 2009 | Voyetra Turtle Beach Turtle Beach Ear...
Xbox 360 hdmi connection to dell W3201C no display
The W3201c IS 720P. You have to adjust the display output on the xbox 360 to 480p then adjust settings up from there...
Jan 03, 2009 | Microsoft Xbox 360 Elite Console
Xbox 360 Elite connected to Mitsubishi HDTV Model No. WD62528
Hudeez: 1. Did you check your TV Menu Settings ?? 2. Also on the XBOX 360 Menu. Go to the SYSTEM MENU (PURPLE). CONSOLE SETTINGS and select DISPLAY. Then you'll find the HDTV Settings and pick your resolution for TV Set. Done....
Jun 05, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Elite Console Logo
531 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
