Question about Philips GoGear SA3245/37 Digital Media Player
Copy mp3's into folders?
"I have the same issue. My work around is to copy MP3sinto folders and drop them on the player. Selecting the folder willthen play only the songs in that folder. Poor Person's playlist." so, how did you do this - "copy MP3sinto folders and drop them on the player."
  • 22 Answers
I'm not quite sure if you're trying to add music to folders in your player or if you're trying to play them from the folders.
If you are trying to play from folders, you need to turn the player on and on the main menu there should be a folder icon. Select that and look for the folder that contains the mp3s you wish to play.
Posted on Feb 06, 2009
I have a Coby MP620. It says to drag and drop files to the music.dir folder but I have no such folder. I have the movie, photo and text files but no music. I have no idea what to do next.
When your MP3 Player is connected to a computer, you may transfer music files to your MP3 player using your operating system's basic file management commands (i.e., copy-and-paste or drag-and-drop).Connect the Coby MP3 player to your computer through its USB adapter. Select "Open folder to view files" from the new device dialog box that pops up. If the new device dialog does not appear upon the hardware's connection, click "Start," click "My Computer" and right-click the Coby MP3 player's device icon in Windows Explorer .Click "Start," click "My Music" and open the folder containing the music you wish to transfer onto the Coby MP3 player. Drag and drop the music files or folders into the Coby MP3 player's open directory. Alternatively, you can highlight the music files or folders and click the "Copy the selected" link from the Files and Folders Tasks menu in the left column. Select the "Removable Disk" drive from the list of destinations.
Sep 16, 2011 | Coby MP620 MP3 Player
Not enough space
Hello. You will need to delete a few tracks from your MP3 player to in order to add more songs.
Simply select the songs you wish to delete, right click, and click "Delete" or "Move to Recycle Bin"
To select more than one song at a time, you can multi-select by selecting one song, holding down Ctrl on your keyboard, and selecting the others until all songs you don't want are selected.
1 Gb is rather small, coming in at about 1024 Megabytes. The average cd quality Mp3 file is around 3.5 to 5 megabytes in size.
1024 / 5 = 204.8
This means you will only be able to fit around 203 high-quality mp3s on your player at one time, and will periodically need to delete and replace them as your music library gets larger.
With these smaller capacity mp3 players, it is often handy to arrange your music library into small folders on your computer so that you can simply clear the player and drop in the contents of one folder. You can even monitor how many files are in each folder to ensure you don't run into this problem often.
I hope this was helpful. -
Frankie
May 11, 2011 | SanDisk Sansa m240 MP3 Player
How do i delete all the songs off my sansa e260?
Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders themselfs then format a couple of times hope this works
Try and drag and drop from your music folder to the media folder on the player make sure usb mode is msc this will show you all the folders Use your windows explorer for the transfer... much easier...If you don't have copies of your music copy to a folder on the computer2.gif first
Dec 20, 2010 | SanDisk Sansa e260 MP3 Player
How do you download music into the pantech c740 music player?
Before answering this, keep the following in mind about uploading files to your phone:
MP3 would be my personal choice for the phone you have. Since you are using Windows Media Player (WMP) on your PC, I assume that any music you have ripped with it would be in WMA format, or maybe WAV. WAV is compatible with your phone, but I haven't tried WMA.
Get into the folder the files for the player are stored in (usually My Music), and look at the format by right clicking and selecting properties. If the file format is not compatible with your phone, you can try changing the file extension by opening any folder, selecting tools>folder options>view, and then unclick "hide known file extensions." Then go back to the file and rename it, but only change the file extension. Example: if the file is named "music.wma", the you would change it to "music.mp3." This usually works with common audio files.
To answer your main question, the easiest way is to bypass all the media player ****, and go straight to the file folder where you music is stored in your "My Music" folder.
The following will work with a mini SD card too.
First connect your phone to your computer via a USB cable. A folder options box should come up. Choose to open the folder and explore files. It may not say exactly that, but you'll sort it out I'm sure. Find the "audio" folder inside the phone, and open it.
Then in your computer's music files, find the folder containing the music you want to put on your phone (usually "My Music"), right click the music file you want and select "copy". Go back to the folder for your phone or card, and copy the file into it. That's it.
There are many ways to copy the files with this method, but this one is the easiest to explain. You can copy entire folders to your phone, if you have enough memory. Also, ripped CD folders often contain album art, so I recommend selecting the files you want to copy, rather than the whole folder. Holding Ctrl while highlighting the files you want to copy will enable you to select multiple files and copy them all at once.
Dec 10, 2009 | Pantech Matrix Cell Phone
The tracks all say bad track and will not play, how do I fix the problem?
These tracks are corrupt Delete all Format
Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders them selfs then format a couple of times hope this works
Try and drag and drop2.gif from your music folder to the media folder on the player make sure usb mode is msc this will show you all the folders Use your windows explorer for the transfer... much easier...If you don't have copies of your music copy to a folder on the computer first
Oct 24, 2009 | SanDisk Sansa e260 MP3 Player
MUSIC.DIR FOLDER NOT SHOWING UP
Plug Coby into computer
Double-click "My Computer"
Double-click icon of Coby
Go to Tools --> Folder options --> View --> select "Show hidden files and folders"
Should be good to go.
-Tha Mp3 Doctor
Mar 22, 2009 | Coby MP-610 MP3 Player
I deleted the music folder and nt able to play the songs in mp3
When I had the same accident this is what worked for me. I disconnected my sandisk player from my computer. After waiting until the sandisk software completed it's termination programming, I re-connected it to the computer.
Because I use Microsoft Windows XP, a window pops up asking if I want to open the device in Windows Explorer. Answering "yes" and then selecting the "Folders" from the tabs at the top of the window will display the sandisk along the left column as "Sansa e250". By double clicking on the folder labeled "PPI NAND" a drop down list of subdirectory folders should be displayed. If the folder "MUSIC" is not there, you will need to create a new folder and label it "MUSIC".
Here is how to create a new folder.
With the folder "PPI NAND" highlighted, move the cursor up to the upper right hand corner of the "Windows Explorer" window and select the tab "File". From the drop down menu select " New Folder ". This should cause a folder to appear in the window to the right of the "Sansa e250" window. The new folder should be highlighted and labeled "New Folder". Select the "New Folder" and rename it "MUSIC". When renamed, select the PPI NAND folder and the new folder "Music" should be listed as one of the folder in the subdirectory. If so, you can select it to see if the Music folder contains and music files. If not, you will need to copy or drag your files into the new "MUSIC' folder.
Once I did all of this and disconnected my sandisk player, the player and let the software complete the programming work before shutting it off, it worked fine. My original problem was caused by shutting my sandisk player off after disconnecting it from the computer before the sandisk software completed its work.
Hope this helps.
Mar 12, 2009 | SanDisk Sansa m230 MP3 Player
Unable to play playlists on my Hitachi MP3
You can try dragging the playlist into the folder that you open up when you connect the player and then you want to drag and drop music. Then drag the folder and drop into the music folder which means you are copying from the player to another folder on the player. This manages to solve the problem of the player re-arranging files alphabetically and may help your playlist issues.
Jan 28, 2009 | Hitachi DMP-7 MP3 Player
How do i move my songs on my mp3 player?
I connected to my Laptop and created folders to contain different albums or songlists. If you want songs sorted by artists or name, that also can be done on a PC folder prior to selecting and copying back to the MP3 player. This worked for me.
Dec 10, 2008 | Audio Players & Recorders
Rca M4002A MP3 player
Make sure the image file is in JPG format, or the player won't be able to read it.
For users running Windows XP with Service Pack 1 and above:
With your device connected to your computer, click on My Computer and then click on the icon for your device. If you see a folder labeled DATA, you must copy the photo files you want to view directly into this folder. Folders containing photos cannot be copied to the DATA folder. Photo files must be copied directly to the DATA folder using no other folder.
If you do not see a folder labeled DATA, then copy the photo files you want to view directly to the device. Folders containing photos cannot be copied to the DATA folder.
May 03, 2008 | RCA OPAL M4001 MP3 Player
Philips GoGear SA3245/37  Digital Media Player Logo
67 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
