Question about Canon imagePROGRAF W8400 InkJet Printer
The printer display says 'printing mistake - switch off'
But every time I switch it off and on the same message comes. The printer doesn't react at all except for this message when switched on again. Thanks
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
My HP LaserJet printer 5200dtn is displaying error message "50.3 Fuser error" what is the solution to this problem because I can't print
50.3 means the fuser is getting too hot. It will either be a problem with the thermistor in the fuser or the power supply. If you can find a another fuser to test with you can answer the question pretty quickly.
Mar 02, 2015 | HP LaserJet 5200dtn Printer
My hp officejet ignore printing after replacing of cayne colour cartridge.
I hope Magenta cartridge is not refilled one right? :#Remove all cartridges and print heads, disconnect power & USB cable, switch off wait for couple of minutes.. give power switch on the machine wait do as per the message appears on display.. once installed cartridges and printer heads wait for the ready mode:.. once ready mode appears attach USB cable then print and see..# check with old and new cartridge see the difference of message.. if both messages are same it might be problem with ISS(Ink supply station) faulty, try it get back to us..for further remedies.
Feb 03, 2012 | HP Officejet Pro 8500 Wireless All-In-One...
I have installed HP 1220c printer on windows 7 in several ways. Printer seems istalled OK, when I try to print test page or other, the printer doesn't react. Although the print appears and dissapears...
Unistall any previous you have installed for your device.
The Driver for Your Product Is Included in the Windows 7 Operating System (i.e. Win 7-32bit & 64bit).
Simply connect the printer to your computer with a USB cable, and Windows Update automatically installs the driver for your product.
Hope it helps.
May 30, 2011 | HP DeskJet 1220c InkJet Printer
Recently had to reload everything on a new hard drive and reinstalled the Z82 drivers and updated firmware. Printer acts like it is printing but does not print anything. Any suggestions?
do you get anything from the self test? Press Setup until MAINTENANCE appears in the display. Press ?ž?or ?¿until PRINT SELF TEST appears in the second row of the display. Press Enter/Select. The message PRINTING appears in
if that works then it is definitely on the computer if not then you know it is a printer issue. When you plug in the USB cable did the computer react as if something plugged in? Try re-installing the drivers. Make sure the port selected is USB
Nov 30, 2010 | Lexmark Color Z82 InkJet
After selecting language and pressin OK message on LCD screen "set the ink cartridge". Cannot go any further than this message except switch off. Restarting brings back the language.
The solution was simple. The printer belonged to a friend who assured me he had replaced both ink cartridges when they ran out. So for some time I did not check them. On removing one cartridge it was obvious that he had accidentallyor unknowingly removed the contact strip on the print head so the printer could not detect or use the new cartridge. An expensive mistake for a newcomer to home printing as he had done the same to both cartridges.
Nov 12, 2009 | Canon Pixma MP480 All-In-One InkJet...
My printer doesn`t react
Hi there, " Unplug the printer cable from the computer. " Unistall the printer drivers from Device manager and also unistall the all the printer appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the printer. " then you can connect the printer and and try to Print the test page.
Scanner: Hi there, " Unplug the Scanner cable from the computer. " Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the Scanner. " then you can connect the Scanner and and try to Scan.
Aug 19, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Will the printer become damaged because repeated error message?
Do a EEPROM initialization:
Service Mode
This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
Service Mode Operations
1) With the printer powered off, hold down the resume button and press the power button.
2) While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power button. The
indicator will blink in green and remain lit in green.
3) Select one of the following service mode functions by pressing the resume button the specified number of times.
Press Resume Indicator Functions
Zero times Green Power off the printer
1 time Orange Service test print
2 times Green EEPROM information print
3 times Orange EEPROM initialization
4 times Green Waste ink counter setting
5 times Orange Destination settings
6 times Green Print head deep cleaning
7 times Green CD-R test print
8 times Orange CD-R print position correction (horizontal)
9 times Green CD-R print position correction (vertical)
4) Execute the function you have selected (except for model setting) by pressing the power button. The printer will switch itself off after performing the function.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 26, 2009 | Canon PIXMA iP1600 Printer
Estudio 352 is not help to take out printout from computer
Hello sir; When you make copy does it print? if there also no print out you better check the corona wire (charge & discharge) it should take care of you, if still don't work let me know.
Dec 30, 2008 | Toshiba Estudio 200L Copier
Canon imagePROGRAF  W8400 InkJet Printer Logo
57 people viewed this question
old marine
old marine
