E.g. are VOB files accepted? if so, in a CD-R or a DVD?
I'm not sure if its Toshiba or CompUSA, since both these companies have a product of the same name (?) i.e. CineVision DVR2000. Can someone pl. clarify this for me. As such, I didn't find Toshiba written anywhere on the player but not sure of the other. anyway, i don't think its that important but in case the supported file types may be different, just pointing it out.
if someone has the manual, could you please give me the link via rapidshare or something else? it would be appreciated!!
SOURCE: Unable to record.
Have you initialised the disk? The manual states that for the first use a DVD-RW has to be initialised first.
SOURCE: toshiba sd 220e dvd player
CDR
CDRW
DVD-R
DVD-RW
DVD+R
DVD+RW
DVD+R DL
VCD
SVCD
It plays PAL and NTSC apperently.
Here is a link to comments and more info of what this player plays-
http://www.videohelp.com/dvdplayers?DVDname=sd+220e&Submit=Search&Search=Search&dvdportable=&dvdchanger=&dvdtv=&chipset=&orderby=Name&hits=50
Hope this helps.
SOURCE: How can I unlock the Regional Code on my Toshiba SD-V392?
A lot of DVD players can be unlocked by using an event sequence. For example, open dvd draw, close the dvd draw, open it it again, put a number in with the remote and hit 0. If you can find an instruction sequence like that it's a lot simpler and easier.
SOURCE: Need codes for toshiba remote to work cinevision
There aren't any, your brand isn't supported on your Toshiba remote. The only thing you can do is to try all the other codes, maybe you're lucky and one of them will.
SOURCE: How do you use the VHS function on the Toshiba DVR670 player?
Because this product is a combination of a VCR and a DVD recorder, you must select first which component you wish to operate with VCR/DVD DVD mode Press DVD on the remote control. Verify that the DVD indicator is lit VCR mode Press VCR on the remote control.(Verify that the VCR indicator is lit OR I set up this pdf link...click on it and it will show you all necessary steps http://www.helpowl.com/manuals/toshiba-dvr670-owners-manual-english-70453af.pdf
