Question about Sony Playstation 3 (PS3) Console
My ps3 is reading ps2 games but not ps3 games
Not reading ps3 games but reads ps2 games
  • Anonymous Mar 02, 2009
    I have the same exacgt issue
  • 4 Answers
Hey man i found a solution to this problem i fixed my ps3 over nite, and i would like to help out, i have the 80gb and after days of research i realized that the problem is in your hard drive, its corrupted whether it gives you the error or not, at first i DIDNT think this was the problem since it never gave me an error but when i went to the reset screen (or how ever is called) by holding the power key down till it beeped three times and went to option RESTORE FILE SYSTEM and after that it said the system files were corrupted and would be restored and fixed but after doing so no matter how many times i chose that option it would always say files were corrupted. dont SEND IT BACK TO SONY, dont GET ANOTHER ONE, dont GET PISSED AND THROW IT AT YOUR MOM OR ANY MEMBER OF UR FAMILY ITS NOT THEIR FAULT LOL =]......HERE'S HOW TO FIX PROBLEM WITH YOUR PS3 THAT STOPPED READING blu RAY AND PS3 GAMES BUT WILL READ YOUR PS1 AND PS2 GAMES AS WELL AS REGULAR DVD DICS AND MUSIC DISC......GOOD LUCK HOPE IT HELPS YOU..........................................WARNING!!!!!! THIS WILL ERASE EVERYTHING FROM UR hdd SO DO A BACK UP OF UR GAME SAVES MOVIES MUSIC OR watever U GOT IN IT THAT IS PRECIOUS TO YOU cuz THIS WILL DELETE EVERYTHING FROM IT, dont SAY I DIDNT WARNED YOU, YOU NAGGERS LOL
THIS FIX WILL TAKE UP TO 6 HOURS DEPENDING ON YOUR LAPTOP AND PS3, MAYBE LONGER BUT LETS HOPE NOT.........HERE IT IS,
THINGS YOU NEED: laptop and recovery system disc(s) for your laptop
STEP 1: take out any disc if any from your 80gb ps3 and properly turn it off.
2: turn power switch off from the back and turn it back on.
3: go to the restore screen....this is how, now this is important, press and keep pressing power button( or key, how ever u WANA call it) on ps3 to turn it on but hold it and wait for 3 beeps till it turns off. now your ps3 will not know u WANA go to the restore screen the first time you try this so do the same step again and it will beep once then it will beep twice repeatedly and bang!! your on the reset screen LOL
4: now take your usb cable and do as the screen says, plug ur controller in and press the ps button on the controller and it will then give you 6 options to choose from, YOU WANA GO TO 3 "RESTORE FILE SYSTEM" but hold on there, dont click yes yet.
5: open the hdd(hard drive) thingy on from your ps3 and take off the blue screw that holds it but dont take the hdd out yet.
6: THIS ONE IS IMPORTANT!......you will select yes when it asks if you really want to proceed to restoring file system and after ur tv flickers and pops up the screen saying the files are corrupted and will be fixed and restored pay attention cuz you need to take your hdd out as soon as it begins to do the restore, YOU WANA TAKE OUT UR hdd WHEN THE PROCESS BAR IS ON 0% NOT 1% NOR 2% BUT 0% ZEEEEROOOOOOOO PERCENT(now leave your hdd on a safe place rit now where nothing will happen to it) if YOURE not quick enough your WOUNT catch the bar at 0% it but thats cool cuz you can try again just repeat the first steps.
7:ok now you need patience here, your ps3 will need to stay on for a long time showing the process bar on zero percent and eventually it will pop up another message saying that there was a problem restoring the system files and that you will need to format the hdd but trust me it will take a looooooong time till u get this message, i left it on over nite so idk how long exactly it took but hey idk, maybe it only takes second for u who knows????.....??? ?? ? WHILE YOU WAIT TO GET THIS MESSAGE YOU NEED TO FULLY FORMAT YOUR hdd USING UR LAPTOP OR SOMEONES LAPTOP, IT IS IMPORTANT cuz OTHER WHISE YOU WOUNT BE ABLE TO FULLY FORMAT YOUR PS3 hdd, WELL THE POINT IS, YOU NEED TO DO A FULL AND COMPLETE FORMAT TO IT, USING A COMPUTER, LAPTOP OR NON LAPTOP AS LONG AS YOU CAN ACHIEVE THIS YOURE GOOD TO GO, NOW THIS IS HOW I DID THIS....and dont think, oh well i could just do that using my ps3, trust me, i did that a million times and none of those times worked, i just wasted my time like an idiot =[
8: TURN OFF LAPTOP, now take the hdd out from ur laptop and connect your ps3's hdd on it......(you may need to take the outter metal cover form the hhd to be able to plug it in to the laptop), this is where you need your laptops recovery disc that came with it when u purchased it and if you dont have one then get one or else YOURE fucked =] .........ok now turn the laptop on and as soon as its turning on, go to the boot menu on your laptop on the first screen it gives you, in my case i had to press the F12 key, could be different for you....now when the other screen wit the boot from options pops up, put ur recovery disc in and when ur done choose to boot computer from disc drive meaning from your recovery disc.
9: ok well now you need to choose to "FULLY FORMAT" your hdd just go for the option or options that seem to take the longest time, if u get an option to fully format and delete all sectors and partitions from the hdd then go for that.....thats the message i got i think or something like that. the process will take up to 5 HOURS remember i said you needed patience, make sure your laptop is plugged in to its charger, you dont want it to turn off while it is doing the format. now go watch tv or something cuz this is gona take a long time, formatting 80gb takes a pretty long while, and if you do this before you go to bed then even better you just get up and start a new day knowing ur ps3 will survive this and u will go back to being happy wit it like before =] yay.
10: ok well now that the format is done and ur laptop says is ok to turn computer off, turn it off, it might do it by itself idk, it DIDNT for me i had to click restart now, ok by this time your ps3 should have given you the message saying that there was a problem doing the file restore and that will need to be formatted, now take off your ps3's hdd from your laptop and plug it back in where it belongs, on your ps3 and once it is in place YOURE good and ready to go, take your ps3 controller and click on YES, format hdd, and then it will format your hdd without problem.
SUCCESS!.......yay try putting in your favorite ps3 game blu ray movie or watever you want to test it with and it should work like it worked for me. remember formatting the hdd wit the ps3 itself WOUNT help you at all, this is the best way to fix your problem...good luck and i hope this also helps other people with this problem...latz and feel free to ask any questions, anyone can.
email===> gothik_zoul@yahoo.com
myspace===> myspace.com/gothik_zoul
Posted on Mar 31, 2009
  • 77 Answers
Disc Drive could be bad, or system may be faulty, check system or disc settings
Posted on Jan 06, 2009
SOURCE: 80015014
buy an xbox 360
Posted on Apr 21, 2008
bubulica2000
  • 55 Answers
SOURCE: ps3 not loading games
The Blu Ray diode actually contains 3 diodes in it.
Looks like the blu ray one is out, the other 2 still function.
You may need to purchase a KES-400AAA replacement.
Posted on Aug 28, 2008
bubulica2000
  • 55 Answers
SOURCE: ps3 not reading disc
the Diode in the PS3 units actually has 3 diodes built in. Looks like your blu ray one went bad the other 2 still function.
Order a replacement KEM-400 AAA and replace it (the whole laser lens mechanism with deck). If you still have warranty send it in.
Posted on Sep 05, 2008
  • 4 Answers
SOURCE: ps3 not reading ps3 games
  • 79 Answers
SOURCE: ps3 won't play blu ray or ps3 games
your blueray laser needs replacing, not very expensive and you can do it yourself.
Posted on Jul 16, 2009
My ps3 wont read games, what is the problem?
ur PS3 wont read PS3 games? or ps2...because ps2 only works on the very oldest models. But as for ps3 games...if NOTHING will read then u have a problem with the laser for reading the discs...which i mean u can pay 150 dollars or something and wait 4 weeks to have it shipped and fixed...or u can try and fix it urself...whatever floats ur boat.
Jul 05, 2010 | Sony Video Game Consoles & Games
Ps3 only plays ps2 games
the read files are corrupt for bluray and DVD discs.
Mar 01, 2010 | Sony Playstation 3 (PS3) Console
Ps3 has ps2 format wont't play ps3 games long. but will play ps2 games with no problem. how do i get ps3 format right.
sounds like a dead Laser they are a dual laser will read DVDs n CDs but wont read Blueray movies or PS3 games
Nov 16, 2009 | Sony Playstation 3 (PS3) Console
My ps3 wont read ps3 games only ps2 games
sounds like a dead Laser they are a dual laser will read DVDs n CDs but wont read Blueray movies or PS3 games Laser needs replacing
Sep 16, 2009 | Sony Playstation 3 (PS3) Console
My playstation 3 currently wont read playstation 2 format games. how do i correct this?
Playstation 3s cannot read Playstation 2 games, only Playstation 1. I know, it sucks. Hope I helped!
Jul 23, 2009 | Sony PlayStation® 3 (80GB) Console
Will not read ps2 games
The newer models of the PS2 Do not have the E-motion chip in them meaning that they will not read PS2 games. If you do indeed have a model that is designed to read PS2 games, then you will need to contact Sony and have them fix it.
Jun 27, 2009 | Sony Playstation 3 (PS3) Console
Running ps2 games on my ps3
could be laser problem. redlight mode laser controls ps2/dvd/cd reading. does it read bluray games?
Oct 31, 2008 | Sony PlayStation® 3 (60 GB) Console
Ps3 40G won't read the game
beacause its not program to the ps3 the ps2 disc try ps3 disc
Jun 10, 2008 | Sony Playstation 3 (PS3) Console
Reads ps2 games not ps3
If you have a copy of your receipt, you need to call Sony. They will send you a box and e-mail you a pdf with instructions. The lasers on these units are cheap. I have had 2 PS3's with disc read errors after 2 months of ownership.
If you don't have the receipt or if your unit is out of warranty it will cost $150.00 to fix-
Apr 02, 2008 | Sony Playstation 3 (PS3) Console
Sony play station 3
ps2 discs are region locked ps3 games are not so are some dvds the are region locked if you seriously want to play the ps2 games buy them from japan
Jun 21, 2007 | Sony PlayStation® 3 (60 GB) Console
Sony Playstation 3 (PS3) Console Logo
542 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
