Question about Canon CanoScan 3000F Flatbed Scanner
Selecting source for 3000f
I got the driver installed fine, every time i go to scan, it comes up with "Select a Source" Box but theres nothing in it for me to select Does anyone have any ideas?
  • graecus Jul 12, 2008
    Hi, I've about the same problem as described, but I'm a bit further already: XP itself perfectly detects the scanner, and I can run the device test successfully, so no cabling or driver issue. Anyhow no way to select this 3000(F) scanner. But, the very similar scanner 3200F gets perfectly detected, shows up in the scanner selection, and is fully usable. All driver and toolbox versions are the latest and greatest and come from the www.canon.com.au site. TIA Wolfgang.
  • Anonymous Oct 01, 2008
    The same problem, none of the hint could be useful.. scanner got right drivers, installation end fine, but no trace of drivers then on the OS.
    Brigadier General:
  • 6,966 Answers
Hi, a possible explanation why the CanoScan 3000F does not show in the Source Box selection is because Windows does not recognize it as being connected. To check, you have to go to Device Manager, Imaging Devices, expand it and see if the CanoScan 3000F is installed. If it is not there, then you would have to reinstall the drivers. Another possibility is a faulty USB cable or the USB port connector itself. Try a different cable or a different USB port. Another way of looking at it is that you were able to install the scanning software but not the actual driver(s) of the scanner. Hope this be of help to you. Good luck and pls post again how things turn up.
Posted on May 26, 2007
SOURCE:
Scanner will not form feed
There is an option in the dialog box where you select the paper source either ADF (chute) or flatbed. The options differs depending whether you are using twain interface for scanning or isis.
You need to select the proper source. If the paper source is correct then, probably, the paper sensor in the chute unit is not operating properly.
Mar 28, 2014 | Fujitsu fi-6230 Flatbed Scanner
AFTER LOADING SOFTWARE I COMPLETED THE TEST, IT THAT OK BUT WHEN I TRY TO SCAN, PRINT COPY OR ANYHING IT TELLS ME UNABLE TO CONNECT TWAIN SOURCE
Hello.
Give this a try (found online):
Download Irfanview:
http://download.cnet.com/IrfanView/3000-2192_4-10021962.html
Open the main app "i_view32.exe"
With the scanner hooked up, click onto the "file" (tab)
Click "Select TWAIN Source .." and select your scanner in the source box (if it is listed, the driver is functioning)
Click file (tab) then "Acquire"
Hope this helps.
Sep 15, 2011 | Canon CanoScan LiDE 60 Flatbed Scanner
When i am going to scan at that time in the screen select the twin source. what is the twin source of canon canoscanlide25
The prompt is probably asking you for the TWAIN source to use. In that box, simply select the Canon TWAIN source. If one isn't present, install the TWAIN drivers for this scanner.
Hope that helps,
MyEfact
Jan 04, 2011 | Canon CanoScan LiDE 25 Flatbed Scanner
I have HP Officejet J3680 All in one I wanted to scan a document but it is saying there is not option..
canning functionality from the LJ3380 and CLJ2840 series All-in-One devices may not function until the correct Twain Data Source is selected by the user. This can be done by attempting to scan from the foundation scan executable "hppscan2.exe ".
  • For the LJ3380 series this is located in C:\Program Files\Hewlett-Packard\LJ3015_LJ3020_LJ3030_LJ3380->hppscan2.exe
  • For the CLJ2840 this is found in C:\Program Files\HP\Digital Imaging\bin->hppscan2.exe
When the "hppscan2.exe " is launched from this location where it resides, a dialog box will open with a "Select Source " box listing the installed Twain scanning devices available. If this box is not seen, then there is only one Twain device installed. In some instances user input is needed to chose the "correct" Twain data source for scanning to be successful from the LJ3380 and CLJ2840 series devices. If the incorrect Twain data source is selected- an error "Cannot initialize device " will be seen.
Oct 27, 2010 | HP J3680 Officejet All In One Printer
Can't find twain source
The Twain source is the Picture or Photo program First I do not think your Scanner will run on XP because i have one and i have tried the original drivers Second I got my scanner running on an old computer with Win 2000 and had to use two sets of drivers FB330P/FB630P & FB630U/Fb636V then I open MS Photo editor and Click on FILE then go down to select source and click on the second entry of the scanner the go FILE Scan Image If you not not have MS Photo editor it may work with other programs
Jan 24, 2009 | Canon CanoScan FB630U Flatbed Scanner
Cannot scan
scanner will not support wireless or network scnning facility
Dec 12, 2008 | Office Equipment & Supplies
How do I scan an image from canon pixma mp150
Acquire Text The following instructions will give you the basic instructions to acquire text from a scanned document in Office Word 2007 using OmniPage SE.
  1. Ensure the Canon scanner driver and OmniPage SE are installed and that your scanner has been setup.
    Note: If OmniPage SE is not installed, the required Add-in for Office Word 2007 will not be installed
  2. Place the document(s) to scan on the platen or on the Automatic Document Feeder (ADF) (if applicable).
  3. Open Office Word 2007.
  4. From the ribbon menu, select the 'Add-Ins' tab.
  5. In the Add-Ins tab, click 'OmniPage' and then select 'Acquire Text Settings (OmniPage SE)'.
    The Options window will open.
  6. On the Direct OCR tab, click the 'Image Source' drop-down to select 'Scan'.
  7. Confirm 'Scan' is shown in Image Source section and then click 'OK'.
    The Options window will close and you'll return to Office Word 2007.
  8. Click 'OmniPage' and select 'Acquire Text (OmniPage SE)' to scan your document.
  9. After the document(s) is scanned, make corrections to the text items as appropriate.
I hope it helps!!!
Dec 01, 2008 | Canon imageCLASS MF7480 Laser Printer
Sound Driver not Install
if u have driver disk or source thene go to my computer then devicemanger then right clik any icon there then u see scan for hardware changes.
then folowthe proceduree then one step is come for browse then select your source of driver then it install.
Nov 15, 2008 | Everex NM3500 Laptop
Unable to select TWAIN source
tried uninstallin and installin canon scanner drivers..nothing works..still seeing unable to select twian source..
so i tried an alternative..here we go..
on vista 64 os/vista any version..click Start>All programs>Windows fax and scan
next click new scan on top and that got me going.
some say there are issues with the way usb talks to old scanners with new operating systems like mine (vista 64). hope it helps until you find the actual cure.
Jun 24, 2008 | Canon LIDE20 Flatbed Scanner
Canon CanoScan 3000F Flatbed Scanner Logo
320 people viewed this question
Clive
Clive
old marine
old marine
