Question about Epson Stylus C88 InkJet Photo Printer
Printer has red lights permanently on when powered up
I have an epsom stylus colour 680 - old yes but not over used! I tried printing a very large colourful document, however the pages jammed and the two red lights began flashing. I do know you shouldn't switch the power off when the lights are flashing, but after removing all signs of the jammed paper, the only solution I thought of (as with most electronic goods) was to switch off and reset. (I know, I was wrong!) However many times I've disconnected the power and left it, every time I switch it back on, it the red lights remain on and permanently fixed now, not flashing. What do I do please, is there a reset button?
  • Anonymous Apr 09, 2008
    i have a epson stylus r230, when i checked cleaned the nozzle then print it its ok it print, but when i get in the computer file to print it doesnt, papre jam red light flashing and i cancell the printing both ink and paper jam blinks fast simulteneously..
    President:
  • 2,961 Answers
If they were initially flashing fast there is a fatal error and a repair is needed, but always try a re install first. Go to printers and faxes folder and go to your Epson C88 printer icon, right click on it and select cancel all documents or prints, then select uninstall, to remove the printer. Uninstall driver from add/remove programmes, turn off and remove printer from usb port and restart pc. Install the drivers and software again from the cdrom and when prompted to connect printer, switch it on but connect to a different usb port if possible and allow windows to detect and install. If the lights are still steady red or flashing fast, then the printer is faulty.
Posted on May 26, 2007
  • RHanson Dec 14, 2010
    not useful info..
    if cartridges have been changed, its a logic board problem..cheap fix
2 Suggested Answers
rotorcrafts
  • 302 Answers
SOURCE: epsom stylus color 680
Try the following it may help.Please download the following software.and install it.
http://www.ssclg.com/download/sscserve.exe
Now select the appropriate printer model in the configurations tab.Now close this window and a small printer icon will appear in the taskbar.Right click on it and go to Protection counter and select "Clear counter overflow".
just do this and you printer will work fine again.
Thankyou,
Mohsin Idrees Khan.
Posted on Apr 10, 2009
Epson colour 680 green and red lights on, will not print
  • Pressing and holding LOAD/EJECT and CLEANING buttons,
  • press POWER button and hold it until You will see blinking INK OUT and PAPER OUT leds.
  • Release all buttons.
  • In 2-3 seconds time press and hold LOAD/EJECT button, until all leds will blink.
Aug 14, 2010 | Epson Stylus 680 InkJet Color Printer
I've just installed both a new black cartridge and a colour one but after having to clean the heads a number of times to try and get the print quality back up to scratch the printer is now refusing to do...
.. is the light flashing alternate? if yes, then the printer porous pad need to be replaced and reset ink counter.. install your printer driver and status monitor and you should be able to find out whether it's the ink empty or maintenance needed. For this model.. I am sure your waste ink counter is full...
May 20, 2010 | Epson Stylus 680 InkJet Color Printer
Have an Epsom stylus color 440. will not print
I'm trying to do a print nozzle check on my Epson Stylus Color 440 printer that I have but a pop-up box say "Error, can't print". Why is this?
Oct 06, 2009 | Epson Stylus Color 440 InkJet Printer
Middle of three buttons permanently on red
Did you mean ink light permanently on? See status monitor. Is all chip (ink tank) recognized? Or may be some chip reach "ink out". Try to use another ink tank (new). If you wish to refill used ink tank, you must reset ink counter first.
Sep 28, 2009 | Epson Stylus 680 InkJet Color Printer
Printing red
Check your installation in extended adjusting the seal, default all in zero, arouse reinstall driver of the printer. Change adjusting the seal from panel of management. But can was simply littered cartridge and at melange colour no other colour.Good luck
Jul 05, 2009 | Office Equipment & Supplies
Green and red light permanantly on.
Green and red light on : ink out error / chip doesn't recognized. If u use SSC, and said "Coomuniaction error", it's normal. Replace ink tank, or use CISS chip.
Jun 11, 2009 | Epson Stylus 680 InkJet Color Printer
Epsom stylus color 680
Thankyou,
Mohsin Idrees Khan.
Apr 10, 2009 | Epson Stylus 680 InkJet Color Printer
I have an Epsom Stylus CX 3900 Series printer and when i switch it on the red light comes on and will not print. I replaced the black ink cartridge but the other three colours are empty. Does this make the...
yes. some printers won't print if they don't have all colors full, even if they dont need them at that time. bad luck ... refill all of them.
I have photo R265 and one color is gist beggining to run out ... I can stand on my head and it won't print anything.
Dec 28, 2008 | Epson STYLUS CX3900 All-In-One InkJet...
"Change cartridge" light stay's on after replacement
What exactly does the status monitor say? Your printer may have a problem with the counter or if the machine simply does not see the cart there could be an issue with the print head or the main board.
Sep 29, 2007 | Epson Stylus 680 InkJet Color Printer
Epson Stylus C88 InkJet Photo Printer Logo
371 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
