Question about SanDisk Sansa e250 MP3 Player
Doesnt detect in MTP mode
I've got a sansa e250 which used to work fine, but one day when i plugged it in in mtp (as i usually do) it asked for a driver and since then its not detected in rhapsody nor wmp11, though it works in msc mode Cheers
On the device itself. Go to settings > USB mode > MTP.
Posted on Jun 09, 2007
  • 3 Answers
I had this type of problem, excluding Rhapsody, but when the computer was updated, everything fixed. Sorry I couldn't help more. I think we updated Windows Media Player, but I think ours was 10, not 11. Try running auto update.
Posted on May 30, 2007
SOURCE:
Sansa e250 MP3 Player: The computer won't acknowledge that my Sansa E250 ...
Hope this helps. See the section about the hot fix first----- If you are using Windows XP: you need the following. Windows XP SP2 or higher Windows Media Player 10 or higher Download and install the latest Windows Media Player if it's not installed. If you are using Windows Vista: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. Download the hotfix from-->>> http://support.microsoft.com/kb/939211. Run the hotfix. Refresh the players driver Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Check under Device Manager 1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are Sansa Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Instructions to connect in Forced MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/61 Instructions to switch player to MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/207 If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the Sansa firmware NOTE: Sansa Express and Sansa Connect do not have MSC mode. For Sansa Connect you can try reinstalling the firmware using the Connect Recovery Mode. Additional troubleshooting notes: If you have replaced the Sansa Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting. - Try connecting on another computer. - Try using a different USB cable - Try connecting to the back USB ports which may supply better power. - If only MTP mode is not working, try reinstalling Windows Media Player For Windows XP try also download and install the MTP Porting Kit ......
May 16, 2010 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player with Mac? Is there any driver to make it compatible with Mac platform? Thank you
NOTE: MAC computers do NOT support MTP modes of USB conectivity in a MP player. A Sansa player in MTP mode when plugged into a MAC computer will NOT be detected or recognized. MAC computers supports Sansa players in MSC mode Sansa players can only be recognized by a MAC if the USB mode on the Sansa player is set to Auto Detect or MSC.
Check in the System Profiler Open System Profiler from the Utilities folder, which is inside the Applications folder. From the Contents column on the left, under the Hardware header, select USB; the panel to the right will show all the USB devices that the computer recognizes. It may not identify them correctly by name, but it should have the right number of devices listed. . Navigate to USB Mode settings. Sansa View - From the Main Menu, select More > Settings/Options > System Settings > USB Mode.
Sansa Fuze and Sansa Clip+ - From the Main Menu, select Settings > System Settings > USB Mode.
Sansa Clip, e200v1 series, e200v2 series and e200R - From the Main Menu, select Settings > USB Mode.
2. Select Auto Detect, MTP or MSC. e200R - PlayforSure is MTP and Rhapsody is MSC
See this tip posted here on this site for a better explanation on the modes - MTP and MSC. Solve your MP3 Player Connection Problem.
Feb 05, 2010 | SanDisk Sansa e250 MP3 Player
MY SANSA 250 NOT DETECTING MTP MODE AND IM UNALBLE TO UPLOAD
It's not to normal that it doesn't recognize the MTP mode. I think reading the minimal requierments should be useful. Thereafter untill I recomend you to use Windows Media Player. You put the music you want to be on your sansa in the WMP library. Then you go on the Syncronisation tab upwards to the vizualisation window. and the rest should roll on
May 21, 2009 | SanDisk Sansa e250 MP3 Player
I turn on my sansa e250 it goes to refresh database, then blanks
There are two connection settings in USB: MTP and MSC. For some reason MTP is the default, but it doesn't connect properly on all computers. Select MSC and plug the player in again, the computer will recognize sansa e250 but not show the driver just yet. It is installing recognition software (just basic drivers - nothing heavy) and it doesnt tell you what its doing until its complete. WAIT FOR IT. Once it is complete you will see both the sansa e250 and the removable memory slot in your "my computer" now you're good to go.
Mar 30, 2009 | SanDisk Sansa e250 MP3 Player
My sansa e250 mp3 player is unable to connect to computer nor recognized to use .It won`t turn on change the modes
turning on to change modes is your problem. If it's completely dead you may need to replace it or refurbish it. Or if the battery is completely dead plug it in all day until you can get it to turn on. ONCE ON then you can worry about getting it to connect. Try this:
Jan 18, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e250 - MTP Mode not working with Windows Vista
Get the vista compatible software from Sandisk's website
Aug 08, 2008 | SanDisk Sansa e250 MP3 Player
MTP Mode Doesnt Work
Try uninstalling MTP Mode in the Windows Device Manager, and replugging the player - set the menu setting in the Sansa itself to "auto" for USB Mode before replugging. Let me know how it works.
Jun 13, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e250 drivers
Hi there , in the settings menu in your player if you go into usb you can change it to msc mode and it will read as a normal usb drive so you can transfer songs etc
Oct 20, 2007 | SanDisk Sansa e250 MP3 Player
Windows XP wont recognize Sansa Player
Try uninstalling and reinstalling your windows media player. And also try to update your windows media player.
Jun 22, 2007 | SanDisk Sansa e250 MP3 Player
MTP device not found in XP with WMP 11
solve your problem from my post:
http://amritbera.blogspot.com/2008/11/mtp-problem-solved.html
May 22, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
78 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
