Question about Refrigerators
Frigidare model FRT18DRHWO manufatured 03-00 The white case at the back of the frig that has styraform in it. What does the styraform do and what happens if someone has removed it? Also why would it run and the compressor not be on? Appreciate you assistance. Thank You
    Scholar:
  • 58 Answers
Don't be concerned about the Styrofoam, what you have there is overflow if you remove the foam you should be ok as long as you didn't cut in to the cab and remove more of it. To awnser your question the foam is there to insulate the cabinet if a lot was removed you can cause a void in the insulation and start to see a lot of moisture build up. As for your sec question depending on the model the t-stat may not be calling for cool. so in some cases the compressor will be off and the fans stay on but how do you know if the compressor is off? unless you pulled the back off and checked, but if your unit is cooling i wouldn't not worry about it.
Posted on Jan 08, 2009
My frigidare 241968503 is leaking water around where you plug the filter in?
Took out filter, placed forefinger firmly over one outlet and sucked, with my mouth on the other. heard seeping noise and found clear casing cracked very slightly where it is melded with the white front plate. This is a much simpler check before you start getting out your tools! Solution, replace filter and cross your fingers that this stuff made in Singapore will hold up for a few more months.
Mar 06, 2012 | Frigidaire Refrigerators
Vegetable bin keep freezing food. Model # ED2CHOXKQ05
That can be the result of a couple things. Check to see if you hear the fan running in the freezer side? If not, since cold air falls, the cold air could be migrating from the freezer into the frig bottom section through the air duct hole in the back of the frig behind the crisper drawers. If the fan is running the check the air damper in the top left of the frig section. If the frig side is cold enough you should not feel air blowing through. Air flow is only very slight. You will have to remove some plastic cover or duct piece to see if it is closing. If the air damper seems to be working properly, you may have a refrigeration problem indicated by frost build up on the lower part of the freezer back wall. You may want to call in a pro at that point. Hope this helps point you in the right direction. Good Luck
Mar 12, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Frigidare 1812 frig-water under crisper drawers
clogged drain line somewhere in fridge plumbing
Feb 21, 2010 | Refrigerators
Lights out..White box is clicking in back base of frig
sounds like the relay box on compressor . . you can repl the relay . it's not a hard job .. and its lso a very common problem on many frig's . ****
Jan 04, 2010 | Refrigerators
Frigidare refrigerator FRS26ZTH FREEZER FREEZING UP/FRIG NOT COOL
also check defrost timer,defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 01, 2009 | Frigidaire FRS26R4A Side by Side...
Refrigerator and freezer not working good
drip tray usually located at bottom of fridge at rear.sounds like defrost timer is no good,some models can be manually manipulated its located at bottom front panel or at back of fridge,if this is the case defrosting the fridge results in operation o.k. for a short period then gradually dying again
Aug 11, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
How to replace three prong cord to four prong cord on Frigidare electric dryer
Red, white and black go to the same terminals. If there is a ground strap connected to the white terminal, remove it. Connect the green wire to a ground. Any screw connected to the casing will do.
Jun 13, 2008 | Frigidaire Dryers
Trying to locate defrost timer on frigidare model frs24wnfw I hsve the psrt but dont know where to locate where it goes.
on your frigidaire model, look on the front left on the bottom. for some info on your frig, see:
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Anderson/95310918.pdf
page 10 item 23. hope this helps.
On the maytag defrost timer: it's probably beside the cold control in the plastic housing on the ceiling of the FF section.
Jun 08, 2008 | Refrigerators
Whirlpool gold conquest refridgerator
if u find out let me know. when we turn both frig/freez switches off the frig light comes back on flashes to number 6. it still seems cold be like this 2-3 days the food still seems cold. good luck. jax, fl
Mar 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
387 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
