Question about Motorola Mobility HS820 Consumer Headset
Samsung e900 pairing
I have an hs 820 bluetooth headset but can,t seem to get it to pair up with a samsung e900 mobile phone i have just bought and i have lost the manual for the headset, can any one please advise? jc
  • john currie May 26, 2007
    thanks quick response solved the problem
    President:
  • 2,961 Answers
If you press the power button and hold until the blue light stays on the set is then in find mode, at this point use your phone to search for new devices and when it finds it it will see the HS820 and probably ask for a pin number this is 0000, when they are paired the blue light will flash and then flash intermitently from then on.
Posted on May 26, 2007
  • andrew pester
    andrew pester May 27, 2007
    sorry, forgot to add;to turn it off press and hold for 3 seconds, the light flashes 3 times, then turns off.
How can i pair my hm1500 buletooth headset with 2 phones?
When device is in pairing mode (device on, long press "talk" button until LED is steady blue), long press the "up" button until the LED blinks twice.
Then search it on the second phone and pair it.
Turn HS off, then on.
Oct 11, 2012 | Samsung HM1500 Bluetooth Headset
Motorola hs850 bluetooth headset won't pair with g five mobile
How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
  4. (Now you can let go of the call button.)
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
May 14, 2012 | Motorola Mobility HS850 Consumer Headset
Pairing the Samsung WEP 210 headset to my Samsung Soul phone
Pairing Instructions
Pairing will create a unique and encrypted wireless link between two Bluetooth enabled devices, such as your Bluetooth phone and Bluetooth headset.
Ensure that the headset is off (see Turning the headset on/off).
Press and hold the Multi-Function button until the indicator light turns on in blue (approximately 8 seconds).
Set your Bluetooth phone to discover the headset by following your phone's guide. Typically, the steps involve going to a Setup, Connect, or Bluetooth menu on your phone and then selecting the option to discover Bluetooth devices.
Your phone will find the Samsung WEP210 headset and ask if you want to pair with it. Confirm this by pressing the Yes or OK key.
Enter a passkey or PIN, 0000 (4 zeros), then press the Yes or OK key.
Aug 21, 2017 | Samsung Bluetooth Headset WEP-210 B2700...
Having problems pairing
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
Apr 12, 2009 | Motorola Mobility Universal Wireless...
HOW TO PAIR A BLUETOOTH HEADSET WITH A SAMSUNG YPP2 MP3 PLAYER
You have to go in to the blue tooth option on the menu of the p2. Then click search. Hit the sync button on the headset. It should find it in less than 20 seconds.
Jan 19, 2009 | Samsung Cardo Scala 500 Hands-free Headset...
I Cant seems to pail motorola h700 headset to samsung g600
Well, it sounds to me like you know how to get the headset in pairing mode, have you tried turning off your old e900 and then pairing?
This guide was taken from here.
In standby mode, press Menu. Highlight Applications and click Select.
Highlight Bluetooth and click Select, or just press 4.
Highlight My devices and click Select, or just press 2.
Put your remote device into pairing mode. You can find out how to do this from the manual that came with the device. When the device is in pairing mode, highlight Search new device and click Select.
If Bluetooth is not activated on your G600, you'll be prompted to switch it on. Click Yes.
The G600 will search for all the Bluetooth devices in the proximity. The type of device will be indicated by the icon to the left of it, so you can clearly see if the device is a PC, a phone or a remote headset.
You'll be asked to enter the PIN number to connect to the device. This is in the documentation that came with the remote device but if in doubt, try 1234 or 0000, as these are the most common PINs.
Once connected, the device's icon will turn orange on the My devices screen, and when you press the red End call key to return to standby mode, you'll see the headphone icon on the top row of the screen.
Your headset will now be paired permanently with your G600. Switch the device off to disconnect it, and next time you switch it on the phone will connect automatically, providing your Blueooth is activated (go to Menu, Applications, Bluetooth, Activation, On to activate Bluetooth).
My apologies for the copy past guide, I have never used a samsung phone.
Dec 25, 2008 | Motorola Mobility H700 Wireless Headset
I have a blackberry curve and am wanting to pair my bluetooth HS850 to it. Please help!
There actually is a trick to the HS850 - flip the boom closed, then hold down the button just until the light holds solid - IMMEDIATELY after it does flip the boom open and this should keep the light solid. Then on your cell/device search for bluetooth devices - you should be able to find it now. Passkey for most devices is 0000.
Jun 30, 2008 | AT&T Blackberry Curve 8300 Smartphone
No connection withe nokia HS-36W bluetooth headset
First check your headset pair with other handsets if ok. your headset is ok. then check your hand set connection is ok.The default password of hs-36w is 0000
Jan 28, 2007 | Nokia 6230
Motorola Mobility HS820 Consumer Headset Logo
105 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
