Question about Bush 5693D 24" TV
Bush tv has a circle on screen like looking thru a telescope
Colours are yellow and purple with a big circle in the middle!
  • andy953 Jan 10, 2009
    The colours are all mixed in a circular pattern on the screen fading from one to the other sort of like a kaleidoscope This on a Bush rf6685vpl model.
    This model has an automatic demagnetiser that should clear4 this problem after the tv has been turned off for 15 minutes.
    If it doesn't do this then the degaussing component has failed
  • 189 Answers
HELLO
Funnily enough I have been given a 21 inch standard Bush set with the same problem!
It's a DEGAUSSING fault. This means the deguss circuit in the TV is not operating as it should - probably a faulty positor. When you switch the TV on (NOT FROM STANDBY) the circuit that removes magnetism from the screen does not work correctly.
Switch it off, unplug the set from the mains for 30 minutes or so and try it again. If there is no change, contact a TV repair centre.
Make sure there are no hifi loudspeakers next to the TV or a radiator as this can have an effect too.
ALL THE BEST! (:-)
Posted on Sep 30, 2009
Bush tv picture colour red&purple
Check for any loose soldering points on the video output card [ a circuit baord located at the neck of the pircture tube]. Resolder all the suspected solder points. Green colour out put is absend now with your Tv.
Mar 14, 2012 | Bush Televison & Video
I have a Bush RF6685VPL/A and the screen colour is very distorted. It looks like a blue red circle in the middle, with a blue and green ring around it.
Good day!
That problem is usually happen when the TV is near the magnet or the speaker.
You have to do is demagnetized the screen of your TV using screen Degausser.
The picture looks like this:
Just plug-in the degausser and push the button in front of your TV.
If you did not have that degausser please buy it to this link:
http://shop.ebay.com/i.html?_nkw=degausser+&_cqr=true&_nkwusc=degauzer&_rdc=1
                                   Thank you and don't forget to rate my answer.
May 10, 2011 | Televison & Video
Yellow circle in the middle of the screen. It has
Not sure if this will help...
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Toshiba 42H83 42" Rear Projection...
My bush tv has a light purple circle in the middle with a blue then green halo.It turns red to blue in the centre,is it worth repairing.
has any full tv image? if not is a vertical and horizontal circuits defectives, send to repair
Nov 22, 2009 | Bush 5693D 24" TV
Colour breakdown
Thank you for your reply. I have since had my TV repaired by a local engineer. The TV needed a new part to restore the colour.
Helen Shaw
Jul 06, 2009 | Bush Televison & Video
Image has big yellow
Hi Zenmast
This is a burnt LCD that will need replacement. If the circle is yellow on a white screen , then it is your blue LCD that will need replacement.
Apr 22, 2008 | SharpVision XV-Z1U Multimedia Projector
Colour distortion
Your screen mask may have become magnetized. This will require that you have the CRT degaussed. This is done with the use of a degaussing coil. you have to stand about 10 feet from the TV with the coil held vertically and moving it in a circular pattern as you walk towards the tv. Once you are about 1-2 inches from the TV stop and continue the circular pattern for about a three count then backup from the tv still using the circular motion once you are about 10 feet from the tv turn the coil to a horizontal plane and move it away quickly and turn it off. This should degauss the TV and remove the color distortion.
You will need a degaussing coil to perform this task.
Thank you,
Shuttle83
Nov 27, 2007 | Televison & Video
Help,colour is wrong
Hi. The problem is either the degaus positor has failed which is an easy repair. Or have you recently placed hifi speakers or something with a strong magnet in side near your tv set.
Jun 04, 2007 | Bush 5693D 24" TV
Bush 5693D 24" TV Logo
153 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Raj Patel
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
