Question about Canon Rebel XT / EOS 350D Digital Camera
Canon EOS 350
My pictures have a strong green cast on them when printed. I am using an Epsom R200 printer. Any ideas??
The color cartridge on the printer might be running out of ink for the 2 other colors. This printer might have a feature such " clean heads" or "clean cartridge". It also might have a test page that would test the 3 colors. If the test does not match ie it is missing the pattern, the cartridge is out of ink.
Posted on Jun 07, 2007
    Genius:
  • 2,985 Answers
Are you printing the images directly off the card or as loaded into computer? Do you use an image editor? I assume not becuse this is correctable. If you do not use an image editor download picasa[just Google picasa] learn to use it and then try.
Posted on May 26, 2007
I am shooting in raw i cant download pictures properly or get my pictures printed off the the card
RAW images are what it means. You should convert them into a printable format such as JPEG before you can take prints. I strongly suggest that you shoot in JPEG mode to avoid all these headaches!
Apr 04, 2011 | Canon EOS 550D EOS REBEL T2i Digital...
Epsom R200 printer - ink and paper lights flashing red.
theres a guide on how to manually reset the counter here
unless you replace or clean the waste pad from here on in regard your printer as a ticking ink bomb. put it on a tray with a lip just incase of an ink overflow and dont put it on the carpet.
Sep 25, 2009 | Epson Stylus Photo R200 InkJet Printer
Bad yellow cast to photos when printed
If you have a yellow cast to your photos, the problem might not be your printer. If you're using a digital camera, indoors under incandescent lighting without a flash your pictures will look yellow.
If this is the case, set your camera's White Balance to Incandescent lighting or use the flash. If all of your pictures, even those taken in daylight, look yellow you'll have to adjust the colors on your printer using the "toolbox" software that comes with it and back the yellow off. I've found that HP printers tend to have better color rendition than Canon.
May 24, 2009 | Canon Office Equipment & Supplies
My IP6700D prints some color but with a green cast
Someone forgot to peel the tape off the PM cartridge, must have been me.Thanks
Jan 04, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
Epsom R200
سلام دوست عزیز
شما میتوانید لوح فشرده راه انداز پرینتر خود را داخل دستگاه گذاشته و دوباره اقدام به نصب پرینتر کنید
فقط پرینتر قبل از نصب حتما خاموش باشد و وقتی پیغام مورد نظر را مشاهده کردید اقدام به اتصال کابل USB کنید
با تشکر ترنج پرینتر
TELL: 0098 311 2683688
FAX: 0098 311 2660477
Nov 29, 2008 | Epson Stylus Photo R200 InkJet Printer
Distorted color printing
Check on the quality printer settings - Clean your cartridges -
Sep 04, 2008 | Canon I960 InkJet Photo Printer
Ink level
i used Epson R230 inkjet printer.Now the printer, two lights are blinking .the messge show service requird .
Aug 04, 2008 | Epson Stylus Photo R200 InkJet Printer
No printer information
Follow these steps to set up your Epson product and install the built-in Windows Vista drivers:
  1. Set up your computer.
  2. Connect your Epson product to your computer.
  3. Follow the on-screen instructions that Windows Vista displays to guide you through product driver installation.
You need to use a program that can do printing multiple pictures in just one click.
Feb 05, 2008 | Epson Stylus Photo R200 InkJet Printer
Canon 20D strong blue cast to pictures
You probably have the White Balance set to a setting other a
than "Auto White Balance" (AWB). On the top of the camera, above the exterior LCD panel, there is the "AF-WB" button. Turn the camera on--past "on" to the bent line. Press the AF-WB button once. On the left side of the exterior LCD panel there is a vertical, reticular box with the symbol of the selected setting for WB. Normally, the setting should be set to AWB. If it is not, turn the command dial at the back of the camera until "AWB" is showing. Try shooting again-the color should be better.
In the "auto" modes (green box, portrait, landscape, etc) the AWB is automatically set. In the "advanced" modes (P,Tv, etc) the WB is manually set for whatever light source you are using. The command dial may have been accidently turned to different setting. Hope this helps.
Jan 23, 2008 | Canon EOS-20D Body only Digital Camera
Epsom R200 COPY INK DOESNT WORK
There is no solution, I have tried this myself, there are compatible inks for this product, you just got the wrong ones, However it may only be down to one of the inks, check the ink levels before removing, if all empty, then they are not compatible.
swampduck
Jan 07, 2008 | Epson Stylus Photo R200 InkJet Printer
Canon Rebel XT / EOS 350D Digital Camera Logo
55 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
