Question about Panasonic Cameras
Outer Lens cover will only half open on my Panasonic TZ5 Lumix Digital Camera, One section appears to be jammed.
    Genius:
  • 1,550 Answers
Try hard reset . Remove the batteries and insert new batteries . Sometimes this may work
Another chance is that lens is struck
* Carefully inspect around it for dirt or debris
* If you see any dirt or debris around the lens, use canned air to gently blow it away
* After removing dirt and debris, turn the camera on and off
This should work
Hope this helps .
If your problem still continues you need to take to service center .
Thanks for using FIxya
SAM ANDERSON
Posted on Jan 06, 2009
Panasonic lumix TZ5
Go to your nearest Camera shop and ask them to see if the lens are damaged.. They will repair your camera.
May 23, 2010 | Panasonic DMC-TZ5 Digital Camera
Lens stuck open on Lumix DSC-TZ5
This is a common problem when something goes wrong with the lens system.
This can be as a result of numerous problems.
Try to pull the lens as turning on and also gently twisting it in and out...just may make the lens go back on track.
Sep 21, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
8 month old tz5 doesn't want to focus any more. Camera says to switch off and then on again, but doesn't help. Anyone help..?
Hi!
It sounds like the focus is stuck. Could be sand, dirt or something like that. I repaired a TZ5 with this problem a couple of days ago. You should contact your local Panasonic service center or other local camera service center. This is a hardware problem, not software, so I'm afraid changing setting and stuff like that won't help.
I hope this helps!
Tom
Jul 29, 2009 | Panasonic DMC-TZ5 Digital Camera
Have Panasonic Lumix DMC-TZ5. get message turn camera off
Did you drop the camera on the lens?
You have to replace the barrel (cost around 175,00 euro)
try to find a cheap second hand camera en replace the lens unit...
Jun 17, 2009 | Panasonic Lumix DMC-LZ2 Digital Camera
Hi I have a panasonic tz3 camera that when i turn it on it after 3 sec turns to please turn camera off and then on again the cover in front does not open up either any idea?
The cover not opening is a common problem with the TZ3, but this should not cause the waring message. Has the camera been bumped hard or dropped?
Try rapping the camera smartly against the heel of your other hand, or on a harder surface cushioned by a double layer of bath towel. You can also coax the lens cover open with a toothpick.
The error your seeing is common for lens problems, either unable to extend or retraced. Sometime you can overcome these problem by giving the lens or cover some manual help. Otherwise, repairmen on ebay buy them for repair, and working used ones are available on ebay at a good price, likely much better than what a local camera shop would charge you, and much better than what Panasonic would charge you.
If you take the ebay option, you can weigh the option of upgrading tp the TZ5, but the TZ5 is not worth upgrading to if bought new. Don't be fooled with a large pixel figure. TZ3 is a very nice camera to have. I love the wide angle and long zoom..
Dec 15, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Lens won't come out
If the camera is powering on as indicated by a normal screen, you can sometimes coax out the lens by rapping the camera against the heal of your other hand, or a hard surface covered with a cushion, like a double with towel.
The idea is to try to free it up without damaging the camers. This problem is common on cameras if dropped or have a few years on them. It is even more common for the Lens Cover on the TZ3 to behave this way. If it is the plastic lens cover that won't open, you can coax it open with a toothpick and if it closes again, I would just carefully pull this plastic cover right out and as a manual plastic cover that will fit the lense.
In any case, it is getting dated by the TZ5, so an alternate is to sell the defectic TZ3 on Ebay and buy a newer TZ5, new or used, on ebay to replace it. Reparmen buy popular cameras like the TZ3 to fix and resell them. If you have everything that came with it, including the box, it is probably worth $40 as is.
Dec 14, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic Lumix DMC-TZ1 spots on pictures
Upgrade to the TZ3 or TZ5. TZ3 is smaller and has a great wide angle lens. You can get a very good buy on Ebay for a used or new TZ3 because it has been replaced with the latest TZ5.
You can likely get about $40 dollars for yous, if it has all the stuff it shipped with, even with the problem you mention, since repairmen buy time to fix and resell on ebay.
Oct 23, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
Panasonic Lumix DMC-TZ3 Lens Won´t Open
This is a common problem with TZ3s. Power the camera on, then puff a little graphite onto the lens cover and coax it open with a tooth pic. Do this, powering the camera on/off till lens opens normally. Add little more graphite if necessary, but sparingly.
Graphite is used because it is extremely slippery, but will not attract dust like an oil will. At the same time, it is black! so you don't want to use anymore than absolutely necessary make lens work. Even then, check to be sure lens itself is clean after, and wipe carefully with an Eyeglass lens cloth only if necessary.
Another option in to remove the lens cover altogether by just pulling the leafs out of the camera. Another option is to sell your working but lens cover problem to a repairman on ebay, and buy a good TZ3 or TZ5 on ebay used, refurbished or new. Good prices if you bide your time.
Don't put in your best bid to the very last minute of the auction. In the mean time, put a camera you are interested in on your MyEbay Watch list and set a reminder alarm on your cell phone about 5 minutes before the auction is to close, then if the price is still good, enter your best bid 30 seconds before the end of the auction. Refresh the auction page on your PC to keep track of the bidding right up to the last 30 minutes so you can see the last remain bid and if it is worth outbidding on this camera. Again, if you are not in a hurry and bide your time, you can get a great buy. There are plenty of these cameras sold every day.
Jul 27, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Lens cover only opens half-way
If the lens barrel isn't fully extending on power up, that will prevent the lens cover shutters from springing open. There is a stationary prong that pushes the cover closed when the barrel is retracted.
Does the camera work otherwise? Take pictures thru the half open lens?
Jun 15, 2008 | Panasonic Lumix DMC-LZ7 Digital Camera
Cameras Logo
154 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
