Question about GE GSH25JSRSS Stainless Steel Side by Side Refrigerator
No water flow gsl251frfbs
Our GE ref's water flow stopped working but ice make still works. It's a GE side by side model# gsl251frfbs
mine stopped a few days a go to so i just turned off the freezer side an undid the water line under neath the fige, you will find it if you remove the front bottom piece. Then i did a test with a bowl press the water button while holding the line from the fige side over it but first be sure to take the line apart. If the waters come out from line while pressing button you know the other line is frozen. get a blow dryer and blow dry about 5 -10 mins inside the door and out side it the side were the hinges are. then try pressing the button and you should have water. good luck!
tina
Posted on Feb 02, 2009
WATER DISPENSER HAS STOPPED WORKING, HAD BEEN WORKING FINE THEN JUST STOPPED. WASNT SURE IF FILTER JUST NEEDED TO BE REPLACED OR IF MAYBE THE WATER LINE WAS CLOGGED. THE ICE MAKER IS WORKING FINE,
check your water tank in ref. it is behind veg. drawers.. if water tank is full. might check water soldnoid in b back of ref. there should be two one for ice maker and one for water..ok
Feb 13, 2011 | GE GSH25JFR Side by Side Refrigerator
The water dispenser in my refrigerator ice maker is leaking
if you have recently changed your filter, had the water turned off, or disconnected from the ref this is a common problem. you have air in your water line. fill 5-6 large cups of water or until it stops spurting and your drip should go away
Apr 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Can't control the Temp. too cold/Ice-Machine over flow
sounds like you have a sensor problem or a open damper ,staying open,so it keeps freezing in the frig...call if need more input...michael..doctor airr appl.repair..843-384-8474...
Apr 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge model gsl251frfbs side by side. Ice maker/water dispenser not working when activated. makes ice, just won't dispense ice or water through front door. don't hear motor activating.
I would check the door switch that turn the light on for freezer. When the door opens the switch changes to deactivate the controls on the dispenser panel and when shut should turn it back on. I will help you trace the problem because sometimes there is a broken connection from the dispenser panel to control board. Let me know, Sea Breeze
Dec 16, 2009 | GE Refrigerators
GE model GSH25JFTACC ice maker not working
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Mar 24, 2009 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
GE Arctica (PSS26NGSB) ice and water dispenser
need to call ge at 1800-386-1215 some of these sxs have a door insulation issue that they will either send replacement doors to an authorized service company to exchange at no cost to you or offer a rebate for a newer model. yours might be in this group
have your model and serial number out of the ref located in the refrigerator section, about 4-5 inches from the celing down the right side and call and see
Apr 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Ref #ESS25LSRCE SS
are you sure it is not a GSS or a PSS model i have the manual on that post your email and i will send it to you
Mar 10, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Water stopped flowing out
Replace Water Valve on the back of Unit. When this valve fails the water will not fill the ice tray or allow water to flow thru. Replace this valve and your good to go.....with a nice glass of ice water. cost of valve between $25-$40
Nov 29, 2007 | GE Profile PSW26P Stainless Steel Side by...
GE SIDE X SIDE Dispenser problem
Sound like maybe a dispenser board short... you could try taking of the top hidge cap on the freezer side unplug the power to the board there for 30 minustes or so plug back in and see if it can reset to default and try that before u have to change board
Aug 20, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSH25JSRSS Stainless Steel Side by Side Refrigerator Logo
521 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
