Question about Logitech Cordless iTouch Keyboard/Cordless Optical Mouse 967204-0000
I need to locate the reset button on my itouch cordless keyboard
I can't locate my manual - I changed the batteries in both my mouse and keyboard - mouse works but my keyboard doesn't. I can't find my reset button on the keyboard - I've looked everywhere! Can you help me?
Look at the side on the right of the keyboard just beneath the grey area. Its a round grey button with no labelling. Press the connect button on the IR module or the itouch icon on your system tray then press this button.
Posted on Jan 08, 2009
It maybe a little white button on the bottom of your keyboard. It will have a connect channel next to it.
Posted on Jan 06, 2009
Changed batteries now does not work
3 possibilities
1. You need to get the devices to see each other again - the keyboard and mouse will have a small button on them (usually underneath) press them and they will re-sync with the receiver.
2. obvious but I have done it - batteries in the wrong way round
3. again obvious - but if you have kids you will understand the problem - the batteries are dead and they have stuck them back with the live batteries.
Dec 14, 2010 | Logitech Cordless iTouch Keyboard/Cordless...
Can someone help me. I forgot to reboot or reset my itouch 2.15
To reset the iTouch so that it connects afresh to the USB receiver, there's a small inset button below the keyboard (and another under the mouse). Try keeping it at around three feet from the receiver when you do that; sometimes, too near does not work very well, and of course too far won't work at all. For the mouse, you will probably need a pin or a ballpoint pen to be able to press the button.
Feb 28, 2010 | Logitech Cordless iTouch Keyboard/Cordless...
Cordless keyboard not working.
there is a button under neath the recerver and the keyboard, hold the button under the recever and then hold the button under the keyboard
wait for a few secounds each time u hold this button then release and it should find it self then
Dec 03, 2009 | Logitech Cordless iTouch Keyboard/Cordless...
My cordless itouch keyboard has stopped activating the screen. I changed batteries in the keyboard. I rebooted the computer.
The FixYa tech assistant was unable to fix the problem. I bought a new cordless keyboard to eliminate the problem.
Please do not charge my credit card.
Thank you,
Mike McKeeman
May 30, 2009 | Logitech Cordless iTouch Keyboard/Cordless...
Recognizes wireless mouse but not keyboard.
may not be compatible,
or you ay need new batteries for the keyboard
Apr 18, 2009 | Compaq Computers & Internet
Mixed up multimedia keys
Take out the batteries, replace them, and hold the 'connect' button for 15 secs. Works a charm; the whole keyboard is reset.
Tim
Jan 31, 2009 | Logitech Cordless iTouch Keyboard/Cordless...
Location of the channel/connect button
Dec 09, 2008 | Logitech Cordless iTouch Keyboard/Cordless...
Hotkey problems
I had the same problem but finally found a solution hidden in the depths of Logitech. It's quoted below. I had to do it a couple of times before it worked, and it seems that you need to reconnect the mouse at the same time. I didn't the first time and then the keyboard refused to work. (Finger trouble?) :-(
Cheers,
Magani
The following is from :-
http://logitech-en-ap.custhelp.com/cgi-bin/logitech_en_ap.cfg/php/enduser/std_adp.php?p_faqid=28&p_created=1083786523&p_sid=hwmEUpij&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTkwLDE5MCZwX3Byb2RzPTg0NCZwX2NhdHM9JnBfcHY9MS44NDQmcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1teCBkdW8gaXRvdWNo&p_li=&p_topview=1
This article applies to the following products:
Cordless Access Duo
Cordless Acess Duo Optical
Cordless access keyboard
Cordless Elite Duo
Cordless MX Duo
Cordless Navigator Duo
You may be able to reset the keyboard and resolve the problem by clearing the keyboard capacitors. To do this, remove the batteries from the keyboard and type continuously on as many keys as possible for one to two minutes. This action should simulate touch-typing; you should not press and hold only some keys down.
After you clear the capacitors, replace the batteries and synchronize the keyboard using the following procedure:
  1. Make sure the batteries are in correctly. A diagram on the device itself or in the Getting Started Guide should tell you the correct polarity for the batteries.
  2. Press the connect button on the receiver.
  3. Press the connect button on the bottom or right hand edge of the keyboard.
    NOTE: If you are using a Cordless Desktop System, you must do this procedure for both the mouse and the keyboard.
The "Connect" button on the mouse is quite small and usually requires a pencil tip or other small object to push it. Remember, ALL Logitech cordless devices will have a synchronization button. If you have the "Cordless Mouse" with Model Number (M/N) M-RN67, the button will be located in a small hole on the lower portion of the back of the mouse. You will need a paper clip to access the button.
Jul 03, 2008 | Logitech Cordless iTouch Keyboard/Cordless...
Logitech iTouch key board
Have you replace the batteries? If so try the following.
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Jun 23, 2008 | Logitech Cordless iTouch Keyboard/Cordless...
Wireless mouse and keyboard inoperatab le
The keyboard and mouse both must be configured in order to work. Check on the top or bottom of the IR transmitter for a button that must be pushed. on the keyboard there are corrisponding buttons, these must also be pushed. do either keyboard or mouse first by pressing the controller button first and then the keyboard button, controller LED should blink to verify linkup. Repeat for mouse
May 26, 2008 | Logitech Cordless iTouch Keyboard/Cordless...
Logitech Cordless iTouch Keyboard/Cordless Optical Mouse 967204-0000 Logo
353 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
