Hello rluehrs96 -Typically error code F1 could indicate a variety of issues. The range could possibly have a runaway temp (higher than normal temps), shorted keypad, faulty EOC (Electronic Oven Control) or, display wire harness missing/not connected. Usually, this code means to replace the EOC. You may be able to reset the range by disconnecting the power to the unit for up ten minutes. Usually this will clear most false error codes. You can disconnect power by either unplugging the unit or flipping the circuit breaker off and back on. If resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately.
SOURCE: Convection fan does not turn off when door opens
fan is operated by a door switch which has jammed. as i recall, this is located inside the rhs side panel
SOURCE: Frigidaire Electric Range error code
Hi jacksmdmat,
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
SOURCE: get F5 error code. Burners
Hi jdaleq,
The f-5 code on the frigidaire ranges is a bad one. It is a ERC (electronic range control) failure. The repair manuals state to replace the control when the f-5 code shows up. You can also try to reset the control. To do this flip the breaker to kill the power, wait about 20 minutes then turn the power back on. If the problem returns then you will need a new ERC. The part number is.
#316418704 The price is $194.99 including shipping in the US. I do have these available to ship today. I hope this helps and please rate me when you can.
Mike
Anderson Appliance
(865)945-3808
SOURCE: Need help with error code for Frigidaire Oven Please!
Hi thanks for the question. the code f 2 means the oven sensor has failed .the sensor is located in the oven, top left corner. replace the sensor. thanks the appliance doc.
SOURCE: convection cooking
Convection ovens are great for roasting!
I cooked a 15 lb stuffed turkey in 2 hours in mine. And it was juicy and fab!
My auto degree set for convection is 325.
I have a Jenn Air wall oven, so I don't know, it might be different for different brand.
Roast or bird should be in the middle of the oven. THe air has to circulate well to get best results.
I believe rule of thumb is a convection oven takes 1/2 LESS time than conventional.
Hope this helps.
