Question about Motorola Mobility MOTOROKR S9 Wireless Headset for Bluetooth-Enabled Cell Phones - Black/Red
Green light stays on....headset not turning on
I charged my headset overnight. The green light was on and when I unplugged from the charger, it stays lit. I have held down the power button for at least 30 seconds and it never goes out and the headset never turns on.
  • dhlmchl Feb 02, 2009
    green light won't turn off after charging
  • dhlmchl May 11, 2010
    that is not the solution
I have had no trouble with mine (3+ months of good use) until today. Same problem you had - green light won't go out, unit won't turn on. Jonsumer's solution got me to thinking, and this worked for me:
1. plug the charger into the wall.
2. plug the headset into the charger.
3. unplug the headset from the wall.
Plugging & unplugging the headset to charger multiple times had NO effect. It was only when I plugged it into the charger and unplugged the charger from the wall that the green light turned off and the headset began to work normally.
Posted on Jul 06, 2010
  • macgyverdigi Sep 16, 2010
    Thanks willima, your solution worked A-1 for me :) ..quick
I had the same problem with this headset i bought from BestBuy in FL last month. Since i live in Brazil, i would not have the chance to return the headset to the store during the guarantee, so i tried to get the problem solved my way:
1) I disassembled the headset with the help of a little screwdriver, taking off all the plastic parts carefully;
2) After i got all the internal parts exposed, i carefully sweeped the metal extremity of the screwdriver over each little metal pair of the electronic circuit, until a short circuit is created, reseting the headset.
3) The green light goes off and a blue light starts blinking. That means the headset is now ok and ready to be hooked up to a bluetooth device.
4) You´ll need the screwdriver to assemble the set again and yes, you´ll need a superbonder to glue the plastic parts back.
Posted on Sep 03, 2009
  • akinbof Feb 08, 2011
    Actually worked
I managed to get the headset out of this state. I put it in the freezer to slow down the battery. This takes quite a while. I did this three times and plugged and unplugged the power supply several times. Eventually, it reset and has worked fine ever since.
Posted on Jul 10, 2009
  • 31 Answers
You can try installing a fresh battery. I have been in contact with the overseas supplier of these batteries and am offering them for $20 via PayPal once my shipment comes in. Please contact me at ebhammonds@gmail.com.
Posted on Dec 06, 2011
  • 57 Answers
The headset is defective take it back to the store you bought it from explain whats going on and they will replace it
Posted on Jan 06, 2009
Why My Nokia BH 505 Stays Blue When Charging?
Do an Hard reset. Plug charger into the headset, press and hold power button and plug the charger into AC, light indicator will change after a while from red to green/blue.
Feb 14, 2014 | Nokia BH505 Bluetooth Stereo Headset
Want turn on when charging green & red light flashes
Normally if you have a VXi, B250-XT on its charger and you are seeing both a Green and Red light the headset is changin over from charging to fully charged. The headset is designed to be able to use while it is on the charger however once you place it on the charger you must turn it on to reconnect to your phone before you can do this. Put the headset on and press the Multifunction Button for 2 to 3 seconds, you should hear two rising tones and the headset should reconnect with your phone. Note* your phone may require you to accept the connection request.
If the headset will not turn on either on or off the charger I recommend calling VXi at 800-742-8588 for warranty repair information. A headset that will not turn on indicates the unit is having an issue with one of its control circuits.
Aug 29, 2011 | VXI Corporation Blueparrott B250-XT...
What does it mean when a household battery charger flashes red then green? The charger is a SYNERGY DIGITAL rapid quick charger. I'm trying to charge new AA Energizer Lithium batteries.
When the charger light is changing from red to green that is a indication that it is charging the battery. When the charge is complete the light will stay green until the battery is removed or the charger is unplugged.
Jun 06, 2010 | Energizer Rechargable Battery with Charger
When charging my H710 bluetooth, do I have to wait until the green light goes off before disconnecting it from the charger? Thanks
No, you don't have to wait. The green light doesn't actually go out. It stays green until you disconnect the headset from the charger.
Jan 10, 2010 | Motorola Mobility H710 Bluetooth Headset
Motorola s9 headset not charging
I had the same problem but instead of a red light it would flash green twice and stay off. I could not find the original charger and another plug in charger would not work. I plugged it into my computer with a usb cable and after several seconds it started charging.
Sep 16, 2009 | Motorola Mobility S9 Headphones
It wont turn on
With the boom closed, insert a plugged in charger and make sure the unit is fully charged. The light will turn from amber to GREEN when it is fully charged. Unplug the charger and open the boom. It is now "on".
Aug 23, 2009 | Motorola Mobility H700 Wireless Headset
How do I reset s9....the green light stays on constantly and I cannot connect at all.
If you guys haven't found a solution, you might want to try this out. Have your S9 charger hooked up to the unit and plug the charger into a surge protector. Flick the main switch of the surge protector on and off a few times and it should turn off the unit. Then turn on and pair if need to and it should be fine. Hope that works for ya!
Cpl. Ramos
Jun 24, 2009 | Motorola Mobility S9 Headphones
Yellow / green light will not go off when charging
Its likely the batteries will take at least several hours to fully charge, if not more. NiCad batteries are slow charging and usually need 4-6 hours for a full charge. Keep them on longer or even overnight but make sure you remove them in the morning. You will probably find the light turns green after 4-6 hours of charging. If lights stay yellow and green after 12 hours of charging, it may indicate a fault in the battery itself where it will not accept a charge.
Jun 18, 2009 | Ryobi Multi-Volt Battery Charger
Peg perego 12v charger question
The green light means it is ready to use. If the battery is bad though, the light will still be green.
Mar 07, 2009 | Peg Perego 12 Volt Rechargeable Battery
My motorola H700 keeps staying red when charging
Wait, how long have you waited for it to charge? It's supposed to stay red until over 80% charge, then switch to yellow. When it is fully charged, it goes to green. When you mean it stays red when plugged in, have you waited the 2 hours?
Jul 10, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility MOTOROKR S9 Wireless Headset for Bluetooth-Enabled Cell Phones - Black/Red Logo
1,317 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
