Lcd tv wont let me view pc input
I have a samsung lcd tv that showed the computer no problem but for some reason it now says format not supported i dont know if its something to do with computer settings of the tv please help
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 88 Answers
First, make sure you do not have a bad cable going from the PC to the TV.
On your computer try the following:
Go to START, CONTROL PANEL, DISPLAY PROPERTIES
Make sure you have the secondary monitor enabled.
Set the screen size for the secondary monitor to 800 X 600
Go to ADVANCED PROPERTIES and make sure the refresh rate for the secondary monitor is set to 60HZ.
These settings on the PC should make the picture compatible with most all TV monitors. If the problem still persists then you may indeed have something wrong with the TV.
Posted on Jan 08, 2009
CONNECT I PHONE TO VIZIO TV USB PORT AND WATCH NETFLIX.
Vizio doesn't support phone connect - only USB drive (ie thumbdrive type) - With correct USB, TV will show USB as a 'Source' - and if selected will show the files on the USB, but can only open / view folders, images, and video types.
Nov 25, 2014 | Vizio E421VO - 42in Lcd 1080p 60hz Hdtv
Eh5000 wont play movies on usb stick
The TV can only play a specific format of video. You may be using MP4 files while the TV can only view 3GP or FLV formats; just try downloading a converter (I've used FLV Converter on Windows XP for years, works fine and very simple) and changing the file format.
Jan 30, 2018 | Samsung Electronics Samsung 40" EH5000...
I am trying to hook up my Dell inspiron 1520 to my viewsonic n2750w tv. Is there an easy way to do this?
Yes there is... You are going to need a VGA cable and an 1/8 audio cable (for sound)
http://support.dell.com/support/edocs/systems/ins1520/en/om_en/pdf/UX8623D.pdf - On page 29 it shows a picture of the right side of your computer. You will hook the VGA cable to the VGA port (Number 8 on the diagram).
The on your tv you will hook it up to the vga port as well. Page 7 of the following document shows a pictures of the back of your tv. You will hook it up to "L" on the diagram. Be careful to not bend the pins in the connector. http://www.viewsonic.com.au/support/manuals/files/LCd%20TV/N2750w%20User%20Guide%20English.pdf
Switch your tv over to the PC input by clicking the "Input" button. Then make sure your PC is sending a signal, you might have to hit the function key to switch the view.
Mar 05, 2011 | ViewSonic N2750w 27 in. HD-Ready LCD...
I have a Samsung SL620 digital camera with a Lexar 4GB SD card. It plays great videos and I am able to view them on my computer. However, when I put the SD into the USB of my Samsung LN46C630 LCD...
Probably because the tv doesn't have the correct circuitry to play videos. If you have a VHS recorder connected to the tv, you could download the video to a tape and play it that way. I have a Dish Network HD DVR. It has a usb connector allowing me to download to the DVR and play slide shows and videos.
Sep 15, 2010 | Samsung SL620 Digital Camera
I have a Samsung LCD TV, model # LN40A450 with a PC input. I connected my Dell Vostro 1310 laptap to the PC input and I consistently get a "Mode Not Supported" message on the TV screen. Why? I had a...
You TV will only accept specific signal formats (modes) through the PC input. Check you user manual for compatible modes. You then need to set screen 2 (your laptop VGA output) to 1 of the compatible formats (PC display settings). A common format/mode example would be 1024 x 768. Try it out and see if you get a picture. You can then increase the resolution 1 at a time to find the best format/mode for your purposes. I hope this was of some assistance.
Dec 29, 2009 | Samsung LN40A450 LCD TV
Samsung 40" lcd - Connecting to PC saying 'MODE NOT SUPPORTED'
First of all, check that the TV is set on PC input when you use PC video input at the back.
Then you may also need to go to video and display properties>>settings, from control panel (personalize on Vista).
There lower down resolution and ensure that frequency is set the same as tv.
Jan 02, 2009 | Samsung LN-S2651D 26 in. LCD Television
PC WON'T DISPLAY ON MY SAMSUNG lcd PC INPUT
I have been informed that the VGA cable may need to be connected in one particular direction if it has a ferrite module built in. Simply connect the cable the other way around and that may solve your problem. Apparently this only applies to Samsung LCD's.
Feb 22, 2008 | Televison & Video
Unable to use intex external TV tuner with acer 19''
Frontech external Miracle TV tuner not working with LCD(ACER 15") monitor. Error msg "input format not suppoting". But CRT monitor (samsung 14") is working with the same.
Pl give advice mr.reghu@yahoo.com
Jan 11, 2008 | Acer AL1916W 19" LCD Monitor
Not supported mode lcd tv samsung lnt4061f
with the PC input or analog SVGA the only 16:9 resolution it supports is 1920x1080, which can be difficult for some older systems to handle. However, on HDMI it should support all the standard HD resolutions.
Dec 29, 2007 | Samsung LN-S2651D 26 in. LCD Television
Televison & Video Logo
673 people viewed this question
Top Televison & Video Experts
