Question about Gateway 830GM PC Desktop
Motherboard wiring My husband was trying to replace the motherboard on my Gateway 830GM computer. Now he can't remember how to rewire it. Do you have a wiring diagram for 103390 Intel (Augsburg) 915G Motherboard No CPU R0?
  • stockfamily1 Jan 06, 2009
    The attachment in your post is not working. Could you please try and send the wiring diagram again?
    Problem Solver:
  • 6 Answers
Motherboard wiring - cba3c97.jpgThis is the diagram for 103390 Intel (Augsburg) 915G
Posted on Jan 06, 2009
Motherboard connections (to front panel)
remember the colored wire is +, the + and - should be printed very small on the board near the connectors as well as what they are example (HDLED is hard drive LED) or (PWRLED is power LED) or (PWRSW is power switch) these are examples yours may differ slightly
Jan 31, 2013 | Gateway (4000811) Motherboard
When I power up the computer, nothing is on the monitor, it is a black screen. what do you think could be wrong?
First off you should check all of your cables to ensure they are in fact connected correctly.
If they are all connected, then your video card has probably kicked itself.
If you have a video card, try taking it out and using the onboard video.
If you are just using the onboard video, then you're probably going to need to replace the entire motherboard.
Feb 24, 2011 | Gateway 830GM (RB830GM) PC Desktop
I have an 830GM and am suspicious of a hard drive crash or a motherboard failure and was wondering how to diagnose?
try replacing or swapping the hard drive with another machine and see if it happens again and on which machine if both machine's crash both MB and HD could be bad, If your machine with different HD works fine then it most likely was the HD If not then the MB might be at fault
Jan 24, 2011 | Gateway 830GM PC Desktop
I have a Gateway 830GM, I was wondering if it were possible to change the motherboard so I could put a newer CPU in it? I would like to buy a core 2 duo motherboard + CPU but I am not sure if I can do that...
Desktop computer cases have standard mounting holes and screw stand offs.
There are a huge range of motherboards available, select well known brands, my favorite are Gigabyte, Intel and MSI.
Select a motherboard with the features you require. If you are into gaming, graphics/CAD then select a motherboard that does not have a built-in graphics chip, and then you can get a high end graphics card.
Most likely you need a CPU and RAM with your new motherboard.
You may also need a newer ATX2 power supply if not then check the total power requirements of the new system, it needs to be at least 10 to 15% over the total power requirements so you don't stress the switch mode power supply.
Nov 19, 2009 | Gateway 830GM PC Desktop
Network card gateway 830gm
Well, you most likely will have to replace the network card, as you already know.
If your network connection is part of the motherboard, disable that one and plug in a new network interface card.
They are fairly plug and play....
Sep 21, 2009 | Gateway 830GM PC Desktop
Need new motherboard for Gateway 830GM
Looks like you have a p4 478 socket with ddr memory bad luck they only make 478 boards with ddr2 memory now. And when ever the power supply is as old as the motherboard it should be replaced to. Here's the specs I found on your computer http://www.shopping.com/xPF-Gateway-830GM. You could always try your luck on ebay good luck.
Jul 11, 2009 | Gateway 830GM PC Desktop
Ethernet driver for gateway 830gm
Insert computer serial number here to download the drivers.
Alternatively click driver download here: Gateway Support - 4659 Gateway 830GM
Click on the drivers, download them , then install them one by one.
Follow instructions from setup program.
Mar 04, 2009 | Gateway 830GM PC Desktop
All wires are connected but still nothing comes up on the monitor
are you familiar into the parts inside.?
if not, i will not advised you t do this.
-inside you can see the memory strip/module, resit it again on the slot.
if you are using an external video card, better to resit it too.
let me know.
Feb 17, 2009 | Gateway 830GM PC Desktop
3 twisted power led wires coming from the power button
Thats how, also see if the wires got any text on them , if they don't you will need to figure out what goes where and then connect accordingly to the picture.
Sep 27, 2008 | Gateway 830GM PC Desktop
Gateway 830GM PC Desktop Logo
804 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
