Question about RCA D61W20 61" Rear Projection Television
RCA D61W20B I have the same problems with my RCA D61W20B. I press the power button, it tries to power up 3 times, then nothing, but if you keep trying about 4 times, it powers up and works fine. I get no squealing noise, just hear a very light tick when the green light on the power switch lights up. When it does come on you hear the what I think are the tubes powering up, a very light cracking noise, kinda like the noise the older glass tube tvs made. This is a great tv when its working. I actually got it for free, it was being thrown out at a tv repair shop and I stopped to inquire about it. The guy said it was deemed to expensive to repair. It looks brand new, I brought it home. I tinker with stuff alot, so I removed the rear panels blew out some dust, dead bugs, unplugged and plugged in wires, then the set came on. When I do get it to turn on it will run all day with no problems. The condition it was in and the way it operates, it seems too nice to toss out. I have owned many RCA products and have had good service from them. Do you think this could be capacitor or weak solder joint?
  • 1 more comment
  • thomas31093 Jan 08, 2009
    I removed the rear cover and found that cp150 is puffed up on the top a little. What are the part numbers for each capacitor?
    Does anyone sell remanufactured deflection boards?
  • Anonymous May 07, 2009
    Same problem as the others with the deflection board.
    Is there a manufacturer? Where can I get the part?
  • RCA Master
  • 5,138 Answers
On the Deflection board CK capacitors cp150,cp114 cp120,If cp 150 is puffed up on top it is bad so replace all 3 capacitors 2200uf 16 use 25v and Two left are 220uf 35v Resolder pinns on flyback Transfomer and when re hooking board back up make sure you have second ribbon connector in good. Board next to Deflection is the SSB it has turners on it where you hook cable.
Posted on Jan 08, 2009
Testimonial: "Bad capaicitor, an easy fix. When removing the bad capacitor that was puffed up at the top, it turns out one side wasn't soldered well from factory. "
  • ladywinn
    ladywinn Jan 08, 2009
    Cost of Rebulit Deflection Board was 197.00 sure it has gone up since then, anyway replace those 3 capacitors and your set will be Fixed.Radio Shack might have capacitors 2200uf 25v on other 2 caps 220uf 35v.
How do I turn on my rca tablet I tried everything I put on the charger , I keep my hand on the power botton it still wont turn on please help me
You need to do a factory reset, follow these instructions:
Step 1. With your tablet turned off, press and hold the volume up (+) button. While holding the volume up (+) button, press the tablet's power button until you see the RCA logo with Nipper and Chipper on the screen. After a few seconds, the screen will change and you will see the Android bot on his back with a caution symbol above him.
Step 2. Now you are going to press and hold the tablet's power button, and without releasing the power button press down on the volume up (+) button. You should then see the screen below.
Step 3. Use the tablet's volume up (+) and down (+) keys to navigate to and select the "wipe data/factory reset" option. To select this option, press the power button.
Step 4. The tablet is going to ask you to confirm your selection. Use the tablet's volume up (+) and down (-) keys to navigate to and select "Yes - delete all user data." Once again, use the power button to select this option.
Step 5. At the bottom of the next screen, you will see "Data wipe complete." Press the power button to restart the system.
Dec 31, 2014 | RCA 7" Dual Tablet Travel Dvd Cd Jpeg...
Every time I try to print I get an error message as follows: Error Message 1700: Waste ink absorber is almost full. Press resume to restart. My manual says nothing about a "waste ink absorber" so...
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Nov 18, 2010 | Canon PIXMA iP2000 InkJet Printer
Will not turn on RCA model D61W20B
the tv won't turn on with the remote or with the power button
Jan 30, 2010 | Televison & Video
My Canon MP160 will not print. I put in new ink, but the light keep flashing and the numbers keep reading E...4...2 over and over. I tried turning it off and on but nothing works. What is the problem and...
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button.
(Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button.
(Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times. Finally press the Power button.
Jun 08, 2009 | Canon PIXMA MP160 All-In-One Printer
Hi i'm having problems programing my universal control
Make sure the device is on. Hold down the tv (or whichever device your trying to program) button and the power button simultaneously until the red light stays on solid. Then press the power button, it will flash one time, and keep pressing slowly letting it flash until the device turns off (mine took like 27 times, could be up to 100). Then press the stop button...and it is programmed.
Jan 03, 2009 | RCA Universal Remote 3 Device Remote...
Dvd code
Try preforming an automatic code search:
1) Make sure the device is on.
2) Hold down the DVD button and the power button simultaneously until the red light stays on solid.
3) Then press the power button - it will flash one time - keep pressing slowly, letting it flash until the device turns off.
4) As soon as the device turns off, press the stop button
If your the remote does not power the device off after cycling through all the codes - You will know this when the power button blinks and deluminates - then your "universal" remote will not work with the DVD player.
The best of luck to you!
Sep 18, 2008 | Televison & Video
Rca d61w20b tv
Some set display this problem because of bad capacitors in the powersupply. Take a good LOOK at all large caps on the board.
Aug 06, 2008 | RCA D61W20 61" Rear Projection Television
My canon ip2000 won't reset
Canon IP 2000 / reset Hi there you can try this.
1. Turn off printer
All the Best Pineworks
Apr 06, 2008 | Canon PIXMA iP2000 InkJet Printer
Programming the remote
1. Hold on TV and POWER simultaneously (light comes on), let go
2. Press POWER then CH+ back and forth (light comes on), when TV turns off
3. press STOP, code is saved!
Oct 22, 2007 | RCA RCR412C Remote Control
RCA RCR3273 3 DEVICE SNOWBOARD UNIVERSAL REMOTE
Answer for how to program the RCA RCR3273 3-DEVICE SNOWBOARD UNIVERSAL REMOTE:
Make sure the device is on. Hold down the tv (or whichever device you're trying to program) button and the power button simultaneously until the red light stays on solid. Then press the power button, it will flash one time, and keep pressing slowly, letting it flash until the device turns off. Then press the stop button...and it is programmed.
phoenixx100@hotmail.com
http://www.angelfire.com/journal/archer/index.html
Oct 12, 2007 | Televison & Video
RCA D61W20 61" Rear Projection Television Logo
352 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
