Question about Sony PlayStation Portable (PSP) Console
PSP power cord does not fit into socket
Not sure what caused this but the power cord does not fit into the yellow power socket anymore. Is is a simple case of replacing the yellow socket? If so, is it easy and can you refer instructions on what is required?
  • 73 Answers
Before trying to replace the yellow socket try this first.got this same problem before.when i remove my charger before the yellow plastic ring was left stuck inside the socket.so when i buy a new adaptor it doesnt fit to the yellow socket anymore,so what i did is i use a piece of pin,bend the end point little bit and try lifting that yellow plastic ring inside.when i finally remove it the new adaptor fits again like nothing happens.try this first.if your willing to change it i will give you the complete instruction on how to replace it.hope this one fix your prob.
Posted on Jan 06, 2009
I have a psp1000 it was fine until is started powering down all by itself. i put a brand new battery in it and shortly after it powers up, it powers down. What do i do now, and would it be very expensive...
Here are some instructions to help fix your problem.
Put the PSP down on a table with the LCD screen facing up.
  • 2 Plug the power cord of the PSP power supply into the PSP's power outlet. Plug the AC plug of the PSP power supply into an AC socket.
  • 3 Perform a hard reset on the PSP by pushing up on the power switch at the lower-right corner with your index finger.
  • 4 Count to 15. Release the PSP's power switch. Count to 30.
  • 5 Flick the PSP's power switch up with your index finger and release it. Repeat this procedure a second time.
  • 6 Wait as the PSP reboots, starts up and stays on.
  • 7 Remove the PSP power supply's power cord from the PSP's power outlet. Remove the PSP power supply's AC plug from the AC socket.
  • 8 Flick the power switch up with your index finger to turn off the PSP.
  • May 05, 2011 | Sony PlayStation Portable (PSP) Console
    Need Some Help, My Psp 3001, Turns Off On It's Own, While I'm Playing A Game Or Listning To Music, What can i do???
    Here are some instruction to help fix your problem.
  • May 04, 2011 | Video Game Consoles & Games
    My psp suddenly stopped working and will not charge wont turn on at all
    Hi Rneal_99,
    If your PSP suddenly stopped, check if the battery cover is fitted snugly because if it is loose even by just a bit, you will have charging issues and you will not be able to turn it on because the battery should be seated properly inside the battery slot. I had the same problem because my battery cover had a small crack which made it a bit loose. I was supposed to get a new battery cover but I was able to resolve the issue by using a piece of paper as a padding for the battery just to get a snug fit. It worked for me, I hope it works for you too.
    Other things to check :
    1. Is the battery dead (does not have charging capabilities anymore)? You can isolate this problem by using a different battery module. You can ask your friends to lend you their PSP2000 battery just for testing purposes. Inversely, ask them to use your battery with their PSP2000. See if they will have the same problem.
    2. Is the Charging Adapter broken ? Same trick here as with the battery, use your friends Charging adapter and vice-versa. Checking on these three things should isolate the cause of the problem.
    If the battery is busted and does not have any charging capabilities anymore, you need to replace it. If the Charging Adapter is the culprit, you should go to a professional to have it fixed. But, if both your battery and your Charger are working properly, chances are the problem lies internally. Specifically the Power switch, the Power Socket Connection module and maybe even the PSP's power supply module. You should seek professional help in these cases because these problems are quite challenging to fix even with the proper tools and the proper skill set. However, if the unit is still under warranty, Sony should cover this. You can call them at 800-345-7669. I hope I was able to help. All the best to you.
    Dec 07, 2010 | Sony PlayStation Portable (PSP) Console
    How to fix psp to charge it agian?
    Hi Ynnaalbasin,
    If your PSP is not charging at all, you initially have to check on three things :
    1. Is the battery seated properly in the battery slot? Also check if the battery cover is fitted snugly because if it is loose even by just a bit, you will have charging issues.
    2. Is the battery dead (does not have charging capabilities anymore)? You can isolate this problem by using a different battery module. You can ask your friends to lend you their PSP2000 battery just for testing purposes. Inversely, ask them to use your battery with their PSP2000. See if they will have the same problem.
    3. Is the Charging Adapter broken ? Same trick here as with the battery, use your friends Charging adapter and vice-versa. Checking on these three things should isolate the cause of the problem. If the battery is busted and does not have any charging capabilities anymore, you need to replace it. If the Charging Adapter is the culprit, you should go to a professional to have it fixed. But, if both your battery and your Charger is working properly, there is a possibility that the problem lies internally. Specifically the Power Socket Connection module and maybe even the PSP's power supply module. You should seek professional help in these cases because the power supply module is quite challenging to fix even with the proper tools and the proper skill set. However, if the unit is still under warranty, Sony should cover this. You can call them at 800-345-7669 I hope I was able to help. All the best to you.
    Dec 04, 2010 | Sony PlayStation Portable (PSP) Slim...
    The PSP won't recharge
    Hello :
    First you need to check the charger . If charger is working fine , then check the power cord . If the power cord is working fine , then the problem is that the battery is dead [ can't be recharged anymore ] . You need to replace the battery in a such situation .
    If it's none of that , then I recommend you to replace it , if you still have the guarantee . Or just take it to the service .
    good luck .
    please rate !
    Mar 30, 2010 | Sony PlayStation Portable (PSP) Slim...
    Cant downlode stuff off my computer onto my psp
    have you tried drag and drop, or copy and paste, or right-click and send to... be sure there in the right files and you have enough memory on your stick to do it. also make sure the files are psp compatable. if the problem still precists then update the driver for your psp.
    Dec 15, 2009 | Sony PlayStation Portable (PSP) Console
    Two of my lighter sockets that don't work
    It could definitely be a fuse - also check to make sure there isn't a coin in there. A penny or a dime fit in there just right and can cause the fuse to blow.
    Jul 11, 2009 | 2005 Volkswagen Touareg
    Psp wont power up .
    psp unable to restore games from memory stick
    Jul 03, 2009 | Sony PlayStation Portable (PSP) Console
    My tv only has a cable hook up how do i hook a dvd player with red white and yellow cords
    put the tv on av
    #yellow cord in yellow socket
    #red cord in red socket
    #white cord in withe socket
    now power the dvd
    #Yellow cord in yellow socket
    there will be 2 places for the red and white cords
    #the red and white cords must be inserted in the audio,
    # you will see them next 2 each other
    insert them you it will work.
    For More Info Email To ruanelectronics@gmail.com
    May 11, 2009 | GE 32GT740 32" TV
    My psp wont turn on!
  • Hi! TRY THESE TO SEE IF WE CAN GET YOU POWERED UP! :)
    Confirm the system is not in HOLD mode
    Make sure the PSP system is not in Hold Mode (in the down position). Slide the Power/Hold switch up to clear Hold Mode. Or try sliding the Power/Hold switch up and holding it there until the power indicator light turns off and the PSP system is completely turned off. Then try turning the PSP on again.
    • Confirm the backlight is ON
      Make sure the LCD screen's backlight is not turned off. If it is, press any button to turn ON the backlight.
    • Confirm use of only licensed products (AC Adaptor, battery pack and charger)
      The AC Adaptor, battery pack and battery charger must be licensed for use with the PSP system. All licensed products for use with the PSP will have the following logos displayed directly on the product and/or the packaging:
      pslogor.gif global_logos_psplogo_168x35.jpg global_logos_scealogowhite_60x73.gif
      If any of the products you are using does not have these logos on them, we recommend that you immediately discontinue the use of these products, as they void the PSP system's warranty, and can cause damage to the system. See compatible peripherals for the PSP system for a full list of supported products.
      There are some products that can be used with the PSP system that may not display our logos. Products such as San Disk 1GB Memory Sticks, or various USB cables, needs only to be genuinely certified. Look for the genuine certified logos on these products or contact the company which manufactures these products for more information.
    • Confirm the battery pack is correctly inserted
      Make sure the battery pack is in its proper position (see inserting the battery pack for details).
    • Try the battery pack only
      Unplug the AC adaptor from the PSP system. Make sure a charged PSP battery pack is inserted inside the PSP system. Turn on the unit. If you get power, then the problem may be with the AC adaptor and power cord.
    • Try the battery pack in a different PSP system
      If possible, try your PSP battery pack in a different PSP system. If your battery works on a different PSP system, it may indicate an issue with your PSP system.
    • Try a different PSP battery pack
      If possible, try a different battery in your PSP system. If a different battery pack does work on your PSP system, it may indicate an issue with the original battery pack.
    • Try the AC adaptor and the PSP battery pack
      Insert the battery pack and plug in the AC adaptor. If you still do not get any power, your PSP system may need to be sent in for service (see PSP Service for details).
    • Try the AC adaptor / power cord only
      Turn off the PSP system, unplug the AC adaptor, and remove the battery. Now plug in the AC adaptor to the PSP system with the battery removed. Confirm the AC adaptor and power cord are firmly connected to each other. Now make sure they are also firmly connected to the PSP system and the electrical outlet.
      If the PSP system powers on, the battery may need to be replaced.
    • Check AC adaptor and power cord for damage
      Visually inspect the AC adaptor and the power cord for damage. Do not use if frayed, cut, or damaged in any way.
    • Check the electrical outlet
      Confirm the electrical outlet that you are using is active (receiving power). Try using a different electrical outlet.
    • Try a different AC adaptor and power cord
      If possible, try a different AC adaptor and power cord. If a different AC adaptor and power cord does not work, the PSP system may need to be sent in for service (see PSP Service for details).
    • Confirm no unauthorized system software or downloads were used
      Confirm that you have not used any unauthorized system software updates or downloads on the PSP system. Use of such unauthorized firmware updates voids the warranty and can damage the PSP system.
    • WLAN turned off
      Make sure the wireless (WLAN) network function is not in use while charging. The battery pack cannot be recharged when the WLAN function is being used.
    • Power surge
      If you experienced a power surge, shortage, or a lightning storm in your geographical area recently, this may have affected the PSP system's power supply. Please contact Consumer Services below for information.
    Sep 03, 2008 | Sony PlayStation Portable (PSP) Console
    Sony PlayStation Portable (PSP) Console Logo
    125 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    marley mcelhinney
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
