Question about ASUS A8N-VM CSM (00610839133826) Motherboard
WORD2THEWHYS-USB PROBLEM Hey its me Shademon. I had usb problems and I was wondering the same thing you told me. That i should get a pci card with usb ports on it. Do you think that would work? My usbs back and front do the same thing. How do I know the Pci card i get wont do the same thing. Aren't all usb connections connected to the same thing, the motherbaord? Just holler at me when you got a solution. Thx........
  • 135 Answers
  • paul hughes Jan 18, 2009
    the pci card works on pci so it will not effect the onboard
Use of PCI-e x16 slot for non-video card
...........................................!O_O!...........................................................
WHY would you want to do that?
There is a PCI-Express x1 slot on the motherboard.
Black in color, and in-between the black PCI-Express x16 slot, and a white PCI slot.
Use the PCI-E x1 RAID adapter card in the PCI-E x1 slot, and a PCI-Express graphics card in the PCI-E x16 slot. Sheesh!
A PCI-Express slot is not an evolved PCI slot.
Completely different technologies.
PCI uses a shared Parallel bus architecture, while PCI-Express is based on Serial point-to-point.
So your idea of how to 'fix' your problem, is to use a PCI-E x1 card in a PCI-Express x16 slot, and a PCI graphics card in a PCI slot?
Completely backwards.
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
PCI-Express x16 slot uses the same lanes from the Northbridge, as the OnBoard video?
UTTER NONSENSE!
The Northbridge chip handles the Faster capabilities of a computer.
Handles the Processor, Ram Memory, and HIGH-SPEED Graphics.
HIGH-SPEED graphics is the Accelerated Graphics Port (AGP) technology, and the PCI-Express technology.
The Southbridge chip handles the Slower capabilities of a computer.
The PCI bus is one of those slower capabilities handled by the Southbridge chip.
The PCI bus is also a shared bus. This slows data down.
The AGP bus, and PCI-Express bus are Not shared. They also have a direct link to the Northbridge chip.
The PCI Bus has to go through the Southbridge chip, which has to go through the Internal Bus, THEN to the Northbridge chip.
OnBoard video, or Integrated Graphics, uses the PCI bus.
When you inserted the PCI-E x1 RAID card in the PCI-Express x16 slot, and a PCI graphics card in the PCI slot, BIOS just assigned another IRQ for the PCI-Express x16 slot.
(Interrupt Request)
No fancy technology going on there.
Backwards technology going on with a PCI-Express x1 card in a PCI-Express x16 slot, though.
I do not concur, and do not think that is a good solution, Kevin.
Regards,
joecoolvette
Aug 24, 2012 | Gateway Foxconn C51GU01 Motherboard
USB problems, 2x not supported. I am told I need
its hardware does not support USB 2, you have to buy an add-on PCI card with USB 2 ports, something like this:
http://www.startech.com/category/parts/usb-firewire/io-cards/usb-cards/list.aspx
Jan 04, 2010 | EliteGroup K7S6A Motherboard
Slow Wireless
I'll assume from the wording of your question that you are using a USB wireless adapter.For the most part you get better performance out of a PCI wireless card (and better range) but you should also run a scan and clean with this program to make sure that your performance issues aren't due to spyware or malware also.
Feb 21, 2009 | Dell Dimension 3100 PC Desktop
USB PROBLEM- Hey its me Shademon
shademon - I'm assuming that the drive letter change didn't help? If not, here's the deal. When you installed Vista over XP you may not have had all of the correct drivers installed. There is still an option. Try going to microsoft update and running cutom updates, down the lefthand side you should see a list of "hardware" updates download and install all of those, perhaps there is a driver update for vista. If that doesn't work you probably have a few ports that are direct soldered to your mobo, but you've probably also got a few in the front that run on a 4 - 8 pin cable to your board. You can also buy a card that should go into your vacant PCI slots (make sure it's vista capable) and you should be able to install the drivers/software direct via a CD with the new hardware check out these products newegg is pretty reasonable price http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=PCI+USB hope this helps let me know if I can answer anything else.
Jan 06, 2009 | ASUS A8N-VM CSM (00610839133826)...
ATI All-in-Wonder 2006 PCI... Problem:
theres obviously some conflict between the sound card and the all in wonder card. it is probably an old card that has trouble playing in stereo. i know of some issues with all in wonder and onboard sound cards. might i suggest a new sound card?
or it may be a problem with the composite cable. does it make a sound like when you unplug composites from a tv? try looking into that also.
Mar 28, 2008 | ATI All-in-Wonder 2006 PCI Express ,...
Adding a second graphics card?
Hey there sven155, If i were you , I would get get the video card for the AGP slot. The main reason is the interface is much more efficient, and as a result the dual monitor output would be better in quality than you can get out of a PCI card or any USB connection. Another option is to have your TV Wonder plugged into the computer via AGP only when you need it, therefore you would be switching one for the other (Inconvenient). Ideally video card on AGP, TV card on the PCI.
Alternately you can make the two work, just not simultaneously, and you would have to change settings in the bios to set one or the other as your primary video output.
Feb 12, 2008 | ASUS P4S800D-X Motherboard
How can i get my wireless rooter to work
Wireless cards come in many different forms: external USB devices, internal PCI Cards desktops, external PC (PCMCIA) Cards for laptops, and internal mini PCI cards for laptops.
What type of computer are wanting to make work with your wireless router? Laptop or PC?
Feb 01, 2008 | D-Link DI 514 Wireless Router (DI-514)
I have a dell dimemsion 8400 pci express i want to change my video card.
ya ,
i dont think this problem is due to your graphics card,
but you have decided to change it is better.
Dec 14, 2007 | ATI All-In-Wonder® 2006 Edition RADEON®...
USB 2.0 PCI Host Card CPQ5PHC
Let me know if your pc is running with winxp if winxp there will such problem doesnot exist. but in case of win98 you have to test drivers which is available in win98 and match to usb pci
follow this procedure
go to mycomputer
right click
select device manager
right click
click on scan for device
new hardware instalation wizard
search for new hardware
automaticaly update drivers
check one or more driver
try
and save which is compitable to your pci usb
Oct 16, 2007 | Micro Innovations MCNCPQ5PHC USB PCI Card...
Video export problem
what are you using the transfer the video USB or Firewire
Aug 30, 2007 | ATI All-in-Wonder 2006 PCI Express ,...
ASUS A8N-VM CSM (00610839133826) Motherboard Logo
81 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
