When filling the car with gas the car starts but then cuts off and once i get the car started it runs eratticly.
SOURCE: 1998 chevy malibu fuse question
Sounds like you have a ground problem, i doubt its in the sending units as both gauges are acting strange work, seeing that electricity likes paths of least resistance one gauge could be grounding through another. Bad grounds wreak havoc on electrical systems.
Fuel injection, could be a few things. Bad injectors, I forget the term for it but the unit that tells what injector to spray at the right time, or even regulator.
SOURCE: 02 malibu won't start
If car won;t start, but turns over it may be the anti theft system. Follow the directions in the manual-turn the key on and leave it for ten minutes or until the anti theft light goes out. Turn the ignition OFF and then restart the engine. If you continue to have problems with the anti theft system, disconnect the battery for 4 or 5 minutes and then reconnect. It seems to reset the system. Found this out after a mech. had worked on the system, disconnected the battery and told me it would be 400 to 500 to replace the module. Said no thanks and drove off to never have the problem again (so far!) 10,000 mile since.
SOURCE: 1998 chevy malibu turned car off at gas station want start back
sounds like an antitheft system malfunction - check to see if light stays on after you remove the key
