Question about HP LaserJet M4345 MultiFunction Printer
Hi how to set up network scanner in m4345mfp all in one
  • 2,692 Answers
Download and install everything you need including the instructuion booklet for the HP support website for yuo model . Link below:
Posted on Jan 06, 2009
I have installed canon colour network scangear in my laptop running on windows 8.1. How can i scan because i didn't get a short-cut to start the scanner. Am able to see the scangear on discover
Hi. Scan gear is just an interface to use the copiers as a scanner. You need and adittional program to scan (for example : acrobat Profesional allow you to create pdf files form scanner, also can use nitro pro. Or any program to scan. I prefer PRESTO PAGE MANAGER. . When scanning you select source : color network scan gear
Jan 19, 2018 | Canon Office Equipment & Supplies
Why doesn't wireless scanning work if initiated from the PC or from the MF212w printer?
hi . I'm almost sure that the toolbox only work on USB. for network scanning there is another aplication I thin is color network scan gear
Mar 14, 2016 | Canon imageCLASS MF212w Network-Ready...
Reseting HP Laserjet M4345Mfp
If you want to do a cold reset, then you must turn machine off. Turn machine on and when the memory count starts, hold down the ok key. When all three leds on control panel stay on solid, use the 9 button to advance through options. When you find cold reset press the 6 button, unit will restart with most settings back to factory. network card may not reset.
Mar 05, 2016 | HP Office Equipment & Supplies
Hi fixya i have presented this problem a few days
Go to Start\Programs\Panasonic and look for the "Network MFP Utilities"
There is a "Network Scanner Configuration" software that create
s a "Location" for the scanner. The location can well be a network drive or a shared folder on your computer.
Once you create the location, the scanner will pick it up automatically so when you want to scan, you will be able to select the destination (i.e. the location you created)
You can create several locations to be able to save scanned docs in more than one place.
Jun 27, 2010 | Computers & Internet
Purchased new Canon ImageRunner C2550... using as network printer and scanner. 3 computers on network, Canon 2550 recognized two computers no problem... cannot get it to recognize the third one. Third...
The network setting for the scanner driver may be incorrect. Check the IP address of your scanner and then set the IP address on the scanner driver.
1- The steps of setting the IP address may differ depending on your operating system.
For XP operating system:
Click Start > Control Panel > Printers and Other Hardware > Scanners and Cameras.
For windows 7 operating system:
Start > Control Panel > ... View scanners and cameras.
2- Right click on the scanner icon for your machine and select Properties.
3- Click Network Setting tab and select Specify your machine by address.
4- Enter the IP Address you confirmed from the snanner menu or ask your network administrator and click OK.
Hope this helps.
Jun 17, 2010 | Canon imageRUNNER C2550 Color Copier
Hp lj m4345mfp printer showing 13.31.00 fuser output paper late jam i am replace the fuser assy but problem is same
If you are using Windows:
  1. Click on Start => Settings => Printers and Faxes
  2. Locate your printer's name and right click on it and click "Printing Preferences"
  3. Under the "Main" (General tab in some other printer models) Tab, and under "Paper Options" group, select the settings for "Paper Type" Paper Size"
  4. Click "Apply" and the click OK.
Your values here will be the default values loaded when you click the print command in any programs in your computer.
Feb 09, 2010 | HP LaserJet 4350 Printer
Scanner is not working
have you set the network settings ? you have to set the ip's if is connected with a lan cable, or share it if is local (connected with the usb interface).
Jun 17, 2009 | Canon imageCLASS MF7280 Laser Printer
Connecting to the internet
Hi there, this one might help since the OS is Windows mobile 5. the settings on your handheld might be quite different but still this may work. Please turn on wi-fi. There is a small icon below for wireless simply tick that and it will turn on wi-fi. Once you turn it on it will detect available wireless networks or you may simply go to Start menu and select settings. Go to connections and select network. It will give you available wireless networks. If prompted for the pass key or encryption, use the encryption set to the wireless network you're trying to connect with. Once you input the correct key you should be good to go.
Hope this helps
May 15, 2009 | Symbol MC9090 Barcode Scanner
Imagerunner 5000s scanning problem
run the network scangear utility from the start menu. Click "discover scanner", when the discovery is finished select your copier and then click apply.
May 28, 2008 | Canon imageRUNNER 5000 Copier
HP LaserJet M4345 MultiFunction Printer Logo
211 people viewed this question
Ben Johnson
