Question about HP OmniBook 6000 Notebook
My cd rom wont close
My dvd rom i realy messed upp it wont stay closed
  • HP Master
  • 19,396 Answers
You need to replace the drive.
DVD RW costs $159.
Part number is F2107-69901 also enquiry here and look on Ebay, you find cheaper in there.
Posted on Jan 06, 2009
  • 22 Answers
Try change it for a new one. if you still have warranty send it in and get it fixed=P
    Scholar:
  • 86 Answers
There's a problem with the mechanism itself. Try to bring it to a technician for service and repair, but if it'll cost you much more than a new one, replace it! =)
Ciao and Good Luck! =)
Dell latitude c800 is not booting
wont boot or wont boot from cd rom ? its posted in cd rom questions
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Sep 07, 2012 | Dell Computers & Internet
Code 39 dvd drive wont even reconize but will open and close
Hi. This is a registry problem which pertains to DVD/CD ROM drive. Please follow the troubleshooting procedure below.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Jul 29, 2010 | Computers & Internet
My laptop (Samsung R60plus) DVD drive door stays open while powered on, but remains closed while shutdown. D OS recognises it, i can play cd and install programs while holding d door. Pls what can i do to...
The problem is the micro switch that opens the door is allways on.... try press it 10 or 20 times to unlock the switch or try to clean it.... It will work for sure.
Jul 07, 2009 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
DVD Drive door stays open
>One solution is to TAKE A SMALL PIN AND RESET YOUR DRIVE BY POKING THE PIN INTO THE HOLE BELOW THE DOOR..
If this doesnt solve....
You need to necessarily replace the drive..
Jul 07, 2009 | Samsung SC 152 Internal 52x CD-ROM Drive
CD Rom Drive opens and closes over and over won't quit
it happens often because of some materials or cd broken pcs try to clean it carefully
Apr 11, 2009 | Dell (0F027) CD-RW/DVD-ROM (Combo) Burner
Dics Drive Upgrade for Toshiba Satillate.
As far as i know thats impossible. Your optical diskdrive is made just for those speeds that you have on it. You cant change the manufacture settings and speed it upp, or make it to an dual layer disk.
Buy a new one whit the needs that u want and replace the old one. Its easy done and its not that expensive.
Good luck to you
Nic
Feb 04, 2009 | Toshiba Satellite A105 Notebook
Tje cd rom isn't working properly
your cd rom motor needs to be replaced..so it is better to take it to nearest service center...
Jan 04, 2009 | Gateway Computers & Internet
DVD had a jammed disc. Got it out but drawer stays open
You broke it. Spend $30 to buy a new CD/DVD reader/writer.
Dec 21, 2008 | Compaq (224130-001) Internal 4x CD-ROM...
Dvd/rom wont stay locked closed
its hanged and can't be taken out by mechanical pressure. The expert will need to un-screw its upper plate and hence after rotating motor you will get your solution.
Dec 17, 2008 | Computers & Internet
My cd/dvd opens then closes
> I've already replaced it once
Well, I've seen CD-drives that would re-open, when you try to close them -- it is _falsely_ detecting a "jam" as the tray is closing, and then just re-opens the tray, rather than "forcing" itself to close.
Replacing the CD-drive is the only way to fix that type of "false-positive" jam-detection conditions.
But, since you've done that, either you were unlucky-enough that the replacement drive was also "defective", or, you have a computer-virus on your computer that is maliciously issuing commands to the CD to "open-the-tray".
Sep 20, 2007 | Compaq (224130-001) Internal 4x CD-ROM...
HP OmniBook 6000 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
