Question about Orion STV2763 27" TV
Picture is to low
The picture is great but the bar on the bottom that flashes scores across on espn or any other channel that does you can read. It seems that the picture needs to be adjusted up.
    Sergeant:
  • 227 Answers
Some sets have adjustments on the board for vert lin/verthold you may have to take the back off to access. May need to blow out dust to see identification of adjustment pots. will be marked on the board as 'vert'. These controls are affected by humidity and dust. will need a mirror to look at the picture while you make adjustment. Do not over adjust make small 1/8 or 1/4 turns either direction until the picture is as you want it.
Posted on Jan 06, 2009
Screen display mode
Because the broadcaster is giving you the bars at top and bottom there is nothing you can do except use the different aspect or screen formats that are on your TV. Please take a few moments to rate my answer. Thanks....
Nov 20, 2009 | Televison & Video
Picture is too big for the screen
go to page 37 of the manual and read through to RESET TO FACTORY SETTINGS
Thanks for using FIXYA
May 30, 2009 | Syntax Olevia 532H 32 in. LCD HDTV
High def programs
You need to change the setting on your tv to see the whole picture on those channels (look for display button)
Dec 13, 2008 | Televison & Video
Mitsubishi wt-42311 picture is to long.
Its all in you remote.you need to turn off cable box and then tv. then turn on box from remote and then tv. I have the same problem when someone in the house turns it on incorrectly. make sure you can see the network sign in corner of tv complete then you have it. you may need to do it a couple of times. tv off first then cable box. or tv on then cable . its been awhile since i had the problem
Mar 24, 2008 | Mitsubishi WT-42311 42" Rear Projection...
Samsung DLP HL-P5674W Screen is stretched at the top and bottom...
did you ever find out the problem , mine is doing the same thing,
please email highltv3@aol.com if you can help
thank you so much
debi
Mar 05, 2008 | Samsung DLP HL-P5663W 56" TV
Cant read espn scores
same problem...screen seems to be to long. i cannot see all objects on bottom...no solution in the menu...help plz
Dec 07, 2007 | RCA 27F530T 27" TV
Picture too tall. How do you shorten?
Picture displaced vertically, picture too high or low
This problem was cured by entering the service mode (menu then 4,7,2,5), then pressing the green fastext button to access geometry settings, selecting VP1 (vertical position) and adjusting as necessary
Very low width and bowed verticals,no ew correction. R626 o/c
C630 (390nF, 300v) faulty, located next to scan socket. This fault can also be caused by R629 (2R7 fusable) o/c. In my set C630 was dry-jointed but not faulty. Check generally for dry joints in the E/W and PSU areas. Note that R629 is a safety component
Nov 23, 2007 | Sylvania SRT2432S TV
Bottom of picture is cut off
Usually when the vertical starts shrinking slowly, it is due to capicators getting out of tolerance in the vertical output section of the chassis. If it can be adjusted out through a service menu, you'll probably need a tech with the right equipment to perform it.
Jan 01, 2007 | RCA F27440 27" TV
Picture slants right to left
Hope you have fixed this problem by now, if that tv is unserviced, I mean if nobody has ever opened it, it could be a problem with the positioning of your tv, just tilt the tv in different positions and find out the position in which it will show the right fit. If it is serviced, especially yoke is changed, this is rare, it could be because the position of yoke is not aligned properly.
Dec 16, 2006 | Philips 27PT5445 27" TV
Orion STV2763 27" TV Logo
82 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
