Question about Cameras
The lens on my kodak P712 camera constantly retracts and extends
This problem has just started, I checked the battery is ok. When I turn the camera on, the lens starts going in and out...I have to keep turning it on and off inorder to maybe take the picture. I have had this camera for about 3 yrs.
  • 1 more comment
  • Anonymous Jan 12, 2009
    on off on off , when power is on
  • Anonymous Jan 14, 2009
    The power, or lens, on my Kodak P712 also constantly cycles off and on.  I have replaced the battery, but problem is something else....?  Help.
  • deemorgan Jan 30, 2009
    I have the same problem and just off the "live chat" w/ a tech who suggested a new battery but mine appears fully charged and I don't think that is the problem but?
  • 36 Answers
This is due to a fault in the circuitry inside the camera that controls the retraction/extension motor. Unfortunately, this needs to be fixed in a camera workshop.
/Chris
Posted on Jan 20, 2009
Why does the kodak p712 camera shuts on and off will not let lens stay out?
Your P712 has the P-series powerswitch problem. Can be solved. Look here: http://www.dpreview.com/search/forums?query=p712+power+switch&forum=1011
Use WD40 or Deoxid to solve it, mostly for the longer duration. If necessary use again.
Aug 12, 2014 | Kodak EasyShare P712 Digital Camera
Tip
Lens Error
Try removing and replacing batteries to reset the camera. Ensure that batteries are fully charged.
If that does not clear the problem, then the lens error is usually caused by mechanical faults concerning lens assembly. This happens because there is dirt inside the lens (sand dust), or one part in the lens assembly is bad or went out of place.
Because of this he lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
If if does not extend tapping gently the back of the camera, and if it does not retract helping lens back in while turning camera respectively on and off.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
on Jul 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Kodak easyshare Z650 lens extends and retracts
I only can think of two reasons. The first, the battery does not have enough power. As a safety precaution it shuts itself down, to avoid damage to the saved pictures. Because if the voltage is to low, it can't write with 100% accuracy.
Second: something is blocking free movement of the lens. This could have a cause inside the lens barrel, and you won't see a thing. It also could be a minute damage on the outside of the lens. Or what sometimes happens while putting the camera on, you touch the lens barrel. I assume you did remove any lens cap attached to the camera.
So if you can't see any damage to the lens barrel, charge the battery and try again.
Jan 30, 2014 | Kodak EasyShare Z650 Digital Camera
The lens extends and retracts constantly after turning it on. Battery has a good charge.
The lens error is due to failure of the lens control system. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
It is also possible that the mechansim is struck .Use some high pressure jet air to blow between the lens to dislodge any sand particles struck inside. If none of these works then you can think of taking consensus with the service centre.
get estimate before you decide. It will be good to have it checked at any camera/Kodak service as you do not have to run around for spares.
Mar 13, 2011 | Kodak EasyShare P850 Digital Camera
When I power up the camera the lens opens and immediately retracts and the camera shuts off. I've attempted to push every button while turning on the camera to no avail. I also held onto the lens when it...
Have you made sure that the batteries are LiIon and fully charged? I had a similar problem with a Kodak Easyshare camera that required the higher voltage LiIon battery pack rather than alkaline AAs which will fit in there but is not exactly right.
Feb 09, 2011 | Kodak EASYSHARE M763 Digital Camera
Kodak p712 shuts of and lens retracts
try resetting the timer to shut off the camera after a period of inactivity to a longer time. It seemed to work for me
Apr 06, 2009 | Kodak EasyShare P712 Digital Camera
Kodak easy share z612 will not turn on to take a picture
When the battery dies, usually the camera will retract the lens if possible. If the battery is so dead the lens can not retract, I would recommend trying to charge or change the battery. Or try to turn the camera on, and then manually shutting it off if you can.
Nov 16, 2007 | Kodak EasyShare Z612 Digital Camera
Lens won't open and retract.
It sound like a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 03, 2007 | Kodak EasyShare CX7530 Digital Camera
Kodak easyshare CX7430
My Kodak camere was really not dropped. I put in new batteries and the camera only gives me one shot and I have to turn it off and try again. I can plug the camera into a charge cord and I can take all the pictures I want. Is it possible the 2 batteries are not enough to power the camera
Mar 28, 2007 | Kodak EasyShare CX7430 Digital Camera
Lens Error 25
Guess what I tried banging the bottom of my CW330 camera, as suggested by Timewarped, and the lens retracted and the "Lens Error 25" cleared. I can't believe it, you saved me about $80 in repairs. Thanks
Mar 25, 2007 | Kodak EasyShare C330 Digital Camera
Cameras Logo
204 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
