Try the below first, but you may require additional assistance after this:
First, test to make sure the Philips remote is working by trying to play a
dvd. If the remote control is working, then either A) your
TV is set to the wrong channel, or B) you have not selected the correct source on the Philips remote.
Look at how the cables run from the back of the Philips to the TV. In the back of your TV, the slot that the cables are plugged in to is usually labelled "AV1, "AV2, "Video 1", "Input 1" or something like that. Change the
television to the appropriate input/source channel.
Press the Source button on the Philips remote and make sure it says E1 or whatever the appropriate source is.
Then try changing channels using the Philips remote.
This does not exhaust every possibility, but you must check the above first to see if anything else might be wrong. If the above does not work, then I would double-check to make sure the
cable/satellite box is connected to the Philips correctly.
-Tha Mp3 Doctor
