Question about Champion G5NG853S Household Juice Extractor
Pulp splattered I tried my beaumark that was a Christmas gift but when I took it apart to clean there was pulp splattered everywhere inside with very little going in the pulp extractor. I'm reluctant to try again.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
Pour some water into it, at the very end.
Posted on Mar 01, 2009
Santos juicer
Couple of things to look at
1 check the grating blade. Maybe clogged therefore need cleaning or need replacing due to bluntness
2 motor may be slipping true to overload. Place fruit in a little at a time
hope this helps
Apr 16, 2014 | Juicers
My jack Lalanne juicer just suddenly stopped working.
Mine stopped working after only a few uses. It turns out that the safety microswitch button wasn't being depressed. The little button on the bottom of the pulp collector had broken off. (Image #1) I put a 1/4 inch piece of a shishkabob skewer in the hole before putting the pulp collector on. (image #2) It works fine now. It's still safe. The motor will not start unless the pulp collector (receptacle) is in place and locked in. Be sure to unplug the machine before doing this. 3717db6c-91bc-41ee-b452-1ed06578f280.jpgjack-lalanne-juicer-just-rgzqoe2q2f3mnxiw25vk3yhi-4-2.jpg
Mar 07, 2011 | Jack Lalanne Power Juicer 250 Watts
I have the beaumark juice extractor BM-473 it worked then i washed the removable parts now it wont work
the first solution is half right ... there are 2 hidden switches on the machine which are activated by shafts on the pulp container and on the top lid .if either is not on then machine will not work. possibly broke plunger on the pulp container ....or broken clip that holds the container in place
Jan 04, 2011 | Champion G5NG853S Household Juice...
Can't find the manual and have forgotten how to take it apart to clean it
Most juicers have a retention rod or side snaps that hold the top of the juicer in place. By loosening these, it will allow you to get underneath the juicer cap top. Once you have done this, you will have to remove the juice/ pulp wheel blade. Your juicer should have come with a two pin tool that facilitates this. Use the tool to loosen the juice /pulp wheel blade. Once you have done this, you should be able to remove the outer juice capture rim with that has the spout on one end. I hope this helps. Good luck and happy juicing.
Jul 18, 2010 | Juicers
I can't take apart my new indulgence by mistral juicer for initial clean. I was able to take off the clear top and pusher and the pulp container, but can't get the filter out or spout.
i have a mistral mss25 air conditiioner and i need to clean the filters is the only the 2 large square filters or is there another somewhere which needs cleaning?
Jun 27, 2009 | Juicers
How to clean the Jack LaLane Juicer?
the blade can be removed possibly with your hands, if you can manage to turn it, if not then find something that will fit into those little holes of the blade to turn it, and then take it apart, but remember in what order. to put it together: the grey thing with the spout attached goes on first, then the orange basket, then the blade, but don't turn it too tight, just look for the indicator marks and line them up with the arrows, then the black lid, and then the pulp basket.make sure that the black lid in the back, goes INTO the pulp collector, it is not very far, but if it is not done like this, then your machine will not work. then you raise and lock the bar into place and put the pusher into the feeding tube. hope that helps.
Jun 21, 2009 | Jack Lalanne Power Juicer 250 Watts
Cant grt it apart to clean
Take off the top part of the juicer that has the chute. You will see the blade and basket. The blade appears to be attached to the basket with three small screws but is actually screwed onto the basket by a large screw that protrudes out of the basket underneath the blade. So the trick is to unscrew the blade, turning it to the left by using maybe a small screwdriver that you will have to put into one of the two small holes that are on the blade surface and pushing the blade to the left. This should loosen the blade and then you can just unscrew the blade off the basket. Once you get that blade off, the rest of the juicer comes apart. The newer models come with a little tool with a couple of arms that go down into those holes and loosen the top. Good luck.
Jul 22, 2008 | Jack Lalanne Power Juicer (Stainless...
Pulp gets stuck in Champion
Feed it slower. Mix up the items, it likes things mixed up. You can add water near the end to clean it out.
Jan 20, 2008 | Champion 2000+ Household Juice Extractor
Wet pulp
There are two almost identical cone-shaped parts, one with metal screening and one solid dark plastic (I'm going by the parts color appearance of my 8003 model). Be sure you're using the one with the screen, otherwise the juice has nowhere to go but out with the pulp.
Jan 05, 2008 | Omega 8005 Juicer
Champion G5NG853S Household Juice Extractor Logo
149 people viewed this question
Top Champion Juicers Experts
David Payne
David Payne
ray gallant
Are you a Champion Juicer Expert? Answer questions, earn points and help others
