Question about Dryers
Kelvinator series 500 clothes dryer timer fault
I have a Kelvinator series 500 clothes dryer. The clockwork timer is sticking (failing to tick). How do you get it out to clean it?Thanks,James
5 Suggested Answers
shinn8
  • 85 Answers
SOURCE: Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
Posted on May 27, 2009
  • 38 Answers
SOURCE: sears kenmore dryer 70 series will not dry clothes, unit does not
faulty heater element try replacing it at rear panel bottom left panel behind drum at rear cheap to mend yaself
Posted on Aug 25, 2009
SOURCE: Clothes dryer troubleshooting
my kenmore dryer keeps on drying after the alotted time has expired, i think the timer is the problem. how can i verify and fix this??
teddy
Posted on Sep 20, 2009
  • 180 Answers
SOURCE: 70 series dryer was workin put in clothes started
Check thremal fuse on the exhaust duct.  It is a safety which blows when your exhaust temp reaches 250 degrees.  It is the one with 2 blue wires going to it and is located on the exhaust duct.  If it is blown you will also need to replace the operating thermostat which is right next to the thremal fuse.  Then check your dryer venting for obstruction as this is often the reason the fuse blows in the first place.  Also make sure that power is getting to your dryer.  You might have blown a breaker.
Posted on Oct 25, 2009
Testimonial: "will try that thank you!"
heatman101
  • 43501 Answers
SOURCE: The dryer stopped working in the middle of drying
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 28, 2010
Kenmore 400 series gas dryer doesnt dry clothes
Replace timer, if you are sure that it is not working.
Do an internet search for kenmore driver parts and get dozens of hits.
Aug 03, 2014 | Kenmore Dryers
White knight tumble dryer timer sticking at 80minutes and not moving to cool clothes
Have had the same problem with the timer sticking on the model and the same time interval, now don't trust it's safe to use at any setting over 60minutes
Jan 06, 2013 | Abbaka White Knight 44AW Electric Dryer
Bought kelvinator dryer series 500 second hand,how does it work? are there any instructions available
Ifyou need to find parts or manuals for the dryer, go to Google website and typein you model number and then type in what you need manuals or parts.
May 11, 2011 | Dryers
Nob for setting time keeps ticking after dryer has stopped cycle
the timer dial you set is at fault. A replacement will be needed soon for it will just quit some day soon
Jun 30, 2010 | Dryers
Dryer Won't Start
May 27, 2009 | Kenmore 73952 Gas Dryer
teddy
Oct 27, 2007 | Dryers
Dryers Logo
43 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
