Question about Pentax K20D Digital Camera
Can i use metz 45 ct 1 on pentax k 20 d - Pentax K20D Digital Camera
Yes you can use the CT45 flash, with a flash sycnh cord or with a pentax dedicated hotshoe SCA adapter if you want it to operate in TTL mode! kinda expensive
vaidikar@gmail.com
Posted on Jan 06, 2009
  • 10,515 Answers
U cant use that :((...
Refer to one of the links :)
http://photo.net/medium-format-photography-forum/00RXN2
Thanks.
2 Suggested Answers
kalaci
  • 30 Answers
SOURCE: can i use metz 45 ct 1 with pentax k 20 d
The trigger voltage of Metz 45-CT1 Ser No above 534 000 are under7V, that is absolutely safe. But below this Ser No that can be anywhere around 200. This not necessarily means the flash will damage the camera, but consult the user's manual.
If you were intended to ask how to connect the flash to the K20 D, then you can use a hotshoe-to-PC adapter.
Posted on May 22, 2009
I need a manual for a metz 45 ct-5 . Can any one help?
please try this link below. its one from fixya!!!
www.metz.de/en/photo-electronics/instruction-manuals/mecablitz.html
Aug 19, 2009 | Cameras
Metz 45 CT-1 Outup Calibration
During the flash impulse the "photocell", actually a phototransistor, charges a capacitor with current, proportional to the reflected light intensity. As soon as the voltage on that capacitor reaches the trigger voltage of a four-layer diode (which, in fact, is playing a role of a PUT) that turns on and triggers the quench thyristor. There is a trimmer potentiometer in the four-layer diode circuitry, which sets the trigger voltage. You can try to fiddling with that. But the culprit of the misalignment easily can be in any of the parts in the above described circuitry.
May 18, 2009 | Metz mecablitz 45 CL-4 TTL Flash
METZ 45 CT 5 S O S
Check the polarity of the batteries.
With the batteries removed you will be able to see small
+ and - alongside each of the six connectors. Make sure the +
of the battery connects with the + connector. Similarly check the -
connections. With the batteries inserted (but without the plastic cap being fitted) you should see the ends of the batteries. Three positive ends (all in a row) and three negative ends.
If one, or more, has been inserted with the polarity reversed it will stop the flash from working.
It can also cause the handle to overheat.
May 02, 2009 | Metz mecablitz 45 CL-4 TTL Flash
AC Power Supply for Metz 45 ct5
Hi daf4,
I have a circuit diagram for the 45CT-5 and the flash unit as well. The voltage is 360V DC, which goes straight across the flash tube. The top pin is positive, when the notch in the socket is on the right hand side, i.e. towards the back of the flash.
I'm also looking for a circuit diagram for a 45CL-4, if you know anyone who has one.
Regards,
Neil
Feb 07, 2009 | Metz mecablitz 45 CL-4 TTL Flash
Metz mecablitz 45 ct 1 and Nikon D-90
The trigger voltage of the 45CL-1 is about 12V, so it should be safe to connect directly to the hot shoe with an adaptor, or to the pc soclet, if the D90 has one. If the D90 is anything like my Canon 40D, which can stand about 30V on the hot shoe, then all the 45CL series will be ok, as they have trigger voltages between 9V and 12V. The 45CT-5 has a trigger voltage of 15V and works well on the 40D. I use 3 different Metz 45 models with my 40D and all work well on automatic, where the flash sensor itself controls the light output.
Jan 26, 2009 | Metz 45 CL-1 Flash
Can i use metz 45 ct 1 with pentax k 20 d digital slr camera
Jan 06, 2009 | Pentax K20D Digital Camera
Metz 45 CT 1
I had that same problem also, but mines was temporarly. Ik think the condensor inside the Metz has to regeneratie (recover) itself by using with a full charged fresh batteries. The high freq. sound is normal. (although not to loud) after a 5 MINUTES the orange bulb should light up. How more u used how better the start-up time. My old Metz start-up time was around 40 sec. and now ot is within 7 sec.
Jun 22, 2008 | Metz 45 CL-1 Flash
Pentax K20D Digital Camera Logo
157 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
