Question about Pentax K20D Digital Camera
Can i use metz 45 ct 1 with pentax k 20 d digital slr camera
    New Friend:
  • 30 Answers
The trigger voltage of Metz 45-CT1 Ser No above 534 000 are under7V, that is absolutely safe. But below this Ser No that can be anywhere around 200. This not necessarily means the flash will damage the camera, but consult the user's manual.
If you were intended to ask how to connect the flash to the K20 D, then you can use a hotshoe-to-PC adapter.
Posted on May 22, 2009
Can metz 45CL-1 support Nikon D5100?
To use Metz 45CL-1 with Nikon D5100, you need use in apperture priority mode (A), adjust same ISO and apperture in Flash and Camera (Ex: ISO400 and F: 5.6) . The flash adjust light intensity to mantain correct exposition. You need use an adapter to conect Sync cable in your camera.
Nov 13, 2015 | Nikon D5100 Digital SLR Camera With...
Can I connect a METZ 45 CL-1 to my CANON D600
Yes, this is the way the flash can be used with the contemporary digital cameras. The camera has to be set to Full Manual mode (in point of the exposition), Exposure Time to 1/100 sec (or the shortest exposure that still assures full opening of the shutter). Aperture on the camera must suit the working aperture on the flash, also ISO speeds must match. The computer in the flash measures the reflected from the subject light and quenches the flash, creating the correct exposure. Mecamat sensor, having narrower reception angle and a sight, helps in achieving the correct illumination even on a relatively small subject. Sync voltage of Metz 45CL1 does not make harm to any digital camera, so you can use even the cheapest hotshoe-to-PC adapter available at many camera shops or you can buy one online. No need to spend much on sophisticated adapters.
Mar 31, 2015 | Metz 45 CL-1 Flash
Ttl connection to a metz 60ct4 or 45 ct-5
You have to use a special cable adapter for each type of camera.
These old flash units do not have adapters for current digital cameras. For old cameras the only place to get the adapters, is on ebay or from KEH.
Feb 10, 2014 | Metz Mecablitz 60CT4 TTL Flash
Safe trigger voltage for a d90
The Metz 45CT4 is borderline according to this list.
May 13, 2012 | Nikon D90 Digital Camera
Metz 45 CT-1 Outup Calibration
During the flash impulse the "photocell", actually a phototransistor, charges a capacitor with current, proportional to the reflected light intensity. As soon as the voltage on that capacitor reaches the trigger voltage of a four-layer diode (which, in fact, is playing a role of a PUT) that turns on and triggers the quench thyristor. There is a trimmer potentiometer in the four-layer diode circuitry, which sets the trigger voltage. You can try to fiddling with that. But the culprit of the misalignment easily can be in any of the parts in the above described circuitry.
May 18, 2009 | Metz mecablitz 45 CL-4 TTL Flash
Metz mecablitz 45 ct 1 and Nikon D-90
The trigger voltage of the 45CL-1 is about 12V, so it should be safe to connect directly to the hot shoe with an adaptor, or to the pc soclet, if the D90 has one. If the D90 is anything like my Canon 40D, which can stand about 30V on the hot shoe, then all the 45CL series will be ok, as they have trigger voltages between 9V and 12V. The 45CT-5 has a trigger voltage of 15V and works well on the 40D. I use 3 different Metz 45 models with my 40D and all work well on automatic, where the flash sensor itself controls the light output.
Jan 26, 2009 | Metz 45 CL-1 Flash
Can i use metz 45 ct 1 on pentax k 20 d
yes you can use the CT45 flash, with a flash sycnh cord or with a pentax dedicated hotshoe SCA adapter if you want it to operate in TTL mode! kinda expensive
vaidikar@gmail.com
Jan 06, 2009 | Pentax K20D Digital Camera
Metz 45 CT 1
I had that same problem also, but mines was temporarly. Ik think the condensor inside the Metz has to regeneratie (recover) itself by using with a full charged fresh batteries. The high freq. sound is normal. (although not to loud) after a 5 MINUTES the orange bulb should light up. How more u used how better the start-up time. My old Metz start-up time was around 40 sec. and now ot is within 7 sec.
Jun 22, 2008 | Metz 45 CL-1 Flash
Pentax K20D Digital Camera Logo
216 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
