Question about Neff 24 in. S5555X0GB Built-in Dishwasher
Neff S5555 - empties water but stuck in draining mode.
I have a two year old Neff S5555 which has stopped working. Although it successfully empties out all the the waste water it does not seem to want to finish it's wash cycle - getting stuck in a constant drain (with the pump running and impeller spinning to remove water that is not there). I have switched the machine on and off, reset the programme to no avail.
  • 1 more comment
  • colin marshall May 26, 2007
    I found another posting similar to mine which suggested a flood in the bottom of the machine.
    I wasn't convinced because my feet were dry but following the advice of tipping the machine backward 45 degrees I managed to create an indoor swimming pool.
    So, the anti-flood mechanism had triggered.
    The upshot is that my immediate problem of constant draining has been solved but the underlying leak that causes the flood is still lurking.
  • al40 Sep 30, 2008
    • Same again on a 3 year old S5457, although it does work one time in 10. Bizarre.
  • Anonymous Mar 29, 2014
    water does not empty, tub agitates, Is problem the selector switch or pump or other another item??
  • 883 Answers
If this machine uses an electrical-mechanical timer with cam switches, the try oiling the shaft bushings both for the timer motor and cams-the timer may be getting stuck because of dry or corroded bushings
Posted on May 26, 2007
  • kevstaa
    kevstaa Nov 01, 2013
    My Neff S5555XOGB/70 dishwasher started getting lairy the other night. I noticed that it was on for a long time, seemed to be stuck on a pump out water function no matter what i did, i could not get it to work...had a butchers on here and seemed to be the flood switch triggered so i took it out, tipped it back and let the bisto drain out....put it all back and hey presto..its alive again...my prob was the salt solution cap housing nut was loose.
  • kevstaa
    oh..and thanks fixya website!!!
Dishwasher will not empty water and has stopped Also a tap emblem has come on which I have not seen before
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 16, 2011 | Neff 24 in. S5555X0GB Built-in Dishwasher
I have a Neff Dishwasher S5446x0/29 FD 8109 460056. It started making a whirring noise and when I looked it was not emptying the soapy wash water. I stopped the machine and manually drained the water out....
if the pump is not emptying properly it will think its still full, they have a sensor in the bottom that tell the machine that the system is empty and to begin next cycle.
Jun 27, 2017 | Neff 24 in. S5456 Built-in Dishwasher
I have a Neff integrated washing machine, approx 9 years old. It is still taking in and draining water, although nothing else seems to be happening. The drum is not being moved (although I can move it...
A couple of possibilities here.
The drum belt could have off, or the motor is not working, possibly due to worn brushes in the motor.
Either way, it means the washer has to come out of the cabinet for you to check these things.
Please rate my solution .
Thankyou.
Jan 13, 2010 | Neff Washing Machines
Water wont fill
first of all, i'm gonna guess that the water supply under the sink is turned on.
the water you hear is the left over water from a previous cycle. there is always some left in the hoses after it drains, just like your washer.
this is 1 of 2 things. either your float is stuck in the up position or your water inlet valve is malfunctioning. the float is the quick and easy fix. the float is somewhere inside your dishwasher. it tells the water to stop coming in when it reaches a certain height, just like your toilet. it could look like anything, but most likely a cone or a little hat. just grab it and try to move it up and down. it should slide freely. it was probably stuck up and your handling will have solved the problem. we hope.
if the float was ok, the inlet valve needs checked or replaced. it is under the machine and has the water supply line hooked up to it. good luck
Nov 01, 2009 | Neff 24 in. S5543X2 Built-in Dishwasher
My dishwasher is not filling w water
check filter or drain hose it probably have a dirt,try to fill with water manually and turn on pump to dispossess water,if water not go out and pump work then you have dirt in hose or filter,if pump not work then pump is broken.
Jul 05, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
NEFF DISHWASHER S5443 STUCK IN TEST MODE
First try disconnecting the unit, completely from any power, for an hour or more, look in any control doors or access points for a small battery mounted to a board or in a holder, if you find one, take it out also, noting the positive and negative orientation.
If that doesn't do it, there are reset buttons under the tops or lids of some NEFF models, if there is an obvious lid after trying the no power trick, take off the top and look for a stand alone reset button.
If all that fails, write me back
Will
Nov 05, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Hotpoint sdw dishwasher
It is possible drain pump blocked, you need to empty d/washer manually, check inside drain pump which is at end of drain hose, always isolate d/washer from power before attempting any work on it.
Aug 14, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Dishwasher stuck on "drain"
not easy to fix - it has a leak. the tray at the base is full of water which ooperates a float which switches drain pump on. remove front panel at bottom front and mop out water or tilt backwards 45deg and water will run out. leak is usually main pump
Mar 18, 2007 | Neff 24 in. S5543X2 Built-in Dishwasher
Neff 24 in. S5555X0GB Built-in Dishwasher Logo
1,781 people viewed this question
Top Neff Dishwashers Experts
vince
Marvin
Marvin
Lawrence Oravetz
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
