Question about Vehicle Parts & Accessories
AGII professional series keyless entry
I bought a 1998 Mazda MPV 4WD Sport have a box under my dash that says Auto Guard on one side & AGII professional series on the other side. I think it's an alarm but I am not sure. I am wondering if you know how I can get a hold of the original manual for it online?
    Welcome Back:
    Visited the website for 2 consecutive days.
Here are the key points from the Autoguard Professional Series Security System AGII manual:
Automatically arms after 1 min when engine off and doors closed.
When red light flashing, engine is immobilised.
When PIN is entered, green light goes solid.
To toggle sounding alarm:
With greed light solid, press number 2 four times.
Red light flashes once and system gives 3 quick beeps. This is on.
Red light doesn't flash and system gives 2 quick beeps. This is off.
To toggle chirp mode:
With green light solid, press number 3 four times.
3 beeps and one red light flash. Chirp is on.
2 beeps and no red light. Chirp is off.
To change PIN:
With green light solid, press number 4 four times.
Red and green light both come on. Enter new PIN.
After fourth digit is keyed, the red light goes out.
Old PIN is no longer valid. Remember your new PIN!
To engage valet mode:
With green light solid, enter PIN.
Green light flashing indicates valet mode.
System will not immobilise until PIN is re-entered.
Green light will be solid again once system is re-activated.
Posted on Nov 27, 2015
SOURCE:
  • 22 Answers
SOURCE: mazda rx8 alarm
Search through the area in the footwell of the drivers side. There will be a very small button. This is a valet/progaming button that is on all aftermarkets. It may be by itself, it may be connected to the brain unit, or it could even be attached to the alarm antenna, which is usually on the windshield. You need to press this button when turning on the car some alarms you need to hold the button down others you just need to press it. This will shut off the alarm until it is reactivated with the key fob.
Posted on Dec 04, 2008
insanegtp
  • 112 Answers
SOURCE: i cant cut off my alarm and car wont start
is ti and aftermarket or factory system, if aftermarket look for little black button under dash or button on antenna, turn key on and press for one full second, if aftermarket unlock door with either trunk or passenger side and try again...
Posted on Jan 26, 2009
outdoorsman5
  • 631 Answers
SOURCE: Keyfob not working in my 2001 Jeep Cherokee Limited
Could be the battery in the Keyfob. Also could be a fautly keyfob itself.
Posted on Jul 29, 2009
MECP Guy
  • 344 Answers
SOURCE: bulldog m200 just stoped working
If it is the same brand and model you will not have to rewire anything
Posted on Sep 29, 2009
SOURCE: crimestopper keyless entry remote wont unlock or lock anymore changed battery still wont work
need to program a new remote to keyless entry system it is crimestoppper cs835 rke
Posted on Dec 16, 2009
1998 mazda mpv all sport 4wd transmission control module. Where is it located?
Hi,have a look on u-tube,if im looking at the right part it seems to be on the inside of the auto sump,hope this was some help all the best.
Oct 30, 2016 | 1998 Mazda MPV
Where is located the ground wire on mazda mpv 2001?
Your ground wire connection for the OBD2 connector is located under the dash just below and to the right of the heater controls. More likely that you dont have power to the connector. Check the 10 amp "ROOM" fuse in under dash fuse box.
May 08, 2016 | 2001 Mazda MPV
How can change blower motor to 2005 mazda mpv
The blower motor is located under the dash on the passenger side of the van, remove any lower dash panels covering the underside of the dash to access the motor. It may be easier to remove the glove box liner for access.
Feb 21, 2012 | 2005 Mazda MPV
Just bought a 1998 Dodge Ram Sport pickup, two keyless entry units came with it. They do not function, replaced the batterise in them they still do not function, how do I get them to work?
take your truck to dealer and have them enable keyless entry if your truck is equipped with it,or one other thing is to check your owners manual to see how to reprogam the units when batteries are replaced
Nov 15, 2009 | 1998 Dodge Ram 1500 4WD
Would like to rekey my auto-keyless entry and cannot find the code near the instrument panel.
your factory code for keyless entry by number pad? this is found on the module for keyless entry located under dash left side, number on module in BOLD type is the original or factory code
May 18, 2009 | 2004 Ford Expedition
I can't find the keyless entry code for my 2004 ford freestar
The code is on the fuse box under the dash near the hood release. On my van there are two bar codes on a sticker attached to the fuse box. Under the first bar code, on the right side is the 5 digit code (bring your glasses the numbers are really small). After you get this code, just search the internet and there are plenty of forums on programing the keyless remote and also adding your own unique number to the key pad entry.
Good Luck
Mar 08, 2009 | 2004 Ford Freestar
Keyless entry code
Right hand side rear cargo area under the trim panel under the side glass, many of the electronics are under that panel.
Nov 18, 2008 | 1995 Ford Explorer
Mazda MPV 2000
Try "resetting" your keyless entry code. Which is a fancy way of explaining that I broke my keyless entry key fob and had to order a new one. It came w/ instructions explaining how to get the new fob to speak to the car's computer. It was weird (turn key on and off 3 times, open and close door three times, etc. **I'm sure my neighbors were watching and laughing**), but it worked. I'll scan and email you the insrtuctions if you wish. Dan: dcarterlaw@lycos.com
Jul 07, 2008 | 2000 Mazda MPV
Vehicle Parts & Accessories Logo
225 people viewed this question
Top Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
