I have several files of custom points of interest from poi factory; recently they don't display the option of 'go' from the points of interest that are found. I find the list of Walmarts, with all there information, but to get directions, I need to enter the address. What happened? It formerly worked ok.
SOURCE: StreetPilot c 340 does not allow to enter address
Ok, you've tried a reset, but have you tried a Master Reset? Doing this WILL ERASE ALL OF YOUR FAVORITES, but it may help. Turn the unit off. Press the "On" button with your finger on the bottom right of the screen at the same time. Release the "On" button, but keep pressing the screen until the unit asks if you're sure you want to reset all data. Press "Yes". See if this helps.
SOURCE: no data available mess
Did you try to perform a map upgrade to 2008? Turn on the Garmin and from the main menu touch the wrench, then press Map, then look for Map info.
SOURCE: Entering and deleting addresses in "Favorites"
Probably go to the favorites menu and manually add it there? if not, when you click the address when it ends up in the recently found, is there no menus that say, maybe , add to favorites?
SOURCE: An address appeared on my gps, however, it is an
If you were browsing the map on the satnav it's possible that you pressed the screen at that point which would give the option of saving it to the favourites folder. If you then pressed SAVE it would save to favourites.
Another possibility is that when you were driving the car you pressed the car icon, which shows your location. This can automatically save the location to favourites if the car was moving or if you were stopped it would ask you if you wanted to save it.
