Question about Oasis Hunter 54' Ceiling Fan
New hunter floor fan Model 90121A does not work
Gets current but does not come on. ever!
Where can I get a new motor for my Hunter Designer's Choice Ceiling Fan (model # 99048
Call Hunter at 1-901-745-9222. I think this number is still current, it might not be. Tell them your issue, most likely they will send you an entire new unit (or is your fan the OLD Designer's Choice from the 80's with a rubber flywheel?)
Apr 06, 2012 | Hunter Designer's Choice 5-Switchblades Lg...
We have a 2 year old Hunter Fan Model # 23285 The fan works fine. Last week the lights began flickering. We changed bulbs, checked for loose wires, etc. The lights go on dim and continue to flicker. ...
if problems with lights flickering. remove governor inside for the lights, and wire lights direct. this should cure problem. ( black box or governor ). part # 98480-02-- have a good day !!
Jan 06, 2011 | Hunter Ceiling Fans Individual...
I just installed a hunter 70" fan model #23285.
Not really a solution but .. try this.. Don't use the fan lights as primary lighting. Install low wattage bulbs in the fan to reduce the shadow depth, and use alternate primary lighting, for example a Torchier style floor lamp.
You realize of course that it did not show in the store because it was surrounded by alternate light sources, eliminating the shadows.
Nov 28, 2010 | Hunter Ceiling Fans Individual...
Hunter 23852,L-black to red-hurricane speed,black to yellow-almost hurricane,black to gray-very slow,hardy moves air,installed westinghouse 6A125vac switch,same speeds,how can i get a comfortable medium...
Sounds like a good ol' American made Hunter Original to me. BEST and most powerful residential ceiling fan (high quality) ever made. The RPM spec is 200-160-50 for the respective speeds, moving 10,500 CFM on high speed. Most ceiling fans barely crack 5,000 CFM. they were built for Brute Force Air Movement and they really don't do well for small spaces. The best solution I have for you is if you have a Wall switch for this fan, to install a Hunter Original Wall control or remote control.
Both controls will lower the Medium speed to about 100-110 rpm, which should be much more comfortable for you.
Because the Hunter Original (I know your fan is an American made unit by your wire colors) draws more current than other fans, the Original controls are the only controls that are designed to work with your fan. Other controls do not have the current capacity for the Original motor.
Also, are you aware your fan uses oil?
Aug 22, 2010 | Hunter 23852 Classic Original Ceiling Fan
Fan works, light works, but won't turn off
Sounds like that part of the multi-switch in the remote is either dirty or shot. Google for new remote for you model of fan
Oct 01, 2017 | Hunter 22460 52'' The Astoria Brushed...
Home Depot Switch Doesn't Work. Does anyone know where to get a
Google search Hunter Fan Parts. Should find what you need, and have it in a few days.
Regards, --WoobieDog--
Jul 10, 2009 | Hunter 30216 3-SPEED FLOOR MODEL Air...
Hunter Fan model no.22570
take it back, and explain to them it will not work. you should be able to get a new one !!
Aug 16, 2008 | Hunter Ceiling Fan Light Switch Control
Oasis Hunter 54' Ceiling Fan Logo
127 people viewed this question
Top Oasis Dryers Experts
Are you an Oasis Dryer Expert? Answer questions, earn points and help others
