Question about Samsung Digimax S800 Digital Camera
Digital camera I put brand new batteries in my camera. It will turn on, then turn off after 2 seconds, with 3 beeps
    Scholar:
  • 125 Answers
Check the ff: 1. In the setup, make sure that the type of battery matches that actual battery that you are using, page 60 of the manual. Choices are alakaline or NiMh. 2. Make sure that the contact in the battery cover is ok^, you may have to scrape if there is dirt. Dirt will introduce resistance and the battery will not be able to supply the required power.
Posted on May 27, 2007
  • 883 Answers
Look for a small pinhole and insert a pin immediately after power up to reset the camera
Posted on May 26, 2007
When I turn my camera on it stays on for a few seconds and then shuts itself off. I even put brand new batteries in it and it does the same thing
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 14, 2010 | Kodak EasyShare Z700 Digital Camera
Digimax s500 cutting off
BAtteries draws down too quick...
Use 2500 mAh or better for longer life the higher the number...
eveready bunny is sometimes not in all their work
Jul 27, 2009 | Samsung Digimax S500 Digital Camera
Samsung bl103
Mine did the same thing. Just let it sit for a couple of days. Don't mess with it. It'll eventually stop doing that and work. That's what i did. It worked for mine.
Jul 15, 2009 | Samsung Digimax D53 Digital Camera
I turn camera on. Lens comes out. beep 3 times. turns off.
Everytime I try to turn it on, the lens comes out for about a second, the camera beeps 3 times, the lens retracts and the camera shuts off. The battery is completely charged and the camera is only 4 months old. HELPP :(
Jun 17, 2009 | Samsung Digimax S500 Digital Camera
Samsung digimax s700
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Aug 21, 2008 | Samsung Digimax A400 Digital Camera
Power on n off
sounds like a battery power problem or problem with the terminal of the camera ; you know the point where the battery meets the camera.
I would recommend a service center
May 31, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Lens stuck open
try little rubbing alcohol around outer surface of lense this should loosen up the sticky ness of it
remove the memmory card and turn on this should reset camera
May 13, 2008 | Samsung Digimax 4500 Digital Camera
Lens stuck open
i have just had the same problem. mine was stuck open, i gave the lens a slight twist and heard a bit of a crack. i switched it on again, now it is ok.
Apr 09, 2008 | Samsung Digimax S600 Digital Camera
HELP!
Use lithium batteries. I had a problem when our camera would turn on for a few seconds, beep 3 times, and then shut off. The best batteries, which are actually recomended for this camera is the lithium batteries. I strongly suggest them.
Nov 13, 2007 | Samsung Digimax S500 Digital Camera
Won't stay turned on!
IF YOU GO IN TO YOUR CAMERAS MENU AND OPTIONS YOU WILL FIND A SETTING FOR THAT. EITHER UNDER POWER SAVER OR MAIN CAMERA OPTIONS AND SETTINGS. I HAD TO CHANGE MY DELAY TIME TO MAX. ALL CAMERAS NOW HAVE A TIME DELAY BEFORE POWERING OFF TO SAVE YOUR BATTERIES. ITS A GOOD IDEA IF YOU ACCIDENTLY SET YOUR CAMERA DOWN AND FORGET. BUT IT IS A PAIN WHEN IT COMES SET FOR 5 SECONDS. HOPE THATS ALL IT IS
Sep 27, 2007 | Samsung Digimax S630 Digital Camera
Samsung Digimax S800 Digital Camera Logo
79 people viewed this question
Top Samsung Cameras Experts
Computer Links
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
